Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > SWIFT Platform
SWIFT Platform D500, D508, D510, D600, D608, D800, D820, E340, E350, E640, E730, E760, T309, T809.
Old 12-04-2006, 12:55   #16 (permalink)
Member: 151264
Unhappy D600 limited service
Hi, I have a problem with a d600 that says limited service, I know its not the imei coz I know the fone is not barred but I changed to another one just incase and the same thing. Any ideas? Does anyone have a service manual for this fone that could help me? Have upgraded the software has well, same thing.
Thanks
Old 12-05-2006, 08:57   #17 (permalink)
Member: 405050
D600 + Soup do not mix
Hi experts,
I dropped my d600 into some soup and I took it apart to clean it. I can turn on the phone and make/receive calls. But the LCD screen is not showing anything other than the backlight (but screen remains black). Is my problem a broken LCD, a broken ribbon or dirty board?
thanks
The Following User Says Thank You to kalamity For This Useful Post:
Old 12-06-2006, 10:46   #18 (permalink)
Dr cellular uk's Avatar
Member: 182216
Thanks Meter: 24
Originally Posted by tandjatelecom View Post
hello
i have d500 keypad prblem
help me please
remove the key pad contacts flex and clean key contacts on pcb,or replace side swithces
Old 12-06-2006, 10:48   #19 (permalink)
Member: 182216
Thanks Meter: 24
Originally Posted by kalamity View Post
Hi experts,
thanks
replace lcd,high chances lcd is damaged,or ribbon,and just incase aswell clean the pcb lcd connector
Old 12-06-2006, 10:51   #20 (permalink)
Member: 182216
Thanks Meter: 24
Thanks
check if the antenna is ok,if so reflow the signal circuit,and the power amp...sounds life a hardware fault,mite have been dropped....
Old 12-06-2006, 13:23   #21 (permalink)
Member: 74812
Thanks Meter: 13
Problem with D600 it's discharging if I connect to charger.Can you assist,Very Urgent!!
Old 12-06-2006, 19:19   #22 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
i have bt problem. cant get activated. in other words, need the correct bt adress for the imei 356096-00-504781/4.
thx
Old 12-06-2006, 19:32   #23 (permalink)
Member: 232516
Thanks Meter: 2
HI GUYS PLEASE HELP
I HAVE A SAMSUNG D600 IT WORKING PERFECT I WANT TO FLASH IT TO CHANGE THE LANGUAGE THEN AFTER I FLASH IT IT BLINKS THEN RESTART AND BLINKS IS THERE ANYONE HAVE ANY IDEA WHAT SHOULD I DO GUYS PLEASE MSN [email protected] THANKS IN ADVANCE
Old 12-06-2006, 22:41   #24 (permalink)
Member: 151264
Thanks for the reply, how do I check the antenna? I get full bar signal strenght on the lcd but it says limited service, o2 pops up for a few seconds then disapears and limited service comes up and I know its not the phone barred, its open all networks and if I put an orange sim in or a vodaphone sim in it goes to limited service striaght away. Can you tell me where the power amp is located?
Thanks for your help.
Old 12-06-2006, 22:46   #25 (permalink)
Member: 43140
Thanks Meter: 10
i have d600 after plug in charger a minute or so later it shows battery full, then swiches off.
can u help???
Old 12-07-2006, 09:38   #26 (permalink)
Member: 298037
I want to rebuild D600's imei and BT ID. I am using FTDI cable with winimei, however, it is not entering TAT mode. Do I need serial cable for that. Can someone post BT ID for the imei 358224009042551.
Old 12-07-2006, 18:08   #27 (permalink)
Member: 274334
d500 texting (sms)
Hi I have a d500 the phone works great , But it will freeze and switch off as soon as I try and type a text message (sms or mms)
Any help with this prob please.
I have flashed this phone with d500XFEB2 flash.
Many thanx for any reply.
Aziman.
Old 12-09-2006, 15:37   #28 (permalink)
1amigo's Avatar
Member: 23587
Thanks Meter: 63
D600 Preview error
When try to use Camera finction, it shows "Preview error".
Old 12-09-2006, 16:46   #29 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
Bro i Hve Prob in my D500 White screen ..... Flex cable is Ok & also LCD ...Disply is White .... Any idea
Old 12-09-2006, 18:58   #30 (permalink)
mobilom's Avatar
Member: 190247
Thanks Meter: 3
Hi
I need help to flashing d600e with ufs sam v2.0.3
with D600EXEEL2 cant format nand flash mcu ok and i can't flash tfs... but after few seconds auto off and i have only startap.
i have msg
Please help me
The Following User Says Thank You to mobilom For This Useful Post:
I Am The Expert For Flashing 1110-1600-2310.... bouziane1 Nokia Digital Core Technology 4 ( DCT-4 ) 26 10-17-2008 14:02
need software for samsung for ufs d500 d600 digitalmk Samsung Flashers, Software, Firmware. 0 07-07-2006 11:24
samsung d500/d600 USB unlock cable henrybuoy Wanted Products 2 01-27-2006 13:27
D500 / D600 Imei Repair Is It Possible With Hwk a5hgr HWK 9 12-14-2005 11:00
Page generated in 0.34007 seconds with 10 queries
