QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
03-30-2009, 05:39 | #1 (permalink) |
Junior Member Join Date: Jul 2005
Member: 165236 Status: Offline Thanks Meter: 0 | Samung U700b Power Button does not work after flashing I flashed it with 2 other firmwares and it remains doing the same. The last time I flashed it with Sim card (Digicel) inserted and it reboot normal and found the network and everything, however, it would not turn OFF, and when I remove and reinsert the battery, it would not turn ON. I tried pressing the POWER button on top for approximately 10-15 sec. Any help about this issue? Regards Pj |
05-23-2009, 00:53 | #5 (permalink) |
Junior Member Join Date: May 2009
Member: 1030339 Status: Offline Thanks Meter: 0 | Hi Paul Did you manage to find the right firmware? I have a similar problem and it would be a big help if you found out what went wrong. Similarly, if I find a solution, I'll post it here in case you still need it. All the best. |
2300 FM Radio does not work after flash????? | chwaseem | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 01-29-2010 18:24 |
W600 power button does not work.... | luisfer99 | Sony Ericsson Hardware Repair | 0 | 04-25-2007 04:17 |
2300 FM radia does not work after flash???? | chwaseem | UFS2 + UFS3-Tornadoflasher | 6 | 07-15-2005 09:33 |
C25 does not work after flash with 5108 | c25_f51 | x1x to x45/x50 | 0 | 05-16-2000 16:05 |
