Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-14-2006, 15:08 | #2072 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: Africa
Member: 180758 Status: Offline Thanks Meter: 13 | 2100 Power Problem Still Quote:
anyother solution or must the ic come from a 2100 ?????? | |
07-14-2006, 15:18 | #2073 (permalink) | |
Member: 180758 Status: Offline Thanks Meter: 13 | (1) 3310 : power problem,(2)2100 :power problem(3)3310 :network probloem Quote:
A 2100 trips off after powering and sometimes some of the keys wont function. Any solutions ????????!!! A 3310 with network problem cant search the network sometimes and when it gets a network,cant make calls.have changed the hetwork switch ,heat the pcb, bridged the antenna switch .Still no network Please help Thanks([email protected]) | |
07-14-2006, 20:14 | #2075 (permalink) | |
Freak Poster Join Date: Aug 2004 Age: 45
Member: 77076 Status: Offline Thanks Meter: 7 | 1110 simways Quote:
07-15-2006, 21:16 | #2076 (permalink) |
Junior Member Join Date: Jul 2006
Member: 312319 Status: Offline Thanks Meter: 1 | nokia 6680 i am a technicianof gsm.now i have a 6680 nokia.that is fell down in the water,now that is not working,only light coming.then i connect TORNADO BOX.I can see the problem THE PRODUCT TYPE MISS MATCH.what will ido .help me |
07-15-2006, 21:20 | #2077 (permalink) | |
Member: 312319 Status: Offline Thanks Meter: 1 | 3310 network Quote:
07-15-2006, 21:21 | #2078 (permalink) | |
07-16-2006, 07:48 | #2079 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: PHIL
Member: 197247 Status: Offline Thanks Meter: 296 | Quote:
07-16-2006, 10:44 | #2081 (permalink) |
Insane Poster Join Date: Mar 2005 Location: Cuttack,India Age: 48
Member: 131618 Status: Offline Thanks Meter: 2 | it was 3120 with n/w problem i just opened and heat the n/w area lightly now the set dead. it can connected with software can do all ui setting except reboot in normal mode |
07-16-2006, 11:57 | #2082 (permalink) |
Junior Member Join Date: Jun 2006
Member: 296806 Status: Offline Thanks Meter: 0 | Hello, Please help me solve this problem. I've come to notice that my Nokia 3230 is not playing all midi files. I had lots of midi files that I used to play on the mobile but now it is playing only few of the midi files but other midi files even though they are in the correct format with .mid extension are not being recongised as midi files and it says unknown format. How is it that I have 2 midi files one of them being recognised and and the other not recognised? I used to play all these files before. How to solve the problem? |
07-16-2006, 17:36 | #2083 (permalink) | |
Member: 312008 Status: Offline Thanks Meter: 0 | Un-lock country code Quote:
357093005136308 3 mobiles UK un-lock the country code being used in Pakistan | |
07-16-2006, 17:55 | #2084 (permalink) | |
Member: 296693 Status: Offline Thanks Meter: 0 | Quote:
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
