I5500 stuck on Samsung/Android logo Hi mates got this one with the above mentioned problem. Tried flashing it with various packages to no avail. Still gets stuck on the flashing logo and then loops again on the flashing logo (Samsung or Android). Used Odin 4.28 with both firmware versions 2.1 and 2.2 such as I5500XWJK3 for 2.1 and I5500XWJPL_ITVJP3_XWJP3 for 2.2. Anyone can help pls? thanks |
Mayb hardware problem. I have flash a couple of i5500 without any problem. Did u flash separate package r just one? |
i flashed 2 packages as mentioned in the first post. I did not try to flash the boot, amss etc on their own however. Cannot find such files. thanks |
For fixing the freezed problem, you need flash with full parts. http://i1128.photobucket.com/albums/...uc79/I5503.jpg |
worked 100% :D THANKS! |
but it starts and the green bar starts to move but after 2 seconds it stops and it is loading amss but now phone wont start and i cant flash it completely im doing it with package option and i saw thath you say it can be fixed flashing all parts but when i extract the tar file the parts dont have the md5 extension so the prog does not sees them when i trie to load the amss for example what can i do?? |
you do not have to extract the tar file!!!! you have to find for example a rar/zip file like i did and extract that. In my case i used i5500XWJG3_XWJJ6_SERJJ2.zip which contained the ops file and 4 .tar.md5 files. That is EUROPA_v1.0.ops GT-I5500-CSC-SERJJ2.tar.md5 I5500XWJG1_BOOTLOADER.tar.md5 I5500XWJG3_amss_phone_CL462398.tar.md5 I5500XWJJ6_PDA_CL650697.tar.md5 |
download odin flasher v4.28 download firmware from z3x download ops file put phone in download mode, hold down volume button centre button and press power on. connect to pc ,open up odin, click on ops button select file, on options click start wait 2-3 minutes, posted;by johnarthur. |
Dear Friends I have same phone Samsung I5500 with same problem and i have also tried 2 t0 4 times flashing with efferent firmware but after flashing its work just for 5 to 10 minuts and after that its comes to the same problem. I think its Hardware problem and i am not sure what i need to do in hardware now but as my knowledge the nand ic corrupted or need to hitup so if any one have solution then i am requesting all of you friends and genius please post here or inform me if you can THANL YOU SO MUCH ALL OF YOU |
