Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
10-06-2010, 03:27 | #5027 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 381168 Status: Offline Thanks Meter: 935 | N95 8gb no display i have N95 8GB but strange problem no display incoming and out going ok , also i already change display and flex and Display Ic sill same problem , how can i solve this problem |
10-08-2010, 05:25 | #5029 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1389140 Status: Offline Sonork: [email protected] Thanks Meter: 0 | motorola motorola c168 . mic noise problem . |
10-08-2010, 11:06 | #5030 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1178397 Status: Offline Sonork: [email protected] Thanks Meter: 6 | samsung cdma sch b259 read lock samsung cdma sch b259 read lock.how read this lock |
10-08-2010, 15:26 | #5032 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1118348 Status: Offline Thanks Meter: 1 | I have a nokia 6300. It have weak network problem. The network down with one stick network all the time, some time 3 or 4 stick and some time no network. What is the solution. |
10-08-2010, 18:22 | #5034 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1236777 Status: Offline Thanks Meter: 0 | Urgent Help!!!!!!!! Hi Guys I have a water damaged nokia 7610. After bypassing zocuss MCU ID identified in jaf but flash id doesn't. and also it's not powering up. So when i tried to flash it doesn't success. Here is the jaf log Getting MCU ID MCU ID: 0x1081 Error reading flashid... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\ Searching for default location of ini... Checking path: \Products\RH-51\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: E:\Nokia\lsd_rh-51_v7.0642.0\RH51_52_67_68PE706420.C1 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: E:\Nokia\lsd_rh-51_v7.0642.0\RH51_52_67_68PE706420.C1 PPM Flash file: E:\Nokia\lsd_rh-51_v7.0642.0\RH51PE706420.26 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: E:\Nokia\lsd_rh-51_v7.0642.0\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... Error in CHK... Error Loading loader! Please Help Me Guys |
10-10-2010, 14:03 | #5039 (permalink) |
Freak Poster Join Date: Sep 2006 Location: bangladesh
Member: 346890 Status: Offline Thanks Meter: 12 | 1ST BOOT : C0,07 [] [2.1.0.1] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 08E00110FFC44650A74873EFCFC6E666127C230C RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK Rebooting Mobile 1ST BOOT : C0,07 [Rm-561] [2.1.0.1] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 08E00110FFC44650A74873EFCFC6E666127C230C RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT UNKID : 32 02FFFFFFFFC800 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT ALG Boot CERT MISM IMAGE : rm561__07.80.mcusw Process Failed, Repowering Mobile pls help me as soon as posible............ |
10-12-2010, 04:14 | #5040 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 486714 Status: Offline Thanks Meter: 4 | 2690 low network Hello masters i have one 2690 burned near antena and it has low network problme come full and sometime after signal go not full 1or 2 signal show only and in some sim no network plz help me masters give me solution i wait 4 reply |
Solving Your CDMA Problem Within 24 hours | kapil2007chakde | Various CDMA/TDMA Cell Phones | 770 | 04-20-2017 22:20 |
..::solve Your Problem Within 24 Hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 16 | 02-03-2013 08:50 |
