QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
08-19-2008, 00:03 | #64 (permalink) | |
Junior Member Join Date: Jul 2006
Member: 313122 Status: Offline Thanks Meter: 137 | UPDATED: Reloaded image ad made corrections. Hi, After searching for ages on google, I still can't seem to find a decent tutorial on how to flash my F480. However I've had bits of help from various people and I've put this little guide together. Worked a treat with my phone. Having said that after trying this guide I accept absolutely no responsibility for your phone being dmaaged or 'bricked' in anyway. Here's what I did: Downloading the software: First off you need to download the firmware you want and then Multiloader V5.33 which is the program you're going to be using to flash your phone. Quote:
Preparing your phone: I am assuming here that you've already installed Samsung PC Studio and it works fine with your supplied USB cable. NOTE: Flashing your phone will delete all your contacts, calender, settings ringtones etc. You probably want to back up all your files and contacts. I recommend syncing your contacts etc. with Samsung PC Studio and copying over your files on your phone to your memory card or PC (your memory card will not be touched). Once that's done remove any memory card you may have and then remove the SIM card. Put you battery back in. Your phone should be off at this point. Hold down the 'Volume down' key (The bottom rocker button on the left side of your phone) and the camera button and press the power on button (some of you may have to press the middle button, as well as the above buttons to go into flash mode). Your phone should start up into a wierd screen with downloader v.5.32 or something and some boxes. It's now ready to be flashed. Using Multiloader: Open multiloader. It should look something like this without all the settings selected (The middle section should be blank!): NOTE: The striked out 'W's are justbackward slashes, don't worry about that. Then press the AMSS button on the left side and browse to the firmware files you want to flash (unzip/rar them as necessary). Go to the binary folder and then select amss_compressed. Do the same for Rsrc1,Rsrc2 and FSS selecting the appropiate files as shown in the above pic. You should now be ready to flash. Connect your phone to your comp and then click download in multiloader. AT THIS POINT DO NOT TOUCH YOUR PHONE/DETATCH THE CABLE/SWITCH OFF YOUR COMP. Your phone should have a status indicator with percentages and this should be reflected in multiloader. The process should tkae about 5 minutes thgouh I'm not sure about that. Once it's done your phone will restart twice by itself. Once this is done it should start up as normal into the widgets page. It's now complete. Congratulations on flashing your phone. You can now repalce your SIM and Memory card and set up your phone the way you like it. Hope this helped. Feel free to steal this tutorial/post it on another website etc., I made it in a few minutes and couldn't care less if you take credit for it. | |
The Following 8 Users Say Thank You to WestHej For This Useful Post: |
08-19-2008, 00:26 | #65 (permalink) |
Junior Member Join Date: Feb 2007
Member: 457882 Status: Offline Thanks Meter: 9 | i did brick my phone then fixed it. so the problem is that first you flash the boot (have boot checked) after that it restarts your phone then flash the rest of the stuff with out the boot checked. so you are flashing it liek 2 times. thats how it worked for me |
The Following User Says Thank You to red man For This Useful Post: |
08-19-2008, 00:47 | #66 (permalink) |
Member: 457882 Status: Offline Thanks Meter: 9 | ok this is what i did first download the files 2. make sure your screen looks like this (after it flashes the boot it will restart your phone and try to connect back to the pc but you will not be able to and your phone will have a red screen(i was scared thinking OMG MY NEW PHONE IS BRICKED. after trying to reflashe it over and over again i realized you need to do a second flash) so after you do the first step stated above reconnect your phone to the pc and uncheck the boot box so it will look like this |
The Following 7 Users Say Thank You to red man For This Useful Post: |
08-19-2008, 18:42 | #71 (permalink) | |
Insane Poster Join Date: Jun 2007
Member: 529899 Status: Offline Thanks Meter: 12 | Quote: I have the F488 version, it's the official Hong Kong version, this version also has the pixelized image like the rest of f/w, but when the image is transferred to the PC, the image are really sharp, as with most camera phone, indoor/dark image don't really come out good. As for the F/w, I think it's quite fast, only if you dont listen to music and use the menu at the same time, otherwise you will see a lagg. kms | |
08-19-2008, 21:31 | #73 (permalink) |
Junior Member Join Date: Oct 2006
Member: 369865 Status: Offline Thanks Meter: 0 | Hi there, I'm about to take my first plunge into flashing so I'm a little bit nervous about it, and forgive me if my questions sound stupid! I'm doing this mainly because I have the problem where 50% of my calls are dropped within 15 seconds, it's getting SO frustrating! So I'm hoping a newer firmware will solve this. Firstly, I assume that changing the firmware will not delete any vital stuff like the IMEI number will it??! i.e. as soon as it's flashed I can happily continue using it on my network (O2 UK) with no problems? Secondly, has anyone had the call dropping problem (I've seen it mentioned by quite a few people across the web) before the HF7 update, and have you noticed the problem go away with the new firmware? Thanks for your help! |
Full Guide: How to Enjoy Your Favorite DVD/ Videos on Your Portable Devices at Will | Pexerious | Sharp | 0 | 09-02-2009 09:55 |
Full Guide: How to Enjoy Your Favorite DVD/ Videos on Your Portable Devices at Will | asangbetty | Motorola ODM | 0 | 06-19-2009 10:27 |
Full Guide: How to Enjoy Your Favorite DVD/ Videos on Your Portable Devices at Will | barbe5564 | Motorola Hardware Repair | 0 | 05-25-2009 07:17 |
