SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809. |
10-15-2006, 20:17 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Age: 51
Member: 163219 Status: Offline Thanks Meter: 4 | [D900] correct pinouts RX TX for flashing i'm looking for the real, correct, and "validated" connexions (RX TX and GND) for making a RS232 cable to flash E900/D800D900 phone .... I've seen many posts here or in others forums that describe the pinouts like that: SAMSUNG E900/D800D900 phone keyboard ub SAMSUNG male connector M20 plug (on the phone) __________________________________________________ _____________ numbering left to right _____________________ \ 1........................20 / --------------------- 1&2 = GND 11 = TX (i think pinout 11 is an OUTPUT that must be connected to the "RX of MAX232" ) 12 = RX (i think pinout 12 is an INPUT that must be connected to the "TX of MAX232" ) __________________________________________________ _____________ OR LIKE THAT (the countnumber is changed) __________________________________________________ _____________ numbering right to left _____________________ \ 20........................1 / --------------------- 1&2 = GND 11 = TX (i think pinout 11 is an OUTPUT that must be connected to the "RX of MAX232" ) 12 = RX (i think pinout 12 is an INPUT that must be connected to the "TX of MAX232" ) SO WHAT IS the good pinouts / countnumber for connexions ??? AND could you give me the right pinout RX and TX for the D800 When we write TX for a pinout of the D800 it's a SIGNAL OUTPUT When we write RX for a pinout of the D800 it's a SIGNAL INPUT so in an electronic diagram: the TX pinout of the D800 must be connected to the RX pinout of the MAX232 the RX pinout of the D800 must be connected to the TX pinout of the MAX232 THANK YOU VERY MUCH for your response Stephane |
The Following User Says Thank You to paillassou For This Useful Post: |
10-16-2006, 09:40 | #3 (permalink) |
Member: 163219 Status: Offline Thanks Meter: 4 | OK thank you KhOliO so ... you scheme shows numbering right to left _____________________ \ 20........................1 / --------------------- 1&2 = GND AND could you give me the right pinout RX and TX for the D800 When we write TX for a pinout of the D800 it's a SIGNAL OUTPUT When we write RX for a pinout of the D800 it's a SIGNAL INPUT so in an electronic diagram: the TX pinout of the D800 must be connected to the RX pinout of the MAX232 the RX pinout of the D800 must be connected to the TX pinout of the MAX232 THANK YOU VERY MUCH for your response Stephane |
11-18-2006, 21:19 | #6 (permalink) | |
Member: 163219 Status: Offline Thanks Meter: 4 | Quote:
but, when you look at the connector... if you count from left to right or right to left it's different and in that case... the number 1 become 20 and the number 2 become 19 and if you want to do a shortcut between GND and VEXT... try... | |
pinout rx tx.......[ANSWERED] | s_ahmed123 | PolarBox 3 | 2 | 02-02-2010 09:13 |
Help, the pinout/rx tx gnd n889 | aswancamel | Chinese Models & Cloned Phones | 0 | 11-06-2008 14:38 |
Need Pinout Rx,tx,gnd for Cruiser box | newfoundghori | Cruiser Suite | 1 | 09-18-2008 08:42 |
Need Pinout Rx,tx,gnd Cruiser | denard | Cruiser Suite | 7 | 12-26-2007 08:46 |
i need Maximus EX60 Pinouts RX TX ..? | communication_expert | Infinity-Box | 4 | 12-17-2007 15:26 |
