Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
12-26-2007, 03:30 | #3978 (permalink) |
Junior Member Join Date: Dec 2007
Member: 662515 Status: Offline Thanks Meter: 0 | Hi, I've recently purchased a Chinese LV918 mobile phone (that which comes with an external telescope). The problem is that i am unable to see the files on the Phone when i connect it to my PC through USB connector.I am able to see only the files on its 256 T Flash Memory card. Is this phone locked? if so please let me know the codes for unlocking ( or the Password for the phone)the phone so that the contents of the phone could be accessed. |
12-26-2007, 13:49 | #3980 (permalink) |
Member: 662897 Status: Offline Thanks Meter: 0 | Forgot N70 Lock Hi I changed my lock code but now have forgotten it and was wondering how it can be restored either with an override code which i have tried many or flashing the phone. Phone: Nokia N70 IMEI: 359367004183307 Please Help Me Thanks |
12-27-2007, 19:26 | #3981 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 315775 Status: Offline Thanks Meter: 9 | i have nokia 6280 water damage. the problem is cannot detect memory card. when i go to galary and open the memory card section the phone going black screen and hang. please help me... |
12-28-2007, 10:23 | #3982 (permalink) | |
Insane Poster Join Date: Feb 2007 Location: Abu Dhabi,UAE
Member: 447572 Status: Offline Thanks Meter: 5 | Quote:
CS problem depends if its H or Sftwr,however if dropped fone and suddenly became CS surely its Hrdwre. 1.Try to reHeat UPP,b careful not 2 damage it otherwise all d data inside d Flash ic will b gone coz 1s u replace d UPP u have to flash it. 2.Make IMEI Backup 1st for safety in case u damage d Flash ic so u can restore d Imei. 3. If its Sftwre no other way but to flash d fone normally | |
12-28-2007, 10:28 | #3983 (permalink) | |
4matting wont reset d security code,Search apps in this Forum for lock code removal just input d whole IMEI n it will gener8 d code for ur fone. | |
12-28-2007, 10:33 | #3984 (permalink) | |
Hi, It means ur fone is grounded better use a microscope analogue so u can easily check d circuit and parts for corrosion,replace damaged n corroded parts connected to MMC circuit. | |
12-28-2007, 10:35 | #3985 (permalink) | |
Just search for BB5 lock code removal to reset d Sec.code to default no need to flash d fone. | |
12-28-2007, 19:12 | #3986 (permalink) |
Member: 665035 Status: Offline Thanks Meter: 0 | help with nokia 1110i/1112 i have a nokia 1110i/1112 how can i make it possible for my phone to show me the name of contacts that call me and to show names when contacts send me messages. my phone only shows the number__ so if i want to see who sent me the message or who is calling i would have to go to my addressbook to see who it is. please help. |
01-07-2008, 16:10 | #3988 (permalink) |
Member: 664597 Status: Offline Thanks Meter: 0 | Can u plz tel me nay software that can read sms 4m nokia 1112.. i hav a data cable(6030) n mobi mb 4.2 . but it only sends tones in the nokia 1112.. i want any software that can read messages from 1112 using 6030data cable.... plz guide me.. U can reply me on [email protected]... Witing for ur reply Reguards, Zohaib Khan |
01-08-2008, 21:47 | #3989 (permalink) |
Junior Member Join Date: Aug 2007
Member: 562449 Status: Offline Thanks Meter: 0 | Hi! i having a charging problem with my nokia 8800. when my phone is on low so i try to plug in to charge but it won't charge, it just say battery is full, i tried with other battery but still the same. |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
