Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-22-2004, 11:39 | #63 (permalink) |
Insane Poster Join Date: Jun 2004 Location: RSA Technology Age: 44
Member: 67836 Status: Offline Thanks Meter: 0 | 3310 no network I have a 3310 that nevr find the network. I try all software solution but no result. I tried with DCT repair partner by neb 3.2, with test Tx900 it seems that there is a good signal, but with test Tx1800 there is no signal. what can be the problem and which IC I should change first? (if it's hardware probleme???) br |
07-23-2004, 20:12 | #66 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | @keany, That's quite a lot here in my country. With our normal service charges between US dollars 3 to 15 (including some spares) it'll take ages to recover. Certainly rates of equipment have dropped by now, but still i have to do a return on investment analysis before i invest. Also that amount is currently beyond my means, and is beyond that of several technicians. As i said elsewhere, I am not limited to earning from the GSM field. As and when i feel its right I shall invest. Could u please give the details of your equipment; make, model, measurement range? Thanks |
07-24-2004, 17:32 | #67 (permalink) | |
Junior Member Join Date: Jul 2003
Member: 35576 Status: Offline Thanks Meter: 0 | Quote:
07-28-2004, 13:48 | #70 (permalink) |
No Life Poster Join Date: Nov 2000
Member: 2625 Status: Offline Thanks Meter: 2 | Hi At first I must say big HELLO and big THANKS to keany for this thread. I have one question. Is is posible to made some (home made ) tester for RX or TX problems .??? What is happening when you put phone near FM Radio station and you hear noise (I hope everybody know what noise) in radio when phone finding network or reciving massage or call.May that use as some tester or ??? Thanks Regards |
07-28-2004, 20:03 | #71 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
07-29-2004, 00:37 | #72 (permalink) |
Freak Poster Join Date: Jul 2003 Location: All Around!
Member: 33996 Status: Offline Thanks Meter: 3 | Thank you so much Sir.. Very useful for poor countries where GSM is still new, and 3310´s are everyday stuff! I´ll get my hands on a few 3310´s and post my results.. |
07-31-2004, 14:49 | #73 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Palestine-Iraq-Afghanistan.... Age: 25
Member: 6478 Status: Offline Thanks Meter: 3 | OK! someone please explain this... I had signal problem in 8210 flashed with good flash -NO luck-thought it was PA e.t.c BUT surely I cant believe always (hardware fault) PA-coz could be several hardware flaws COBBA e.t.c BUT I think theres software fix- then I thought its dead fone may aswell use it as mados calc so flashed with MADOS moded full flash-now signal perfect can make & receive calls with NO problems! strange! |
08-02-2004, 18:50 | #75 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | NOKIA 7250 nhm j, I meat with the stanger problem, I got one 7250 with a camera, the phone radio was no radio (radio error) I flashed it and acting good, bu the phone from now can not ring and cannot listen it through speaker but only with Headphone, I tried to update until 7250i but this result contact service, but initial the phone main cover was written 7250 NHL-4 as I know the NHL-4 is for 7210 and NHL -4J is for 7250 also NHL4JX is 7250i, any body who can solve my problem |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth™ | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
