SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
02-18-2006, 19:43 | #1 (permalink) |
Freak Poster Join Date: Sep 1999 Location: UK
Member: 498 Status: Offline Thanks Meter: 6 | D500 dead after flash VIBRATES?? Using corona 3.2 flashed a d500. Everything flashed OK. But when i powered handset on it went to a white screen then turned off. Then tried again + formatted nand first ...then clicked erase NOR and selected all areas. Now handset only vibrates when you connect a battery? Also does the same when you connect a dc power supply? Also will not connect to any computer.... Tried flashing with nsdongle too (with and without battery) and phone starts vibrating and wont connect? Any ideas? Kind Regards David |
02-18-2006, 19:51 | #2 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
First of all make sure that your phone is consuming normal voltage amplitude (current), if all is ok then flash it with SUS-Swift-DL, with nor erase checked ... | |
D500 dead after trying to flash , can anyone help? | haveri | NSPRO | 18 | 09-12-2006 17:05 |
D500 dead after flashing | Rainmaker_ua | Samsung Flashers, Software, Firmware. | 2 | 04-17-2006 02:05 |
Samsung D500 Dead After Flashing With UST | afrodizzy | UST Pro II | 3 | 01-10-2006 18:48 |
d500 dead after flash with bin + tfs | patric | SWIFT Platform | 1 | 09-12-2005 07:14 |
