Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 01-07-2005, 04:49   #46 (permalink)
gsmfactory's Avatar
Member: 5752
Thanks Meter: 13
Thanks a lot for this tips !! I sucess unlock a Z105 from SFR France with your tips after take 1 boring hour to make the Cable
And after lose another hour try to understand why no communication, but problem solved sucessfuly after connect PIN 2 & 3 of Com Port
Thanks Angelo
Old 01-07-2005, 16:05   #47 (permalink)
dayman22's Avatar
Member: 46621
Thanks Meter: 34
working 100% , tested today on XP.
Old 01-08-2005, 21:37   #48 (permalink)
ringtons's Avatar
Member: 97600
Thanks Meter: 97
any help please unlocking gets to
USB port open success
lock read fail
any ideas
Old 01-08-2005, 21:54   #49 (permalink)
Member: 33320
Thanks Meter: 6
I have same problem with Z107.
Problem solved on another PC with WIN98 OS.
Try with Win98
Dusko
Old 01-08-2005, 22:03   #50 (permalink)
Member: 18966
Thanks Meter: 59
10x working i just unlocked two z105u on xp good work
Old 01-08-2005, 22:21   #51 (permalink)
ringtons's Avatar
Member: 97600
Thanks Meter: 97
Try with Win98
Dusko
tried 98 still no better but at least in 98 i can get to change com port . This is a success story as you said USED ANOTHER COMPUTER WORKED FIRST TIME
Old 01-11-2005, 00:39   #52 (permalink)
Member: 33915
Thanks Meter: 4
on this post (http://forum.gsmhosting.com/vbb/show...highlight=z105 ) they say that after we conect the pins 2-3 on the port we must conect it to the green wire of the usb conection ... why ?!
is it wright ?!
Old 01-19-2005, 19:54   #53 (permalink)
MaFiaaa's Avatar
Member: 57930
Thanks Meter: 24
yes yes yes working gr8 on all windows
just make yr USB thats easy and power on the phone install driver
get any female com9 and connect 2 with 3 don`t connect this come with any think
press unlock
10000000000% working
Old 01-25-2005, 17:47   #54 (permalink)
Member: 109058
Yes. just use the original USB cable and then short out pins 2 and 3 on your COM1 with a jumper or piece of wire. If you got a laplink/serial cable, just plug in one end and use a piece of wire to short out pins 2 and 3 on the other.
You don't need to build a custom cable.
Old 01-27-2005, 11:37   #55 (permalink)
drdjolens's Avatar
Member: 33912
Thanks Meter: 3
Nice work!
Thanks
Old 02-02-2005, 23:29   #56 (permalink)
Member: 61729
Thanks Meter: 15
tested on win98se and xp sp2 working .Thanks. good work
Old 02-09-2005, 21:12   #57 (permalink)
TOZE's Avatar
Member: 54945
Thanks Meter: 22
good thing thanks fot that!!!!
i will try soon as possible!!
Old 02-14-2005, 02:01   #58 (permalink)
Member: 91605
HI, Someone was try to change IMEI on Z105?
I was try with winimei, but receive Cal_Date empty fail.
Any solution?
Thanks in advance
Old 02-15-2005, 20:19   #59 (permalink)
Singh05's Avatar
Member: 69293
Thanks Meter: 19
I have made a cable with help of this forum,
Some days ago It was working very good for me,
But now it is showing an error.
See the picture and help me please.
Old 02-16-2005, 22:07   #60 (permalink)
Member: 74443
Hi @ all
Where is green cable conected on usb?????
anyone knows???
Martech Complete Solution All in One (TRICKS / SOLUTION / GUIDE) The_Gorr Martech CLIP / Box / Key 22 05-16-2006 08:31
[NEED] Samsumg Z105 unlock solution tneto QUALCOMM Models (3G) 0 11-30-2004 16:45
PLS Where can I get Free & Complete Cracked Wintesla with Most DLL's dannyogolo Nokia Multimedia 3 10-29-2003 23:25
here is the complete solution for nokia2100 LRS13A1 flash magnet Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-17-2003 11:33
Page generated in 0.19467 seconds with 10 queries
