Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 03-09-2009, 00:45   #5881 (permalink)
vali23_mm's Avatar
Member: 627228
Sonork: 100.1577983
Thanks Meter: 155
Originally Posted by SheikhEhsan View Post
1600 contact service
Rehold PCB ................
Old 03-09-2009, 00:46   #5882 (permalink)
vali23_mm's Avatar
Member: 627228
Sonork: 100.1577983
Thanks Meter: 155
Originally Posted by kajol1167 View Post
nokia 7610 start up failed.after full flash also remain same problem.start up failed.contact the retailer.please post me the solution.
Check if PM is ok do self test and run all
Write Good PM
BR,vali23_mm
Old 03-09-2009, 03:58   #5883 (permalink)
Member: 990117
hello,
i have a nokia 6300,but for some reason it can no longer switch on.i have tried charging/swapping the battery and sim cards but although the blue side lights sometimes flash,but still won't on......
Old 03-09-2009, 04:02   #5884 (permalink)
Member: 990117
hello,
Old 03-09-2009, 07:58   #5885 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 148
7610 contact retailer
Write Good PM
BR,vali23_mm
dear change boot ic ur problem will be solve 10000000000000000%
if u dont know about boot ic then ask me for picure i send u
Old 03-09-2009, 08:01   #5886 (permalink)
Member: 405696
Thanks Meter: 148
6300 blue lights
Originally Posted by rhenzz View Post
hello,
brother flash with 7 pin cable and upgrade latest version of software
Old 03-09-2009, 11:56   #5887 (permalink)
Member: 633701
8600 charging not support pls hep me
Old 03-10-2009, 01:29   #5888 (permalink)
vali23_mm's Avatar
Member: 627228
Sonork: 100.1577983
Thanks Meter: 155
Do info with JAF and Post here log
And so Self Test check all filds and see if all pass
B.R,vali23_mm
Old 03-10-2009, 06:57   #5889 (permalink)
dey mobiles's Avatar
Member: 799558
Thanks Meter: 430
Bro nokia 1110 no charging when i connect the charger only beep and on display not showing any chargeing bars but after one hour when i unplug the charger the battery is empty there is no charge in the battery please help me........................
Old 03-10-2009, 07:39   #5890 (permalink)
Member: 802916
Thanks Meter: 23
Post 1600 contact servies
chang ic and okaaaaaaaaaaaaaaaaaaaaaa
Old 03-10-2009, 07:42   #5891 (permalink)
Member: 802916
Thanks Meter: 23
7610 contactservies
take flesh 7610 and set will be ok
Old 03-10-2009, 18:30   #5892 (permalink)
Member: 991413
simply blackberry question
Hi, I have a blackberry curve which is no longer connected to my employers exchange server and hence I do not receive emails from my employers email account. I would however like to have access to my yahoo account emails. The phone is connected to T mobile though I can not access the internet, I was told this is because I was no longer connected to the exchange server.
Can you help?
Much appreciate in advance
Old 03-11-2009, 03:11   #5893 (permalink)
vali23_mm's Avatar
Member: 627228
Sonork: 100.1577983
Thanks Meter: 155
Can you help?
Try Please in Blackberry Section becouse in Blackberry section is more user blackberry and can Help you
Here is Nokia Hardware section
B.R,vali23_mm
Old 03-11-2009, 06:41   #5894 (permalink)
Crazy Poster
Member: 798093
Sonork: 000001
Thanks Meter: 6
n70 network
hello...can u help me, nokia n70 network ok and sometimes missed....
always like that.....beside that batery very fast empty......
plz help [email protected]....
Originally Posted by nolyboy View Post
hey guys post your problem here ill try to help
Old 03-11-2009, 06:43   #5895 (permalink)
Member: 991731
NKTel C6000 problem
I have a NKTel C6000 Set,
It was not getting properly charged from last two months,
I found the cable used for charging was having problem , the cable that converts the USB to the standard for charging and connecting the phone to PC is having its sodering joints broken, I didn't find that type of cable in the market.
I have searched on the internet that the connector name is " L12B ".
Can any body help me please to get the pin diagram for the 12 pin connector , so that I can charge my phone.
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.27220 seconds with 10 queries
