QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
02-06-2013, 17:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | play with Bootloader - S8500 and S8530 - example Please read carefully. Playing with Bootloaders can brick handset... then JTAG like RIFF Box is mandatory to reanimate... So it is NOT riskfree. 2. For study you need Tools like: Wave_Remaker for Decrypt and Encryption again... ELF files like these are available in many Firmware packages: Code: BL3_univ.elf I have not enough space to upload here... But then modified bootloader.mbn is possible to flash via Multiloader. It was simple Copy and Paste "hack" to remove RSA 1024 Check... I9000/M130K have NO public key in first few KB... 0x0 - 0x9FF Best Regards |
02-06-2013, 17:50 | #2 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | example4modifiedBootS8500andS8530.rar Expect no magic at the moment... AT your OWN risk!! Solution is tested and confirmed. This is simple example by textchange... 1. In DL Mode now Download FREE is visible... 2. Devicename for Multiloader is changed... Anyway. Before it was not possible, because protected by RSA Security Check... of public key and Signatures of boot_loader.mbn Best Regards |
02-07-2013, 14:27 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Location: ranchi jharkhand
Member: 1564275 Status: Offline Sonork: badal ranchi Thanks Meter: 120 | hi i try after write your boot set show downloas free..........i want to install i9000 finwere but how please reply |
The Following User Says Thank You to badal don For This Useful Post: |
02-07-2013, 14:28 | #4 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | S8500 XXLA1 At the moment I am trying to change start address for apps_compressed.bin... Original start is here: Code: 0x01100000 According to this... RC1 partition enough space reserved for DEcompressed apps_c + RC1... 80 MB Code: { S8500v20 | BADA_APPS, 0x04020000, 0x01100000, 0x02000000 }, { S8500v20 | BADA_RSRC1, 0x05020000, 0x05D00000, 0x05A00000 }, { S8500v20 | BADA_RSRCS, 0x05020000, 0x03A00000, 0x02300000 }, Need few more tests, but I think start address is here: Code: 0x00115720 Need more time and brain... Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
02-07-2013, 14:33 | #6 (permalink) | |
Member: 420658 Status: Offline Thanks Meter: 211 | Quote:
Thanx for trying. 2. I9000 Hardware differences TOOO big for 1:1 use... But... 3. There is an Android Porting Project on XDA... check this out: [ROM] [WIP] CM10 "Jelly Bean" v0.1 - xda-developers Best Regards | |
02-07-2013, 14:54 | #8 (permalink) | |
You know Original Firmware before? Like XXLA1 DBT for Europe.... 2. If not, then be sure you have no M210S... 3. You can remove battery and check model name an serial number S/N... With these infos + Samsung Tool Kies you can check Firmware you exact need. Good luck. Best Regards | |
02-10-2013, 08:04 | #9 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | If someone flashed SHW-M210S with S8530 Firmware inclusive BOOTFILES... I found way to flash M210S Boot + Firmware to S8530... It seems really bigger differences... Display for instance... If M210S Boot on S8530... Screen black/grey If S8530 Boot back... Screen visible, but after Lockscreen not awake... Best Regards |
09-05-2013, 06:11 | #10 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | Dear@adfree i have Korean SHW-M210S....it's now Samsung logo mode....i had to tired ur modified boot file + firmware......but still same condition...there have two files in samfirmware server for SHW-M210S... and every time both files csc + shp app file error.....when i had to flash.. so do u have any idea how to successfully flash this set.....? please guide me..... |
09-11-2013, 21:52 | #11 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | KRLC1 contain Bootloader = complete Firmware for M210S. To check why M210S not start... Sometimes hanging Logo could mean NO IMEI... or something else... Anyway. With RC2 file with Debug Level Mid or High it is possible to see Bluescreen with maybe helpfull infos... I have sent PM to you. Best Regards |
