i try to manual search network found, but if i select 1 network, no network perview on display.....:confused: |
3310swich antena jampar |
Same Problam Change Anteina Switch >>>>>> But No Network |
hello bhai i have one sigmatel dead on formating format error.A5 come |
n 70 no network on n 70 any body help me |
hi bro i have 2 set of n81 ,i set is no display n other set is when start up it will just hung at nokia than blank over n over again .can u tell me what to do ? thanks |
nokia 3120c netwark problem pls hlp me nokia 3120c netwark problem.i wr pm file but same problm.when i call any whr it say no netwark covarage. |
nokia 1110 signal problem plz help me |
Urgent Need Help Team Plz Nokia 6300 RM-217 Signal Problem SALAMz...................... dear I hav NOkia 6300 Rm-217 its signal booster full short but mobile iz on tell me how i recover my signal without booster if hav ny direct jumper to antina that signal work plz tell me how i direct jumper to antina that signal work plz help i Change many booster on my nokia 6300 but signal not work giv me any direct signal methode plz its urgent plz plz plz nokia team help me............... |
i got a N70 shorting on z7500. here >> 1..remove this z7500 mark in (1) if u want to check the shorting of pf of gsm and wcdma ....if remove the coil and ur shorting is gone then there is shoting in ur pf of gsm or wcdma ........ http://forum.gsmhosting.com/vbb/show...ight=n70+z7500 (POST #7) WHATS THE SOLUTION? how can i repair that pf of gsm or wcdma? please help... :( |
6681 network no access after water damg |
6610 no signal, can u help for this problem? |
6300 Network got problem,wat ic should Check?:confused: |
1.bt.sisx not supported? Hi there, I have tried to install tom tom v6 onto my n95 8gb and keep getting the error message that 1.bt.sisx is not supported. I have previously managed this on my daughters old n95 and it worked fine until she lost the phone hence me trying to install onto the n95 8gb |
nokia 1100 and 1200 network prob brother 1100 shows all network but goes down with 5 seconds and 1200 show no network plz help soon |
