QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
11-02-2004, 16:24 | #3 (permalink) | |
Freak Poster Join Date: Jul 2003 Location: UK Age: 56
Member: 33320 Status: Offline Thanks Meter: 6 | Quote:
11-29-2004, 11:44 | #6 (permalink) | |
Junior Member Join Date: Nov 2004 Age: 54
Member: 94522 Status: Offline Thanks Meter: 0 | Pinout Samsung Z105 Quote:
YOU ONLY NEED A USB CABLE TO UNLOCK THE PHONE.THE SECRET IS TO CONNECT TO YOUR COM PORT YOUR INTERFACE (WITH A NORMAL MAX 232) AND SHUNT PIN 10 AND 11 OFF THE IC.THE SW WILL CONNECT TO SERIAL THEN WILL READ ALL CODES BY THE USB CABLE 100% TESTED REGARDS Z105 | |
11-29-2004, 11:54 | #7 (permalink) |
Member: 94522 Status: Offline Thanks Meter: 0 | Samsung Cable Use Winimei,connect You Interface To Com Port Shunt Pin 10 And 11 Off Max 232 (out Off Rx And Tx Off The Ic) Then Connect A Usb Cable To Usb Com Port And All Problems Will Be Solve.you Can Use The Original Cable That Comes In The Box Off The Phone(usb Cable) |
Z105 Pinout | Mansoor | TST Dongle | 4 | 08-31-2005 23:58 |
is z105 pinout same as old models? pls help | ashvin | QUALCOMM Models (3G) | 0 | 07-18-2005 10:27 |
Samsung z105 need pinout | .::Zafar Communication::. | QUALCOMM Models (3G) | 1 | 12-24-2004 10:49 |
Please Ineed Usb Or Com Pinout For Z105 | SANTOGSM | QUALCOMM Models (3G) | 0 | 09-15-2004 19:20 |
z105 charger pinout? | surfer2go | QUALCOMM Models (3G) | 2 | 07-26-2004 15:47 |
