Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
10-28-2005, 17:56 | #31 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Free World Age: 59
Member: 89177 Status: Offline Thanks Meter: 5 | I have flashed nokia 6600 with version 5.27 and after done init sim lock after that formated the user aerea Phone is working normally but has no network. I used to flash the pm with euroals.pp and the difoult.pp with two booth no network What enymore I have to do |
10-29-2005, 10:46 | #32 (permalink) | |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | hi willy ... all flashes are good for sure. It sseem i have problem with flas h d314. leave the phone for an hour.. flash id become bad. replace with another, good for first time, but it will bad after one hour. Maybe the path ??? please help Quote:
11-01-2005, 17:39 | #33 (permalink) |
Member: 3194 Status: Offline Thanks Meter: 41 | sory... my mistake. is not d314..but 315. solved by jumper b9 to upp path. i have one more problem.. 6600 signal problem. rssi is jumping.. -25, -80, -30, etc... ithe [hone is water damage. dead. i replace uem but no signal. mjoelner replace not helping. please help e again.... |
11-04-2005, 09:41 | #36 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 51
Member: 78767 Status: Offline Sonork: 100.95137 Thanks Meter: 566 | Quote:
can you give picture for jumper b9 to upp pat | |
11-06-2005, 16:06 | #38 (permalink) |
Junior Member Join Date: Aug 2005 Age: 45
Member: 171344 Status: Offline Thanks Meter: 0 | hi raheeeeb. my problem is that when i switch the unit on, NOKIA word shows, but after awhile just shows bright light. i need your help. how can i format N6600's phone memory? what "code" should i press? |
11-06-2005, 19:18 | #39 (permalink) | |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
if you still have a problem post what the stauts of your phone exactlly might we give you a help .. br., raheeeeb | |
11-07-2005, 10:08 | #40 (permalink) | |
can you give picture for jumper b9 to upp path | |
11-16-2005, 19:05 | #41 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | i have 2 phones 6600 when power it up , u see nokia logo on screen with lcd on (white) for ever and nothing changed, try sw solution did not help, also try change UPP but also the same white screen with nokia logo ...!!!! pls help |
11-17-2005, 06:00 | #42 (permalink) | |
Junior Member Join Date: Jun 2005 Age: 37
Member: 157144 Status: Offline Thanks Meter: 0 | Quote:
REGARDS NITIN | |
11-23-2005, 18:52 | #43 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Quote:
hay,,, VR3~VR7 UPP to RFIC 4 line (reset , SDATA, SLCK, SENA) RFIC to UEM 4 line VCO LOOP ! Willy | |
11-29-2005, 19:37 | #44 (permalink) |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | @ hi all i have the problem 6600 automatic switch off agen i put good bettry not on i have full flash v 5.530 flasing is complet but lcd do not sow any thing plz helpe me my 6600 dead |
11-30-2005, 18:04 | #45 (permalink) | |
what the phone problem whne you recived it and what you done also what the phone status now to help you best regards raheeeeb | |
How to solve the problem in Kentucky, we service 5130 | shirzad3423 | Nokia Base Band 5 ( BB-5 ) | 2 | 02-14-2010 14:32 |
how to solve this problem in Mt-Box??? | svchost | MT-BOX | 6 | 03-24-2009 21:53 |
How to solve blinking problem of nokia 7500 with UB? help | alexvideogames | Universalbox | 1 | 10-30-2008 09:42 |
How to solve boot problem ? | pavankhatri4024 | Chinese Models & Cloned Phones | 4 | 09-21-2008 13:58 |
how to solve "no network in nokia 1110i" | gsmfield | Nokia Hardware & Hardware Repair | 21 | 04-15-2008 05:36 |
