Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 07-17-2017, 22:57   #8956 (permalink)
Member: 2737733
Good Evening, I'm having a nasty problem with my Nokia 5530. Everything works fine, earpiece and all, but when calls are made/receved, most of the times nothing can be heard. Removing and re-inserting SIM card seems to work temporarely but then problem returns. Thought issue was SIM card, so had 2nd made, but problem precisted. Please help me, I don't want to have to switch phone and you're my last hope.
Old 07-17-2017, 23:07   #8957 (permalink)
Member: 1177781
Sonork: zam zam
Thanks Meter: 3
If you can use rework and hit gently the audi ic
Old 07-24-2017, 04:46   #8958 (permalink)
Member: 2739901
How do I fix network problem on Nokia 105?
Old 08-15-2017, 02:46   #8959 (permalink)
Member: 1701611
Smile Nokia 1100 Show Battery Empty and Power Off Frequently
Hi, Anyone help me to solve Nokia 1100 Power Off Problem. battery is Full charged and its frequently showing Battery empty message and power off.
Old 08-15-2017, 10:31   #8960 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
check BSI on board for battery empty problem.
The Following User Says Thank You to nafe2me For This Useful Post:
Old 08-21-2017, 03:29   #8961 (permalink)
Member: 1701611
Thanks for advice and can you post picture of that.
Old 08-21-2017, 04:00   #8962 (permalink)
Member: 2467697
Sonork: 100.1675830
Thanks Meter: 13
nokia 3310 2017 edition enter SIM PIN problem...
help!!!not supported with cm2 dongle
Old 08-21-2017, 06:41   #8963 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
check these jumper
or try this
Old 08-27-2017, 23:47   #8964 (permalink)
Member: 2751856
Hi, need to unlock my Nokia C5-00. Can you help?
Old 09-05-2017, 11:11   #8965 (permalink)
Member: 1071128
Thanks Meter: 33
Nokia 150 keypad problem
keys, 4 5 6 Ok and Left key not working.
Old 09-10-2017, 18:59   #8966 (permalink)
Member: 2756362
Originally Posted by nolyboy View Post
hey guys post your problem here ill try to help
Nokia 105 not charging error problem solution
Old 10-22-2017, 07:22   #8967 (permalink)
Member: 2365611
Sonork: just post your massage i
I have nokia c2-00 when i changed screen it continue to display white and all tracks are ok solution pls
Old 11-02-2017, 08:12   #8968 (permalink)
Member: 2773245
nokia 150 power key solution
Old 11-18-2017, 15:29   #8969 (permalink)
Member: 2775091
Nokia Rm-969
It's keypad not working give me solution to repair it please
Old 11-30-2017, 07:37   #8970 (permalink)
Member: 1785635
Thanks Meter: 9
Hello everyone. I have a problem about Nokia Lumia 620. its my customer's phone. I lost that diode in picture and when i was power phone it starts as right photo. When i add a diode that area phone is not working. What should i do? Thanks
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.27492 seconds with 10 queries
