Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 12-15-2006, 16:43   #2941 (permalink)
Member: 405886
I have a Nokia 6030. I was wondering why everytime I put java applications larger than 100 kb they come up as invalid. Every app/game under that size seems to work fine.....is there a way to fix this? Thanks!!
Old 12-16-2006, 03:48   #2942 (permalink)
Member: 300545
do u know what movie format except for mp4 is supported in sonyericsson k610i and k618i its says wmv, 3gpp but i cant play any of this movie type
Old 12-16-2006, 06:12   #2943 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
Red face 6680 no network
hi friend here i try to do jumper for antenna switch but still having problem also front camera not working can you send me possition for camera & its diagram
Old 12-16-2006, 06:45   #2944 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by @sEPH View Post
help Bro. the prob. n1110 no buzzer when i heat the audio ic becomes contcact service on showing the screen then i heat again its work but the signal now is the problem no network found already what should i do now?
you said only audio ic u heated then try to replace it
Old 12-16-2006, 06:47   #2945 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by mohsen643 View Post
dear friend
without receiving or sending anything, all of a sudden my nokia 7610 froze up
I could not even turn off,removed the battery and turned on again but no use.
Removed the MMC, phone worked well.
Formatted the phone without mmc, inserted mmc again,phone cant start and hangs on white NOKIA LOGO screen.
haven't got a mmc reader to format mmc.
Can you help me plz
well you got to format your mmc so but mmc reader there are cheap mmc reader now
Old 12-16-2006, 09:47   #2946 (permalink)
Member: 405608
Sonork: marklester
Thanks Meter: 47
Originally Posted by nolyboy View Post
hey guys post your problem here ill try to help
hello!can u help me with my 3200 notcharging?
Old 12-16-2006, 09:58   #2947 (permalink)
Member: 405608
Sonork: marklester
Thanks Meter: 47
notcharging 3200
Old 12-16-2006, 10:09   #2948 (permalink)
techseeker"ems"'s Avatar
Member: 343227
Thanks Meter: 22
full erase files
could you give me a bin file or full erase flash file of 6220 or 6610i??? thanks...
Old 12-17-2006, 15:23   #2949 (permalink)
tony1972's Avatar
Member: 280989
Thanks Meter: 9
hello,nokia 3650 not charging pls help me.
Old 12-18-2006, 07:19   #2950 (permalink)
Member: 409247
Hi I'd be very grateful for an unlock code for this please
Nokia 1110
010765001928866
Telefonica Moviles El Salvador
El Salvador (MCC=706)
Many thanks
Roger
Old 12-18-2006, 07:38   #2951 (permalink)
Member: 409247
Nokia 1110
010765001928866
Many thanks
Roger
[email protected]
Old 12-18-2006, 18:33   #2952 (permalink)
rirou's Avatar
Member: 85312
Sonork: 1576920
Thanks Meter: 35
nokia 7370 no ring and no sound .......thanks
Old 12-18-2006, 23:39   #2953 (permalink)
Member: 220070
pls i need solution to my e900 samsung keypad not working
Old 12-19-2006, 10:09   #2954 (permalink)
Member: 378442
Hey men i need your help.
i ve 6101 no light, an them no key pad.
any solution.
in this forum no key pad wayes.
the 6101 only work 1 and 4 y off. no more.
if your any solution. Thanks
best regards
Old 12-20-2006, 11:47   #2955 (permalink)
Member: 380076
Hello...
I need help. Do you have any solution for SE k500i with broken joystick?
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.57017 seconds with 10 queries
