QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
06-17-2008, 19:54 | #21 (permalink) |
Banned Join Date: Jan 2002 Location: Morocco , Tetouan
Member: 8784 Status: Offline Sonork: 100.63512 Thanks Meter: 31 | Hmmm ... seems its working ... I check with X820 : Code: Samsung Rocker v1.06g Loaded 400 models Avaiable COM ports: , COM60, COM61, COM1 Using COM1 port. Sending Request to phone Phone Find - Speed: OK TestMode: OK HW revision: MP 1.700 SW version: X820XXFF2 IMEI: 35930800059967-4 MSL address: R1UA676733 MSL access: TRUE LevelOfLock: be --> Lock Active EConvertError 'e' is not a valid integer value Provider: dea-db Codes: NEW OLD PCK: 03792107 - 83300360 Counter: 38 - 6c NCK: 01666112 - 95723592 Counter: 13 - 00 SCK: 01285297 - 26347694 Counter: 00 - 00 SPCK: 03792139 - 82292744 Counter: 03 - 00 MCK: 01285800 - 28448830 Counter: b1 - 9c #0111*NCK# : reset Network Lock #0121*SCK# : reset Subnet Lock #0133*SPCK# : reset SP Lock #0141*PCK# : reset SIM Lock #0149*MCK# : reset SIM Lock #0151*PCK# : reset Automatic Lock #0199*MCK# : reset Phone Freeze status Lock: *0111*NCK*NCK*MCCMNC# : Network Lock, Save NCK *0111# : Network Lock using MCC+MNC of current SIM Phone reset: OK Closed COM1 port. |
06-21-2008, 08:48 | #25 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | tested and work.. Samsung Rocker v1.06g Loaded 400 models Avaiable COM ports: , COM3, COM1, COM6 ThreadGUI started ThreadProtocol started OS: NT family, Ver:5.1 Boot loader protocol type: passive Memory interface type: 1 Setup loader: D:\GSM\SAMSUNG\SOFT\Samsung roker\data\fsl3.sre Setup loader base addr: 0x00000000 Flash loader: D:\GSM\SAMSUNG\SOFT\Samsung roker\data\fl4.sre Flash loader base addr: 0x30000000 Stack base addr: 0x20000000 Stack buffers: 2 0: 0x20000000 - 0x21ffffff [32 MB (33554432 Bytes)] 1: 0x28000000 - 0x2fffffff [128 MB (134217728 Bytes)] Opened COM6 at 115200 baud PC transfer speeds (COM6): 57600 115200 230400 460800 921600 Loading S-record file (RangeCheck=Off) File: D:\GSM\SAMSUNG\SOFT\Samsung roker\data\fsl3.sre SRE line 181: IGNORING: S70500000000FA There is 1 memory region in the S-record file: 1: 0x00000000 - 0x00000b3f = 2880 Bytes Loading S-record file (RangeCheck=Off) File: D:\GSM\SAMSUNG\SOFT\Samsung roker\data\fl4.sre SRE line 5700: IGNORING: S70530000000CA There is 1 memory region in the S-record file: 1: 0x30000000 - 0x30016427 = 91176 Bytes Loading S-record file (RangeCheck=On) File: H:\Flash files\samsung\e720\E720XEEJ1.s3 SRE line 3547: IGNORING: S70520020000D8 SRE line 3548: IGNORING: S00600004844521B SRE line 34272: IGNORING: S705A002000058 SRE line 34754: IGNORING: S70520010000D9 SRE line 34817: IGNORING: S70520040000D6 SRE line 897027: IGNORING: S705200D80004D SRE line 1575251: IGNORING: S70528000000D2 There are 6 memory regions in the S-record file: 1: 0x20010000 - 0x20011e03 = 7684 Bytes 2: 0x20020000 - 0x2002dd9b = 56732 Bytes 3: 0x20040000 - 0x200403db = 988 Bytes 4: 0x20042000 - 0x200ba02f = 491568 Bytes 5: 0x200d8000 - 0x20e00003 = 13795332 Bytes 6: 0x28000000 - 0x28a594e3 = 10851556 Bytes SendFile=D:\GSM\SAMSUNG\SOFT\Samsung roker\data\fl4.sre, Mode=3 Power on mobile ! TalkToBootLoader (using COM6) Talking to passive bootloader Bootloader V1.1 using UART1 ROM mask ID: 0x00030108 ( ) ID register: 0x00030108 (SC4 ROM) Bootloader type: 6 (0) Max. transfer size: 2048 bytes Adjusted max. transfer size to: 1792 bytes Data to transfer: 2880 bytes in 1 region(s) Send: 0x00000000 - 0x000006ff (=1792) Send: 0x00000700 - 0x00000b3f (=1088) Talking to setup loader Setup loader V1.1 using UART1 Setup loader type: 4 Max. transfer size: 2048 bytes Adjusted max. transfer size to: 1792 bytes Data to transfer: 91176 bytes in 1 region(s) Send: 0x30000000 - 0x300006ff (=1792) Send: 0x30000700 - 0x30000dff (=1792) Send: 0x30000e00 - 0x300014ff (=1792) Send: 0x30001500 - 0x30001bff (=1792) Send: 0x30001c00 - 0x300022ff (=1792) Send: 0x30002300 - 0x300029ff (=1792) Send: 0x30002a00 - 0x300030ff (=1792) Send: 0x30003100 - 0x300037ff (=1792) Send: 0x30003800 - 0x30003eff (=1792) Send: 0x30003f00 - 0x300045ff (=1792) Send: 0x30004600 - 0x30004cff (=1792) Send: 0x30004d00 - 0x300053ff (=1792) Send: 0x30005400 - 0x30005aff (=1792) Send: 0x30005b00 - 0x300061ff (=1792) Send: 0x30006200 - 0x300068ff (=1792) Send: 0x30006900 - 0x30006fff (=1792) Send: 0x30007000 - 0x300076ff (=1792) Send: 0x30007700 - 0x30007dff (=1792) Send: 0x30007e00 - 0x300084ff (=1792) Send: 0x30008500 - 0x30008bff (=1792) Send: 0x30008c00 - 0x300092ff (=1792) Send: 0x30009300 - 0x300099ff (=1792) Send: 0x30009a00 - 0x3000a0ff (=1792) Send: 0x3000a100 - 0x3000a7ff (=1792) Send: 0x3000a800 - 0x3000aeff (=1792) Send: 0x3000af00 - 0x3000b5ff (=1792) Send: 0x3000b600 - 0x3000bcff (=1792) Send: 0x3000bd00 - 0x3000c3ff (=1792) Send: 0x3000c400 - 0x3000caff (=1792) Send: 0x3000cb00 - 0x3000d1ff (=1792) Send: 0x3000d200 - 0x3000d8ff (=1792) Send: 0x3000d900 - 0x3000dfff (=1792) Send: 0x3000e000 - 0x3000e6ff (=1792) Send: 0x3000e700 - 0x3000edff (=1792) Send: 0x3000ee00 - 0x3000f4ff (=1792) Send: 0x3000f500 - 0x3000fbff (=1792) Send: 0x3000fc00 - 0x300102ff (=1792) Send: 0x30010300 - 0x300109ff (=1792) Send: 0x30010a00 - 0x300110ff (=1792) Send: 0x30011100 - 0x300117ff (=1792) Send: 0x30011800 - 0x30011eff (=1792) Send: 0x30011f00 - 0x300125ff (=1792) Send: 0x30012600 - 0x30012cff (=1792) Send: 0x30012d00 - 0x300133ff (=1792) Send: 0x30013400 - 0x30013aff (=1792) Send: 0x30013b00 - 0x300141ff (=1792) Send: 0x30014200 - 0x300148ff (=1792) Send: 0x30014900 - 0x30014fff (=1792) Send: 0x30015000 - 0x300156ff (=1792) Send: 0x30015700 - 0x30015dff (=1792) Send: 0x30015e00 - 0x30016427 (=1576) TalkToBootloader: OK Duration: 19s SendFile=H:\Flash files\samsung\e720\E720XEEJ1.s3, Mode=0 TalkToFlashloader (using COM6) Switching over to flash loader COM6 is connected to UART1 Sync'ing to flash loader Sync'ing sync'ed Querying device information dwTxSize : 36 MSG: NAND initialize SUCCESS Flash loader version: V5.13 Max. TX/RX size: 65536/32768 Mobile transfer speeds: 115200, 230400, 460800 IDs returned by detection: 2 AMD:0xec/0x22fd0000, Intel:0x1c/0x02010000, NAND:0xec/0x003c0000 AMD:0x58/0x31520000, Intel:0x58/0x31520000, NAND:0xec/0x003c0000 Detected flash chips: 2 0xec/0x22fd0000: KBJ17KC00M (32 MB (33554432 Bytes) in 519 sectors) Write buffer size: 0 0xec/0x003c0000: KBJ1xKC00M (OneNAND 1G) (128 MB (134217728 Bytes) in 1024 sectors) Write buffer size: 0 Total flash memory: 160 MB (167772160 Bytes) in 1543 sectors on 2 chips COM6: changing baud rate to 460800 COM6: baud rate set to 460800 Sync'ing sync'ed Port info: Logical port 0: COM6 <-> UART1 at 460800 baud (~100%) TalkToFlashloader: OK There are no reserved regions defined Data to be transferred: 24 MB (25203860 Bytes) Setup Sector: 0/8 OpenSector: 0/8, 0x20010000, 65536, 0x13 SendData: 0x20010000 - 0x20011e03 CloseSector: 0/8 Sector: 0/9 OpenSector: 0/9, 0x20020000, 65536, 0x13 SendData: 0x20020000 - 0x2002dd9b CloseSector: 0/9 Sector: 0/11 OpenSector: 0/11, 0x20040000, 65536, 0x13 SendData: 0x20040000 - 0x200403db SendData: 0x20042000 - 0x2004ffff CloseSector: 0/11 Sector: 0/12 OpenSector: 0/12, 0x20050000, 65536, 0x11 SendData: 0x20050000 - 0x2005ffff CloseSector: 0/12 Sector: 0/13 OpenSector: 0/13, 0x20060000, 65536, 0x11 SendData: 0x20060000 - 0x2006ffff CloseSector: 0/13 Sector: 0/14 OpenSector: 0/14, 0x20070000, 65536, 0x11 SendData: 0x20070000 - 0x2007ffff CloseSector: 0/14 Sector: 0/15 OpenSector: 0/15, 0x20080000, 65536, 0x11 SendData: 0x20080000 - 0x2008ffff CloseSector: 0/15 Sector: 0/16 OpenSector: 0/16, 0x20090000, 65536, 0x11 SendData: 0x20090000 - 0x2009ffff CloseSector: 0/16 Sector: 0/17 OpenSector: 0/17, 0x200a0000, 65536, 0x11 SendData: 0x200a0000 - 0x200affff CloseSector: 0/17 Sector: 0/18 OpenSector: 0/18, 0x200b0000, 65536, 0x13 SendData: 0x200b0000 - 0x200ba02f CloseSector: 0/18 Sector: 0/20 OpenSector: 0/20, 0x200d0000, 65536, 0x13 SendData: 0x200d8000 - 0x200dffff CloseSector: 0/20 Sector: 0/21 OpenSector: 0/21, 0x200e0000, 65536, 0x11 SendData: 0x200e0000 - 0x200effff CloseSector: 0/21 Sector: 0/22 OpenSector: 0/22, 0x200f0000, 65536, 0x11 SendData: 0x200f0000 - 0x200fffff CloseSector: 0/22 Sector: 0/23 OpenSector: 0/23, 0x20100000, 65536, 0x11 SendData: 0x20100000 - 0x2010ffff CloseSector: 0/23 Sector: 0/24 OpenSector: 0/24, 0x20110000, 65536, 0x11 SendData: 0x20110000 - 0x2011ffff CloseSector: 0/24 Sector: 0/25 OpenSector: 0/25, 0x20120000, 65536, 0x11 SendData: 0x20120000 - 0x2012ffff CloseSector: 0/25 Sector: 0/26 OpenSector: 0/26, 0x20130000, 65536, 0x11 SendData: 0x20130000 - 0x2013ffff CloseSector: 0/26 Sector: 0/27 OpenSector: 0/27, 0x20140000, 65536, 0x11 SendData: 0x20140000 - 0x2014ffff CloseSector: 0/27 Sector: 0/28 OpenSector: 0/28, 0x20150000, 65536, 0x11 SendData: 0x20150000 - 0x2015ffff CloseSector: 0/28 Sector: 0/29 OpenSector: 0/29, 0x20160000, 65536, 0x11 SendData: 0x20160000 - 0x2016ffff CloseSector: 0/29 Sector: 0/30 OpenSector: 0/30, 0x20170000, 65536, 0x11 SendData: 0x20170000 - 0x2017ffff CloseSector: 0/30 Sector: 0/31 OpenSector: 0/31, 0x20180000, 65536, 0x11 SendData: 0x20180000 - 0x2018ffff CloseSector: 0/31 Sector: 0/32 OpenSector: 0/32, 0x20190000, 65536, 0x11 SendData: 0x20190000 - 0x2019ffff CloseSector: 0/32 Sector: 0/33 OpenSector: 0/33, 0x201a0000, 65536, 0x11 SendData: 0x201a0000 - 0x201affff CloseSector: 0/33 Sector: 0/34 OpenSector: 0/34, 0x201b0000, 65536, 0x11 SendData: 0x201b0000 - 0x201bffff CloseSector: 0/34 Sector: 0/35 OpenSector: 0/35, 0x201c0000, 65536, 0x11 SendData: 0x201c0000 - 0x201cffff CloseSector: 0/35 Sector: 0/36 OpenSector: 0/36, 0x201d0000, 65536, 0x11 SendData: 0x201d0000 - 0x201dffff CloseSector: 0/36 Sector: 0/37 OpenSector: 0/37, 0x201e0000, 65536, 0x11 SendData: 0x201e0000 - 0x201effff CloseSector: 0/37 Sector: 0/38 OpenSector: 0/38, 0x201f0000, 65536, 0x11 SendData: 0x201f0000 - 0x201fffff CloseSector: 0/38 Sector: 0/39 OpenSector: 0/39, 0x20200000, 65536, 0x11 SendData: 0x20200000 - 0x2020ffff CloseSector: 0/39 Sector: 0/40 OpenSector: 0/40, 0x20210000, 65536, 0x11 SendData: 0x20210000 - 0x2021ffff CloseSector: 0/40 Sector: 0/41 OpenSector: 0/41, 0x20220000, 65536, 0x11 SendData: 0x20220000 - 0x2022ffff CloseSector: 0/41 Sector: 0/42 OpenSector: 0/42, 0x20230000, 65536, 0x11 SendData: 0x20230000 - 0x2023ffff CloseSector: 0/42 Sector: 0/43 OpenSector: 0/43, 0x20240000, 65536, 0x11 SendData: 0x20240000 - 0x2024ffff CloseSector: 0/43 Sector: 0/44 OpenSector: 0/44, 0x20250000, 65536, 0x11 SendData: 0x20250000 - 0x2025ffff CloseSector: 0/44 Sector: 0/45 OpenSector: 0/45, 0x20260000, 65536, 0x11 SendData: 0x20260000 - 0x2026ffff CloseSector: 0/45 Sector: 0/46 OpenSector: 0/46, 0x20270000, 65536, 0x11 SendData: 0x20270000 - 0x2027ffff CloseSector: 0/46 Sector: 0/47 OpenSector: 0/47, 0x20280000, 65536, 0x11 SendData: 0x20280000 - 0x2028ffff CloseSector: 0/47 Sector: 0/48 OpenSector: 0/48, 0x20290000, 65536, 0x11 SendData: 0x20290000 - 0x2029ffff CloseSector: 0/48 Sector: 0/49 OpenSector: 0/49, 0x202a0000, 65536, 0x11 SendData: 0x202a0000 - 0x202affff CloseSector: 0/49 Sector: 0/50 OpenSector: 0/50, 0x202b0000, 65536, 0x11 SendData: 0x202b0000 - 0x202bffff CloseSector: 0/50 Sector: 0/51 OpenSector: 0/51, 0x202c0000, 65536, 0x11 SendData: 0x202c0000 - 0x202cffff CloseSector: 0/51 Sector: 0/52 OpenSector: 0/52, 0x202d0000, 65536, 0x11 SendData: 0x202d0000 - 0x202dffff CloseSector: 0/52 Sector: 0/53 OpenSector: 0/53, 0x202e0000, 65536, 0x11 SendData: 0x202e0000 - 0x202effff CloseSector: 0/53 Sector: 0/54 OpenSector: 0/54, 0x202f0000, 65536, 0x11 SendData: 0x202f0000 - 0x202fffff CloseSector: 0/54 Sector: 0/55 OpenSector: 0/55, 0x20300000, 65536, 0x11 SendData: 0x20300000 - 0x2030ffff CloseSector: 0/55 Sector: 0/56 OpenSector: 0/56, 0x20310000, 65536, 0x11 SendData: 0x20310000 - 0x2031ffff CloseSector: 0/56 Sector: 0/57 OpenSector: 0/57, 0x20320000, 65536, 0x11 SendData: 0x20320000 - 0x2032ffff CloseSector: 0/57 Sector: 0/58 OpenSector: 0/58, 0x20330000, 65536, 0x11 SendData: 0x20330000 - 0x2033ffff CloseSector: 0/58 Sector: 0/59 OpenSector: 0/59, 0x20340000, 65536, 0x11 SendData: 0x20340000 - 0x2034ffff CloseSector: 0/59 Sector: 0/60 OpenSector: 0/60, 0x20350000, 65536, 0x11 SendData: 0x20350000 - 0x2035ffff CloseSector: 0/60 Sector: 0/61 OpenSector: 0/61, 0x20360000, 65536, 0x11 SendData: 0x20360000 - 0x2036ffff CloseSector: 0/61 Sector: 0/62 OpenSector: 0/62, 0x20370000, 65536, 0x11 SendData: 0x20370000 - 0x2037ffff CloseSector: 0/62 Sector: 0/63 OpenSector: 0/63, 0x20380000, 65536, 0x11 SendData: 0x20380000 - 0x2038ffff CloseSector: 0/63 Sector: 0/64 OpenSector: 0/64, 0x20390000, 65536, 0x11 SendData: 0x20390000 - 0x2039ffff CloseSector: 0/64 Sector: 0/65 OpenSector: 0/65, 0x203a0000, 65536, 0x11 SendData: 0x203a0000 - 0x203affff CloseSector: 0/65 Sector: 0/66 OpenSector: 0/66, 0x203b0000, 65536, 0x11 SendData: 0x203b0000 - 0x203bffff CloseSector: 0/66 Sector: 0/67 OpenSector: 0/67, 0x203c0000, 65536, 0x11 SendData: 0x203c0000 - 0x203cffff CloseSector: 0/67 Sector: 0/68 OpenSector: 0/68, 0x203d0000, 65536, 0x11 SendData: 0x203d0000 - 0x203dffff CloseSector: 0/68 Sector: 0/69 OpenSector: 0/69, 0x203e0000, 65536, 0x11 SendData: 0x203e0000 - 0x203effff CloseSector: 0/69 Sector: 0/70 OpenSector: 0/70, 0x203f0000, 65536, 0x11 SendData: 0x203f0000 - 0x203fffff CloseSector: 0/70 Sector: 0/71 OpenSector: 0/71, 0x20400000, 65536, 0x11 SendData: 0x20400000 - 0x2040ffff CloseSector: 0/71 Sector: 0/72 OpenSector: 0/72, 0x20410000, 65536, 0x11 SendData: 0x20410000 - 0x2041ffff CloseSector: 0/72 Sector: 0/73 OpenSector: 0/73, 0x20420000, 65536, 0x11 SendData: 0x20420000 - 0x2042ffff CloseSector: 0/73 Sector: 0/74 OpenSector: 0/74, 0x20430000, 65536, 0x11 SendData: 0x20430000 - 0x2043ffff CloseSector: 0/74 Sector: 0/75 OpenSector: 0/75, 0x20440000, 65536, 0x11 SendData: 0x20440000 - 0x2044ffff CloseSector: 0/75 Sector: 0/76 OpenSector: 0/76, 0x20450000, 65536, 0x11 SendData: 0x20450000 - 0x2045ffff CloseSector: 0/76 Sector: 0/77 OpenSector: 0/77, 0x20460000, 65536, 0x11 SendData: 0x20460000 - 0x2046ffff CloseSector: 0/77 Sector: 0/78 OpenSector: 0/78, 0x20470000, 65536, 0x11 SendData: 0x20470000 - 0x2047ffff CloseSector: 0/78 Sector: 0/79 OpenSector: 0/79, 0x20480000, 65536, 0x11 SendData: 0x20480000 - 0x2048ffff CloseSector: 0/79 Sector: 0/80 OpenSector: 0/80, 0x20490000, 65536, 0x11 SendData: 0x20490000 - 0x2049ffff CloseSector: 0/80 Sector: 0/81 OpenSector: 0/81, 0x204a0000, 65536, 0x11 SendData: 0x204a0000 - 0x204affff CloseSector: 0/81 Sector: 0/82 OpenSector: 0/82, 0x204b0000, 65536, 0x11 SendData: 0x204b0000 - 0x204bffff CloseSector: 0/82 Sector: 0/83 OpenSector: 0/83, 0x204c0000, 65536, 0x11 SendData: 0x204c0000 - 0x204cffff CloseSector: 0/83 Sector: 0/84 OpenSector: 0/84, 0x204d0000, 65536, 0x11 SendData: 0x204d0000 - 0x204dffff CloseSector: 0/84 Sector: 0/85 OpenSector: 0/85, 0x204e0000, 65536, 0x11 SendData: 0x204e0000 - 0x204effff CloseSector: 0/85 Sector: 0/86 OpenSector: 0/86, 0x204f0000, 65536, 0x11 SendData: 0x204f0000 - 0x204fffff CloseSector: 0/86 Sector: 0/87 OpenSector: 0/87, 0x20500000, 65536, 0x11 SendData: 0x20500000 - 0x2050ffff CloseSector: 0/87 Sector: 0/88 OpenSector: 0/88, 0x20510000, 65536, 0x11 SendData: 0x20510000 - 0x2051ffff CloseSector: 0/88 Sector: 0/89 OpenSector: 0/89, 0x20520000, 65536, 0x11 SendData: 0x20520000 - 0x2052ffff CloseSector: 0/89 Sector: 0/90 OpenSector: 0/90, 0x20530000, 65536, 0x11 SendData: 0x20530000 - 0x2053ffff CloseSector: 0/90 Sector: 0/91 OpenSector: 0/91, 0x20540000, 65536, 0x11 SendData: 0x20540000 - 0x2054ffff CloseSector: 0/91 Sector: 0/92 OpenSector: 0/92, 0x20550000, 65536, 0x11 SendData: 0x20550000 - 0x2055ffff CloseSector: 0/92 Sector: 0/93 OpenSector: 0/93, 0x20560000, 65536, 0x11 SendData: 0x20560000 - 0x2056ffff CloseSector: 0/93 Sector: 0/94 OpenSector: 0/94, 0x20570000, 65536, 0x11 SendData: 0x20570000 - 0x2057ffff CloseSector: 0/94 Sector: 0/95 OpenSector: 0/95, 0x20580000, 65536, 0x11 SendData: 0x20580000 - 0x2058ffff CloseSector: 0/95 Sector: 0/96 OpenSector: 0/96, 0x20590000, 65536, 0x11 SendData: 0x20590000 - 0x2059ffff CloseSector: 0/96 Sector: 0/97 OpenSector: 0/97, 0x205a0000, 65536, 0x11 SendData: 0x205a0000 - 0x205affff CloseSector: 0/97 Sector: 0/98 OpenSector: 0/98, 0x205b0000, 65536, 0x11 SendData: 0x205b0000 - 0x205bffff CloseSector: 0/98 Sector: 0/99 OpenSector: 0/99, 0x205c0000, 65536, 0x11 SendData: 0x205c0000 - 0x205cffff CloseSector: 0/99 Sector: 0/100 OpenSector: 0/100, 0x205d0000, 65536, 0x11 SendData: 0x205d0000 - 0x205dffff CloseSector: 0/100 Sector: 0/101 OpenSector: 0/101, 0x205e0000, 65536, 0x11 SendData: 0x205e0000 - 0x205effff CloseSector: 0/101 Sector: 0/102 OpenSector: 0/102, 0x205f0000, 65536, 0x11 SendData: 0x205f0000 - 0x205fffff CloseSector: 0/102 Sector: 0/103 OpenSector: 0/103, 0x20600000, 65536, 0x11 SendData: 0x20600000 - 0x2060ffff CloseSector: 0/103 Sector: 0/104 OpenSector: 0/104, 0x20610000, 65536, 0x11 SendData: 0x20610000 - 0x2061ffff CloseSector: 0/104 Sector: 0/105 OpenSector: 0/105, 0x20620000, 65536, 0x11 SendData: 0x20620000 - 0x2062ffff CloseSector: 0/105 Sector: 0/106 OpenSector: 0/106, 0x20630000, 65536, 0x11 SendData: 0x20630000 - 0x2063ffff CloseSector: 0/106 Sector: 0/107 OpenSector: 0/107, 0x20640000, 65536, 0x11 SendData: 0x20640000 - 0x2064ffff CloseSector: 0/107 Sector: 0/108 OpenSector: 0/108, 0x20650000, 65536, 0x11 SendData: 0x20650000 - 0x2065ffff CloseSector: 0/108 Sector: 0/109 OpenSector: 0/109, 0x20660000, 65536, 0x11 SendData: 0x20660000 - 0x2066ffff CloseSector: 0/109 Sector: 0/110 OpenSector: 0/110, 0x20670000, 65536, 0x11 SendData: 0x20670000 - 0x2067ffff CloseSector: 0/110 Sector: 0/111 OpenSector: 0/111, 0x20680000, 65536, 0x11 SendData: 0x20680000 - 0x2068ffff CloseSector: 0/111 Sector: 0/112 OpenSector: 0/112, 0x20690000, 65536, 0x11 SendData: 0x20690000 - 0x2069ffff CloseSector: 0/112 Sector: 0/113 OpenSector: 0/113, 0x206a0000, 65536, 0x11 SendData: 0x206a0000 - 0x206affff CloseSector: 0/113 Sector: 0/114 OpenSector: 0/114, 0x206b0000, 65536, 0x11 SendData: 0x206b0000 - 0x206bffff CloseSector: 0/114 Sector: 0/115 OpenSector: 0/115, 0x206c0000, 65536, 0x11 SendData: 0x206c0000 - 0x206cffff CloseSector: 0/115 Sector: 0/116 OpenSector: 0/116, 0x206d0000, 65536, 0x11 SendData: 0x206d0000 - 0x206dffff CloseSector: 0/116 Sector: 0/117 OpenSector: 0/117, 0x206e0000, 65536, 0x11 SendData: 0x206e0000 - 0x206effff CloseSector: 0/117 Sector: 0/118 OpenSector: 0/118, 0x206f0000, 65536, 0x11 SendData: 0x206f0000 - 0x206fffff CloseSector: 0/118 Sector: 0/119 OpenSector: 0/119, 0x20700000, 65536, 0x11 SendData: 0x20700000 - 0x2070ffff CloseSector: 0/119 Sector: 0/120 OpenSector: 0/120, 0x20710000, 65536, 0x11 SendData: 0x20710000 - 0x2071ffff CloseSector: 0/120 Sector: 0/121 OpenSector: 0/121, 0x20720000, 65536, 0x11 SendData: 0x20720000 - 0x2072ffff CloseSector: 0/121 Sector: 0/122 OpenSector: 0/122, 0x20730000, 65536, 0x11 SendData: 0x20730000 - 0x2073ffff CloseSector: 0/122 Sector: 0/123 OpenSector: 0/123, 0x20740000, 65536, 0x11 SendData: 0x20740000 - 0x2074ffff CloseSector: 0/123 Sector: 0/124 OpenSector: 0/124, 0x20750000, 65536, 0x11 SendData: 0x20750000 - 0x2075ffff CloseSector: 0/124 Sector: 0/125 OpenSector: 0/125, 0x20760000, 65536, 0x11 SendData: 0x20760000 - 0x2076ffff CloseSector: 0/125 Sector: 0/126 OpenSector: 0/126, 0x20770000, 65536, 0x11 SendData: 0x20770000 - 0x2077ffff CloseSector: 0/126 Sector: 0/127 OpenSector: 0/127, 0x20780000, 65536, 0x11 SendData: 0x20780000 - 0x2078ffff CloseSector: 0/127 Sector: 0/128 OpenSector: 0/128, 0x20790000, 65536, 0x11 SendData: 0x20790000 - 0x2079ffff CloseSector: 0/128 Sector: 0/129 OpenSector: 0/129, 0x207a0000, 65536, 0x11 SendData: 0x207a0000 - 0x207affff CloseSector: 0/129 Sector: 0/130 OpenSector: 0/130, 0x207b0000, 65536, 0x11 SendData: 0x207b0000 - 0x207bffff CloseSector: 0/130 Sector: 0/131 OpenSector: 0/131, 0x207c0000, 65536, 0x11 SendData: 0x207c0000 - 0x207cffff CloseSector: 0/131 Sector: 0/132 OpenSector: 0/132, 0x207d0000, 65536, 0x11 SendData: 0x207d0000 - 0x207dffff CloseSector: 0/132 Sector: 0/133 OpenSector: 0/133, 0x207e0000, 65536, 0x11 SendData: 0x207e0000 - 0x207effff CloseSector: 0/133 Sector: 0/134 OpenSector: 0/134, 0x207f0000, 65536, 0x11 SendData: 0x207f0000 - 0x207fffff CloseSector: 0/134 Sector: 0/135 OpenSector: 0/135, 0x20800000, 65536, 0x11 SendData: 0x20800000 - 0x2080ffff CloseSector: 0/135 Sector: 0/136 OpenSector: 0/136, 0x20810000, 65536, 0x11 SendData: 0x20810000 - 0x2081ffff CloseSector: 0/136 Sector: 0/137 OpenSector: 0/137, 0x20820000, 65536, 0x11 SendData: 0x20820000 - 0x2082ffff CloseSector: 0/137 Sector: 0/138 OpenSector: 0/138, 0x20830000, 65536, 0x11 SendData: 0x20830000 - 0x2083ffff CloseSector: 0/138 Sector: 0/139 OpenSector: 0/139, 0x20840000, 65536, 0x11 SendData: 0x20840000 - 0x2084ffff CloseSector: 0/139 Sector: 0/140 OpenSector: 0/140, 0x20850000, 65536, 0x11 SendData: 0x20850000 - 0x2085ffff CloseSector: 0/140 Sector: 0/141 OpenSector: 0/141, 0x20860000, 65536, 0x11 SendData: 0x20860000 - 0x2086ffff CloseSector: 0/141 Sector: 0/142 OpenSector: 0/142, 0x20870000, 65536, 0x11 SendData: 0x20870000 - 0x2087ffff CloseSector: 0/142 Sector: 0/143 OpenSector: 0/143, 0x20880000, 65536, 0x11 SendData: 0x20880000 - 0x2088ffff CloseSector: 0/143 Sector: 0/144 OpenSector: 0/144, 0x20890000, 65536, 0x11 SendData: 0x20890000 - 0x2089ffff CloseSector: 0/144 Sector: 0/145 OpenSector: 0/145, 0x208a0000, 65536, 0x11 SendData: 0x208a0000 - 0x208affff CloseSector: 0/145 Sector: 0/146 OpenSector: 0/146, 0x208b0000, 65536, 0x11 SendData: 0x208b0000 - 0x208bffff CloseSector: 0/146 Sector: 0/147 OpenSector: 0/147, 0x208c0000, 65536, 0x11 SendData: 0x208c0000 - 0x208cffff CloseSector: 0/147 Sector: 0/148 OpenSector: 0/148, 0x208d0000, 65536, 0x11 SendData: 0x208d0000 - 0x208dffff CloseSector: 0/148 Sector: 0/149 OpenSector: 0/149, 0x208e0000, 65536, 0x11 SendData: 0x208e0000 - 0x208effff CloseSector: 0/149 Sector: 0/150 OpenSector: 0/150, 0x208f0000, 65536, 0x11 SendData: 0x208f0000 - 0x208fffff CloseSector: 0/150 Sector: 0/151 OpenSector: 0/151, 0x20900000, 65536, 0x11 SendData: 0x20900000 - 0x2090ffff CloseSector: 0/151 Sector: 0/152 OpenSector: 0/152, 0x20910000, 65536, 0x11 SendData: 0x20910000 - 0x2091ffff CloseSector: 0/152 Sector: 0/153 OpenSector: 0/153, 0x20920000, 65536, 0x11 SendData: 0x20920000 - 0x2092ffff CloseSector: 0/153 Sector: 0/154 OpenSector: 0/154, 0x20930000, 65536, 0x11 SendData: 0x20930000 - 0x2093ffff CloseSector: 0/154 Sector: 0/155 OpenSector: 0/155, 0x20940000, 65536, 0x11 SendData: 0x20940000 - 0x2094ffff CloseSector: 0/155 Sector: 0/156 OpenSector: 0/156, 0x20950000, 65536, 0x11 SendData: 0x20950000 - 0x2095ffff CloseSector: 0/156 Sector: 0/157 OpenSector: 0/157, 0x20960000, 65536, 0x11 SendData: 0x20960000 - 0x2096ffff CloseSector: 0/157 Sector: 0/158 OpenSector: 0/158, 0x20970000, 65536, 0x11 SendData: 0x20970000 - 0x2097ffff CloseSector: 0/158 Sector: 0/159 OpenSector: 0/159, 0x20980000, 65536, 0x11 SendData: 0x20980000 - 0x2098ffff CloseSector: 0/159 Sector: 0/160 OpenSector: 0/160, 0x20990000, 65536, 0x11 SendData: 0x20990000 - 0x2099ffff CloseSector: 0/160 Sector: 0/161 OpenSector: 0/161, 0x209a0000, 65536, 0x11 SendData: 0x209a0000 - 0x209affff CloseSector: 0/161 Sector: 0/162 OpenSector: 0/162, 0x209b0000, 65536, 0x11 SendData: 0x209b0000 - 0x209bffff CloseSector: 0/162 Sector: 0/163 OpenSector: 0/163, 0x209c0000, 65536, 0x11 SendData: 0x209c0000 - 0x209cffff CloseSector: 0/163 Sector: 0/164 OpenSector: 0/164, 0x209d0000, 65536, 0x11 SendData: 0x209d0000 - 0x209dffff CloseSector: 0/164 Sector: 0/165 OpenSector: 0/165, 0x209e0000, 65536, 0x11 SendData: 0x209e0000 - 0x209effff CloseSector: 0/165 Sector: 0/166 OpenSector: 0/166, 0x209f0000, 65536, 0x11 SendData: 0x209f0000 - 0x209fffff CloseSector: 0/166 Sector: 0/167 OpenSector: 0/167, 0x20a00000, 65536, 0x11 SendData: 0x20a00000 - 0x20a0ffff CloseSector: 0/167 Sector: 0/168 OpenSector: 0/168, 0x20a10000, 65536, 0x11 SendData: 0x20a10000 - 0x20a1ffff CloseSector: 0/168 Sector: 0/169 OpenSector: 0/169, 0x20a20000, 65536, 0x11 SendData: 0x20a20000 - 0x20a2ffff CloseSector: 0/169 Sector: 0/170 OpenSector: 0/170, 0x20a30000, 65536, 0x11 SendData: 0x20a30000 - 0x20a3ffff CloseSector: 0/170 Sector: 0/171 OpenSector: 0/171, 0x20a40000, 65536, 0x11 SendData: 0x20a40000 - 0x20a4ffff CloseSector: 0/171 Sector: 0/172 OpenSector: 0/172, 0x20a50000, 65536, 0x11 SendData: 0x20a50000 - 0x20a5ffff CloseSector: 0/172 Sector: 0/173 OpenSector: 0/173, 0x20a60000, 65536, 0x11 SendData: 0x20a60000 - 0x20a6ffff CloseSector: 0/173 Sector: 0/174 OpenSector: 0/174, 0x20a70000, 65536, 0x11 SendData: 0x20a70000 - 0x20a7ffff CloseSector: 0/174 Sector: 0/175 OpenSector: 0/175, 0x20a80000, 65536, 0x11 SendData: 0x20a80000 - 0x20a8ffff CloseSector: 0/175 Sector: 0/176 OpenSector: 0/176, 0x20a90000, 65536, 0x11 SendData: 0x20a90000 - 0x20a9ffff CloseSector: 0/176 Sector: 0/177 OpenSector: 0/177, 0x20aa0000, 65536, 0x11 SendData: 0x20aa0000 - 0x20aaffff CloseSector: 0/177 Sector: 0/178 OpenSector: 0/178, 0x20ab0000, 65536, 0x11 SendData: 0x20ab0000 - 0x20abffff CloseSector: 0/178 Sector: 0/179 OpenSector: 0/179, 0x20ac0000, 65536, 0x11 SendData: 0x20ac0000 - 0x20acffff CloseSector: 0/179 Sector: 0/180 OpenSector: 0/180, 0x20ad0000, 65536, 0x11 SendData: 0x20ad0000 - 0x20adffff CloseSector: 0/180 Sector: 0/181 OpenSector: 0/181, 0x20ae0000, 65536, 0x11 SendData: 0x20ae0000 - 0x20aeffff CloseSector: 0/181 Sector: 0/182 OpenSector: 0/182, 0x20af0000, 65536, 0x11 SendData: 0x20af0000 - 0x20afffff CloseSector: 0/182 Sector: 0/183 OpenSector: 0/183, 0x20b00000, 65536, 0x11 SendData: 0x20b00000 - 0x20b0ffff CloseSector: 0/183 Sector: 0/184 OpenSector: 0/184, 0x20b10000, 65536, 0x11 SendData: 0x20b10000 - 0x20b1ffff CloseSector: 0/184 Sector: 0/185 OpenSector: 0/185, 0x20b20000, 65536, 0x11 SendData: 0x20b20000 - 0x20b2ffff CloseSector: 0/185 Sector: 0/186 OpenSector: 0/186, 0x20b30000, 65536, 0x11 SendData: 0x20b30000 - 0x20b3ffff CloseSector: 0/186 Sector: 0/187 OpenSector: 0/187, 0x20b40000, 65536, 0x11 SendData: 0x20b40000 - 0x20b4ffff CloseSector: 0/187 Sector: 0/188 OpenSector: 0/188, 0x20b50000, 65536, 0x11 SendData: 0x20b50000 - 0x20b5ffff CloseSector: 0/188 Sector: 0/189 OpenSector: 0/189, 0x20b60000, 65536, 0x11 SendData: 0x20b60000 - 0x20b6ffff CloseSector: 0/189 Sector: 0/190 OpenSector: 0/190, 0x20b70000, 65536, 0x11 SendData: 0x20b70000 - 0x20b7ffff CloseSector: 0/190 Sector: 0/191 OpenSector: 0/191, 0x20b80000, 65536, 0x11 SendData: 0x20b80000 - 0x20b8ffff CloseSector: 0/191 Sector: 0/192 OpenSector: 0/192, 0x20b90000, 65536, 0x11 SendData: 0x20b90000 - 0x20b9ffff CloseSector: 0/192 Sector: 0/193 OpenSector: 0/193, 0x20ba0000, 65536, 0x11 SendData: 0x20ba0000 - 0x20baffff CloseSector: 0/193 Sector: 0/194 OpenSector: 0/194, 0x20bb0000, 65536, 0x11 SendData: 0x20bb0000 - 0x20bbffff CloseSector: 0/194 Sector: 0/195 OpenSector: 0/195, 0x20bc0000, 65536, 0x11 SendData: 0x20bc0000 - 0x20bcffff CloseSector: 0/195 Sector: 0/196 OpenSector: 0/196, 0x20bd0000, 65536, 0x11 SendData: 0x20bd0000 - 0x20bdffff CloseSector: 0/196 Sector: 0/197 OpenSector: 0/197, 0x20be0000, 65536, 0x11 SendData: 0x20be0000 - 0x20beffff CloseSector: 0/197 Sector: 0/198 OpenSector: 0/198, 0x20bf0000, 65536, 0x11 SendData: 0x20bf0000 - 0x20bfffff CloseSector: 0/198 Sector: 0/199 OpenSector: 0/199, 0x20c00000, 65536, 0x11 SendData: 0x20c00000 - 0x20c0ffff CloseSector: 0/199 Sector: 0/200 OpenSector: 0/200, 0x20c10000, 65536, 0x11 SendData: 0x20c10000 - 0x20c1ffff CloseSector: 0/200 Sector: 0/201 OpenSector: 0/201, 0x20c20000, 65536, 0x11 SendData: 0x20c20000 - 0x20c2ffff CloseSector: 0/201 Sector: 0/202 OpenSector: 0/202, 0x20c30000, 65536, 0x11 SendData: 0x20c30000 - 0x20c3ffff CloseSector: 0/202 Sector: 0/203 OpenSector: 0/203, 0x20c40000, 65536, 0x11 SendData: 0x20c40000 - 0x20c4ffff CloseSector: 0/203 Sector: 0/204 OpenSector: 0/204, 0x20c50000, 65536, 0x11 SendData: 0x20c50000 - 0x20c5ffff CloseSector: 0/204 Sector: 0/205 OpenSector: 0/205, 0x20c60000, 65536, 0x11 SendData: 0x20c60000 - 0x20c6ffff CloseSector: 0/205 Sector: 0/206 OpenSector: 0/206, 0x20c70000, 65536, 0x11 SendData: 0x20c70000 - 0x20c7ffff CloseSector: 0/206 Sector: 0/207 OpenSector: 0/207, 0x20c80000, 65536, 0x11 SendData: 0x20c80000 - 0x20c8ffff CloseSector: 0/207 Sector: 0/208 OpenSector: 0/208, 0x20c90000, 65536, 0x11 SendData: 0x20c90000 - 0x20c9ffff CloseSector: 0/208 Sector: 0/209 OpenSector: 0/209, 0x20ca0000, 65536, 0x11 SendData: 0x20ca0000 - 0x20caffff CloseSector: 0/209 Sector: 0/210 OpenSector: 0/210, 0x20cb0000, 65536, 0x11 SendData: 0x20cb0000 - 0x20cbffff CloseSector: 0/210 Sector: 0/211 OpenSector: 0/211, 0x20cc0000, 65536, 0x11 SendData: 0x20cc0000 - 0x20ccffff CloseSector: 0/211 Sector: 0/212 OpenSector: 0/212, 0x20cd0000, 65536, 0x11 SendData: 0x20cd0000 - 0x20cdffff CloseSector: 0/212 Sector: 0/213 OpenSector: 0/213, 0x20ce0000, 65536, 0x11 SendData: 0x20ce0000 - 0x20ceffff CloseSector: 0/213 Sector: 0/214 OpenSector: 0/214, 0x20cf0000, 65536, 0x11 SendData: 0x20cf0000 - 0x20cfffff CloseSector: 0/214 Sector: 0/215 OpenSector: 0/215, 0x20d00000, 65536, 0x11 SendData: 0x20d00000 - 0x20d0ffff CloseSector: 0/215 Sector: 0/216 OpenSector: 0/216, 0x20d10000, 65536, 0x11 SendData: 0x20d10000 - 0x20d1ffff CloseSector: 0/216 Sector: 0/217 OpenSector: 0/217, 0x20d20000, 65536, 0x11 SendData: 0x20d20000 - 0x20d2ffff CloseSector: 0/217 Sector: 0/218 OpenSector: 0/218, 0x20d30000, 65536, 0x11 SendData: 0x20d30000 - 0x20d3ffff CloseSector: 0/218 Sector: 0/219 OpenSector: 0/219, 0x20d40000, 65536, 0x11 SendData: 0x20d40000 - 0x20d4ffff CloseSector: 0/219 Sector: 0/220 OpenSector: 0/220, 0x20d50000, 65536, 0x11 SendData: 0x20d50000 - 0x20d5ffff CloseSector: 0/220 Sector: 0/221 OpenSector: 0/221, 0x20d60000, 65536, 0x11 SendData: 0x20d60000 - 0x20d6ffff CloseSector: 0/221 Sector: 0/222 OpenSector: 0/222, 0x20d70000, 65536, 0x11 SendData: 0x20d70000 - 0x20d7ffff CloseSector: 0/222 Sector: 0/223 OpenSector: 0/223, 0x20d80000, 65536, 0x11 SendData: 0x20d80000 - 0x20d8ffff CloseSector: 0/223 Sector: 0/224 OpenSector: 0/224, 0x20d90000, 65536, 0x11 SendData: 0x20d90000 - 0x20d9ffff CloseSector: 0/224 Sector: 0/225 OpenSector: 0/225, 0x20da0000, 65536, 0x11 SendData: 0x20da0000 - 0x20daffff CloseSector: 0/225 Sector: 0/226 OpenSector: 0/226, 0x20db0000, 65536, 0x11 SendData: 0x20db0000 - 0x20dbffff CloseSector: 0/226 Sector: 0/227 OpenSector: 0/227, 0x20dc0000, 65536, 0x11 SendData: 0x20dc0000 - 0x20dcffff CloseSector: 0/227 Sector: 0/228 OpenSector: 0/228, 0x20dd0000, 65536, 0x11 SendData: 0x20dd0000 - 0x20ddffff CloseSector: 0/228 Sector: 0/229 OpenSector: 0/229, 0x20de0000, 65536, 0x11 SendData: 0x20de0000 - 0x20deffff CloseSector: 0/229 Sector: 0/230 OpenSector: 0/230, 0x20df0000, 65536, 0x11 SendData: 0x20df0000 - 0x20dfffff CloseSector: 0/230 Sector: 0/231 OpenSector: 0/231, 0x20e00000, 65536, 0x13 SendData: 0x20e00000 - 0x20e00003 CloseSector: 0/231 Sector: 1/0 OpenSector: 1/0, 0x28000000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x0 SendData: 0x28000000 - 0x2800ffff SendData: 0x28010000 - 0x2801ffff CloseSector: 1/0 Sector: 1/1 OpenSector: 1/1, 0x28020000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1 SendData: 0x28020000 - 0x2802ffff SendData: 0x28030000 - 0x2803ffff CloseSector: 1/1 Sector: 1/2 OpenSector: 1/2, 0x28040000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2 SendData: 0x28040000 - 0x2804ffff SendData: 0x28050000 - 0x2805ffff CloseSector: 1/2 Sector: 1/3 OpenSector: 1/3, 0x28060000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3 SendData: 0x28060000 - 0x2806ffff SendData: 0x28070000 - 0x2807ffff CloseSector: 1/3 Sector: 1/4 OpenSector: 1/4, 0x28080000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4 SendData: 0x28080000 - 0x2808ffff SendData: 0x28090000 - 0x2809ffff CloseSector: 1/4 Sector: 1/5 OpenSector: 1/5, 0x280a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x5 SendData: 0x280a0000 - 0x280affff SendData: 0x280b0000 - 0x280bffff CloseSector: 1/5 Sector: 1/6 OpenSector: 1/6, 0x280c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x6 SendData: 0x280c0000 - 0x280cffff SendData: 0x280d0000 - 0x280dffff CloseSector: 1/6 Sector: 1/7 OpenSector: 1/7, 0x280e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x7 SendData: 0x280e0000 - 0x280effff SendData: 0x280f0000 - 0x280fffff CloseSector: 1/7 Sector: 1/8 OpenSector: 1/8, 0x28100000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x8 SendData: 0x28100000 - 0x2810ffff SendData: 0x28110000 - 0x2811ffff CloseSector: 1/8 Sector: 1/9 OpenSector: 1/9, 0x28120000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x9 SendData: 0x28120000 - 0x2812ffff SendData: 0x28130000 - 0x2813ffff CloseSector: 1/9 Sector: 1/10 OpenSector: 1/10, 0x28140000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0xa SendData: 0x28140000 - 0x2814ffff SendData: 0x28150000 - 0x2815ffff CloseSector: 1/10 Sector: 1/11 OpenSector: 1/11, 0x28160000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0xb SendData: 0x28160000 - 0x2816ffff SendData: 0x28170000 - 0x2817ffff CloseSector: 1/11 Sector: 1/12 OpenSector: 1/12, 0x28180000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0xc SendData: 0x28180000 - 0x2818ffff SendData: 0x28190000 - 0x2819ffff CloseSector: 1/12 Sector: 1/13 OpenSector: 1/13, 0x281a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0xd SendData: 0x281a0000 - 0x281affff SendData: 0x281b0000 - 0x281bffff CloseSector: 1/13 Sector: 1/14 OpenSector: 1/14, 0x281c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0xe SendData: 0x281c0000 - 0x281cffff SendData: 0x281d0000 - 0x281dffff CloseSector: 1/14 Sector: 1/15 OpenSector: 1/15, 0x281e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0xf SendData: 0x281e0000 - 0x281effff SendData: 0x281f0000 - 0x281fffff CloseSector: 1/15 Sector: 1/16 OpenSector: 1/16, 0x28200000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x10 SendData: 0x28200000 - 0x2820ffff SendData: 0x28210000 - 0x2821ffff CloseSector: 1/16 Sector: 1/17 OpenSector: 1/17, 0x28220000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x11 SendData: 0x28220000 - 0x2822ffff SendData: 0x28230000 - 0x2823ffff CloseSector: 1/17 Sector: 1/18 OpenSector: 1/18, 0x28240000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x12 SendData: 0x28240000 - 0x2824ffff SendData: 0x28250000 - 0x2825ffff CloseSector: 1/18 Sector: 1/19 OpenSector: 1/19, 0x28260000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x13 SendData: 0x28260000 - 0x2826ffff SendData: 0x28270000 - 0x2827ffff CloseSector: 1/19 Sector: 1/20 OpenSector: 1/20, 0x28280000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x14 SendData: 0x28280000 - 0x2828ffff SendData: 0x28290000 - 0x2829ffff CloseSector: 1/20 Sector: 1/21 OpenSector: 1/21, 0x282a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x15 SendData: 0x282a0000 - 0x282affff SendData: 0x282b0000 - 0x282bffff CloseSector: 1/21 Sector: 1/22 OpenSector: 1/22, 0x282c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x16 SendData: 0x282c0000 - 0x282cffff SendData: 0x282d0000 - 0x282dffff CloseSector: 1/22 Sector: 1/23 OpenSector: 1/23, 0x282e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x17 SendData: 0x282e0000 - 0x282effff SendData: 0x282f0000 - 0x282fffff CloseSector: 1/23 Sector: 1/24 OpenSector: 1/24, 0x28300000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x18 SendData: 0x28300000 - 0x2830ffff SendData: 0x28310000 - 0x2831ffff CloseSector: 1/24 Sector: 1/25 OpenSector: 1/25, 0x28320000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x19 SendData: 0x28320000 - 0x2832ffff SendData: 0x28330000 - 0x2833ffff CloseSector: 1/25 Sector: 1/26 OpenSector: 1/26, 0x28340000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1a SendData: 0x28340000 - 0x2834ffff SendData: 0x28350000 - 0x2835ffff CloseSector: 1/26 Sector: 1/27 OpenSector: 1/27, 0x28360000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1b SendData: 0x28360000 - 0x2836ffff SendData: 0x28370000 - 0x2837ffff CloseSector: 1/27 Sector: 1/28 OpenSector: 1/28, 0x28380000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1c SendData: 0x28380000 - 0x2838ffff SendData: 0x28390000 - 0x2839ffff CloseSector: 1/28 Sector: 1/29 OpenSector: 1/29, 0x283a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1d SendData: 0x283a0000 - 0x283affff SendData: 0x283b0000 - 0x283bffff CloseSector: 1/29 Sector: 1/30 OpenSector: 1/30, 0x283c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1e SendData: 0x283c0000 - 0x283cffff SendData: 0x283d0000 - 0x283dffff CloseSector: 1/30 Sector: 1/31 OpenSector: 1/31, 0x283e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x1f SendData: 0x283e0000 - 0x283effff SendData: 0x283f0000 - 0x283fffff CloseSector: 1/31 Sector: 1/32 OpenSector: 1/32, 0x28400000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x20 SendData: 0x28400000 - 0x2840ffff SendData: 0x28410000 - 0x2841ffff CloseSector: 1/32 Sector: 1/33 OpenSector: 1/33, 0x28420000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x21 SendData: 0x28420000 - 0x2842ffff SendData: 0x28430000 - 0x2843ffff CloseSector: 1/33 Sector: 1/34 OpenSector: 1/34, 0x28440000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x22 SendData: 0x28440000 - 0x2844ffff SendData: 0x28450000 - 0x2845ffff CloseSector: 1/34 Sector: 1/35 OpenSector: 1/35, 0x28460000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x23 SendData: 0x28460000 - 0x2846ffff SendData: 0x28470000 - 0x2847ffff CloseSector: 1/35 Sector: 1/36 OpenSector: 1/36, 0x28480000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x24 SendData: 0x28480000 - 0x2848ffff SendData: 0x28490000 - 0x2849ffff CloseSector: 1/36 Sector: 1/37 OpenSector: 1/37, 0x284a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x25 SendData: 0x284a0000 - 0x284affff SendData: 0x284b0000 - 0x284bffff CloseSector: 1/37 Sector: 1/38 OpenSector: 1/38, 0x284c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x26 SendData: 0x284c0000 - 0x284cffff SendData: 0x284d0000 - 0x284dffff CloseSector: 1/38 Sector: 1/39 OpenSector: 1/39, 0x284e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x27 SendData: 0x284e0000 - 0x284effff SendData: 0x284f0000 - 0x284fffff CloseSector: 1/39 Sector: 1/40 OpenSector: 1/40, 0x28500000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x28 SendData: 0x28500000 - 0x2850ffff SendData: 0x28510000 - 0x2851ffff CloseSector: 1/40 Sector: 1/41 OpenSector: 1/41, 0x28520000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x29 SendData: 0x28520000 - 0x2852ffff SendData: 0x28530000 - 0x2853ffff CloseSector: 1/41 Sector: 1/42 OpenSector: 1/42, 0x28540000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2a SendData: 0x28540000 - 0x2854ffff SendData: 0x28550000 - 0x2855ffff CloseSector: 1/42 Sector: 1/43 OpenSector: 1/43, 0x28560000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2b SendData: 0x28560000 - 0x2856ffff SendData: 0x28570000 - 0x2857ffff CloseSector: 1/43 Sector: 1/44 OpenSector: 1/44, 0x28580000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2c SendData: 0x28580000 - 0x2858ffff SendData: 0x28590000 - 0x2859ffff CloseSector: 1/44 Sector: 1/45 OpenSector: 1/45, 0x285a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2d SendData: 0x285a0000 - 0x285affff SendData: 0x285b0000 - 0x285bffff CloseSector: 1/45 Sector: 1/46 OpenSector: 1/46, 0x285c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2e SendData: 0x285c0000 - 0x285cffff SendData: 0x285d0000 - 0x285dffff CloseSector: 1/46 Sector: 1/47 OpenSector: 1/47, 0x285e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x2f SendData: 0x285e0000 - 0x285effff SendData: 0x285f0000 - 0x285fffff CloseSector: 1/47 Sector: 1/48 OpenSector: 1/48, 0x28600000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x30 SendData: 0x28600000 - 0x2860ffff SendData: 0x28610000 - 0x2861ffff CloseSector: 1/48 Sector: 1/49 OpenSector: 1/49, 0x28620000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x31 SendData: 0x28620000 - 0x2862ffff SendData: 0x28630000 - 0x2863ffff CloseSector: 1/49 Sector: 1/50 OpenSector: 1/50, 0x28640000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x32 SendData: 0x28640000 - 0x2864ffff SendData: 0x28650000 - 0x2865ffff CloseSector: 1/50 Sector: 1/51 OpenSector: 1/51, 0x28660000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x33 SendData: 0x28660000 - 0x2866ffff SendData: 0x28670000 - 0x2867ffff CloseSector: 1/51 Sector: 1/52 OpenSector: 1/52, 0x28680000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x34 SendData: 0x28680000 - 0x2868ffff SendData: 0x28690000 - 0x2869ffff CloseSector: 1/52 Sector: 1/53 OpenSector: 1/53, 0x286a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x35 SendData: 0x286a0000 - 0x286affff SendData: 0x286b0000 - 0x286bffff CloseSector: 1/53 Sector: 1/54 OpenSector: 1/54, 0x286c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x36 SendData: 0x286c0000 - 0x286cffff SendData: 0x286d0000 - 0x286dffff CloseSector: 1/54 Sector: 1/55 OpenSector: 1/55, 0x286e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x37 SendData: 0x286e0000 - 0x286effff SendData: 0x286f0000 - 0x286fffff CloseSector: 1/55 Sector: 1/56 OpenSector: 1/56, 0x28700000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x38 SendData: 0x28700000 - 0x2870ffff SendData: 0x28710000 - 0x2871ffff CloseSector: 1/56 Sector: 1/57 OpenSector: 1/57, 0x28720000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x39 SendData: 0x28720000 - 0x2872ffff SendData: 0x28730000 - 0x2873ffff CloseSector: 1/57 Sector: 1/58 OpenSector: 1/58, 0x28740000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3a SendData: 0x28740000 - 0x2874ffff SendData: 0x28750000 - 0x2875ffff CloseSector: 1/58 Sector: 1/59 OpenSector: 1/59, 0x28760000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3b SendData: 0x28760000 - 0x2876ffff SendData: 0x28770000 - 0x2877ffff CloseSector: 1/59 Sector: 1/60 OpenSector: 1/60, 0x28780000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3c SendData: 0x28780000 - 0x2878ffff SendData: 0x28790000 - 0x2879ffff CloseSector: 1/60 Sector: 1/61 OpenSector: 1/61, 0x287a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3d SendData: 0x287a0000 - 0x287affff SendData: 0x287b0000 - 0x287bffff CloseSector: 1/61 Sector: 1/62 OpenSector: 1/62, 0x287c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3e SendData: 0x287c0000 - 0x287cffff SendData: 0x287d0000 - 0x287dffff CloseSector: 1/62 Sector: 1/63 OpenSector: 1/63, 0x287e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x3f SendData: 0x287e0000 - 0x287effff SendData: 0x287f0000 - 0x287fffff CloseSector: 1/63 Sector: 1/64 OpenSector: 1/64, 0x28800000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x40 SendData: 0x28800000 - 0x2880ffff SendData: 0x28810000 - 0x2881ffff CloseSector: 1/64 Sector: 1/65 OpenSector: 1/65, 0x28820000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x41 SendData: 0x28820000 - 0x2882ffff SendData: 0x28830000 - 0x2883ffff CloseSector: 1/65 Sector: 1/66 OpenSector: 1/66, 0x28840000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x42 SendData: 0x28840000 - 0x2884ffff SendData: 0x28850000 - 0x2885ffff CloseSector: 1/66 Sector: 1/67 OpenSector: 1/67, 0x28860000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x43 SendData: 0x28860000 - 0x2886ffff SendData: 0x28870000 - 0x2887ffff CloseSector: 1/67 Sector: 1/68 OpenSector: 1/68, 0x28880000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x44 SendData: 0x28880000 - 0x2888ffff SendData: 0x28890000 - 0x2889ffff CloseSector: 1/68 Sector: 1/69 OpenSector: 1/69, 0x288a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x45 SendData: 0x288a0000 - 0x288affff SendData: 0x288b0000 - 0x288bffff CloseSector: 1/69 Sector: 1/70 OpenSector: 1/70, 0x288c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x46 SendData: 0x288c0000 - 0x288cffff SendData: 0x288d0000 - 0x288dffff CloseSector: 1/70 Sector: 1/71 OpenSector: 1/71, 0x288e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x47 SendData: 0x288e0000 - 0x288effff SendData: 0x288f0000 - 0x288fffff CloseSector: 1/71 Sector: 1/72 OpenSector: 1/72, 0x28900000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x48 SendData: 0x28900000 - 0x2890ffff SendData: 0x28910000 - 0x2891ffff CloseSector: 1/72 Sector: 1/73 OpenSector: 1/73, 0x28920000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x49 SendData: 0x28920000 - 0x2892ffff SendData: 0x28930000 - 0x2893ffff CloseSector: 1/73 Sector: 1/74 OpenSector: 1/74, 0x28940000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4a SendData: 0x28940000 - 0x2894ffff SendData: 0x28950000 - 0x2895ffff CloseSector: 1/74 Sector: 1/75 OpenSector: 1/75, 0x28960000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4b SendData: 0x28960000 - 0x2896ffff SendData: 0x28970000 - 0x2897ffff CloseSector: 1/75 Sector: 1/76 OpenSector: 1/76, 0x28980000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4c SendData: 0x28980000 - 0x2898ffff SendData: 0x28990000 - 0x2899ffff CloseSector: 1/76 Sector: 1/77 OpenSector: 1/77, 0x289a0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4d SendData: 0x289a0000 - 0x289affff SendData: 0x289b0000 - 0x289bffff CloseSector: 1/77 Sector: 1/78 OpenSector: 1/78, 0x289c0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4e SendData: 0x289c0000 - 0x289cffff SendData: 0x289d0000 - 0x289dffff CloseSector: 1/78 Sector: 1/79 OpenSector: 1/79, 0x289e0000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x4f SendData: 0x289e0000 - 0x289effff SendData: 0x289f0000 - 0x289fffff CloseSector: 1/79 Sector: 1/80 OpenSector: 1/80, 0x28a00000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x50 SendData: 0x28a00000 - 0x28a0ffff SendData: 0x28a10000 - 0x28a1ffff CloseSector: 1/80 Sector: 1/81 OpenSector: 1/81, 0x28a20000, 131072, 0x11 MSG: EraseSectorNAND : nPbn=0x51 SendData: 0x28a20000 - 0x28a2ffff SendData: 0x28a30000 - 0x28a3ffff CloseSector: 1/81 Sector: 1/82 OpenSector: 1/82, 0x28a40000, 131072, 0x13 MSG: EraseSectorNAND : nPbn=0x52 SendData: 0x28a40000 - 0x28a4ffff SendData: 0x28a50000 - 0x28a594e3 CloseSector: 1/82 Done MSG: BML_Close Success Duration: 14:08 All is well ! ThreadProtocol finished ThreadProtocol: 0 ThreadGUI finished Closed COM6 port. Using COM6 port. Sending Request to phone Phone Find - Speed: OK TestMode: OK HW revision: ******XX SW version: E720XEEJ1 IMEI: 35528700043781-8 Service Functions: CHECKED JAVAReset: OK WAPReset: OK CMPReset: OK MMSReset: OK MediaReset: OK FullSvcReset: OK ServiceReset: OK StackReset: OK CustReset: OK FactoryReset: OK This phone not have MSL lock or MSL data is bad. LevelOfLock: 00 --> Lock not Active Provider: h h- h ReBuild NVM: OK Phone reset: OK Closed COM6 port. |
The Following User Says Thank You to TEHGSM For This Useful Post: |
Samsung Rocker dongle | shahzad00786 | Samsung Flashers, Software, Firmware. | 1 | 12-12-2011 14:41 |
Rocker Dongle (By Legija) IN Stock & activation lg 3g only 99 euro | shadi | Main Sales Section | 0 | 12-29-2008 22:47 |
Samsung Rocker Dongle (LEGIJA) FREE | magixian | Samsung Flashers, Software, Firmware. | 11 | 08-04-2008 20:39 |
can you help me! Rocker Dongle (By Legija) | jiahua | Rocker Dongle (By Legija) | 3 | 05-22-2008 13:13 |
