Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > QUALCOMM Models (3G)
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10.
Old 03-08-2008, 21:30   #256 (permalink)
Member: 721559
Hi minorKa - and anyone else!
Like a few who have posted on here, I have a Z400 which I'd love to unlock. (In my case, my wife was given it by a work colleague and it's locked to Orange. Her current SIM card is Virgin. After, er, playing with the Z400, I've now also 'frozen' the SIM...)
I have downloaded your recommended prog, minorKa, but find that the Z400 isn't supported. Do any of the other model options have a close enough compatibility to the Z400 to allow it to be used instead, or am I being just too silly to consider doing that?!?
Anyone know if a Z400 unlocking prog is available or on its way?
Many thanks.
Old 04-19-2008, 08:06   #257 (permalink)
Mang mel's Avatar
Member: 218941
Thanks Meter: 1,801
can any share another link for my Z500V PHONE FREEZED...
Old 04-20-2008, 09:03   #258 (permalink)
Member: 721559
Hi Mang mel.
The process described in the opening post of this thread covers the Z500 model, I believe. It seems to be bona-fide; I downloaded the software and it appeared to run ok, but unfortunately for me the Z400 wasn't supported.
If the Z500 is anything like the Z400, then it CANNOT be unlocked with a simple typing in of a code - believe me I've tried, and only succeeded in freezing my SIM card along with everything else! A more complex process is required, involving software and connecting your phone to a computer. If you don't think you are up to doing this, then take your phone to a professional!
Which is what I ended up doing!!!
So, I can thoroughly recommend ' unlock-my-phone ' who sells on Ebay. They also have a proper website, tho' I forget what it is - it could be similar. I can check if anyone is interested, as it's on a contact email somewhere!
I needed everything doing to my phone after I'd finished with it (!): unlocking, unfreezing the SIM, and debranding. I was quoted £12 by them, but if you follow their link to their website, it's only £10 (I noticed this after I'd paid through Ebay )
It's a postal service, and very fast. Obviously, it also costs you to post it to them, but return is included. If you only require 'unlocking', for example, then it's much less.
I have no connection with them - blah blah - other than having used them once. They were spot on.
(There are some on Ebay who claim they can unlock your Z400s by sending you an unlocking code. I DON'T BELIEVE THEM!!)
Old 12-06-2008, 19:14   #259 (permalink)
Member: 241673
Thanks Meter: 8
Originally Posted by -minorKa- View Post
This is a post to help everyone that has a Samsung Z serie mobile that is locked and/or freezed.
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download: http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=HQ&CttFileID=380589&CDCtt Type=SW&ModelType=N&ModelName=SGH-Z500&VPath=SW/200505/20050526174209031_USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
'…………………………………………... ŻŻŻŻŻ
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
[Note]: To set the COM port, run the QUALCOMM UNLOCKER program and click on "Check Modem", then, in the "Phone and Modem Options" menu, click on the "Modem" tab, select your mobilephone on the modem list and then click proprieties. In the modem proprieties menu, you must click on the "Advanced" tab and then click on "Advanced Port Settings". In the "Advanced Port Settings menu, there should be a dropdown list, in the bottom of the window, to select the desired COM port for your mobile. The port must not have 2 digits - like COM10 or above - and it's not convenient to be set as COM1. Select one of the unused and confirm everything by clicking all "OK" buttons.
Then you'll have your phone completely free of lockings and freezings. I did it with my own Z300 and, after doing it just like I described, it finally worked.
Hope this thread was usefull and enjoy your phones without restrictions.
this tricks not work for me for not detected phone in normal mode
Old 01-08-2009, 11:13   #260 (permalink)
Member: 717001
Thanks Meter: 55
Originally Posted by BMobile View Post
Thanks you very much !
I think you should post pinout, coz Z500 & Z140V have different cable connector.
Another way :
*7465625*28782#
*7465625*28638#
(NOTE: When you change sim to other operator repeat this process to unlock it for that operator also)
hi frend i can't unlock by code z140v can you help me
thank
ros
Old 01-08-2009, 11:47   #261 (permalink)
Member: 717001
Thanks Meter: 55
sir plzz give me driver link
thank
ros
Old 01-11-2009, 12:05   #262 (permalink)
Member: 887227
Thanks Meter: 16
How to unlock Z500? pls share code unlock. thanks all
Old 01-20-2009, 22:35   #263 (permalink)
Member: 951852
i need some help desperately.
when i followed the instructions here.. i found that my imei number had been erased. now i really dunno what to do. please help me. =(
Old 05-04-2010, 14:26   #264 (permalink)
Member: 1272786
hi can someone give me instructions on how to flash sam z400 please...i hav da firmware and multiloader v5.33
Old 05-26-2010, 15:03   #265 (permalink)
Member: 1212347
Thanks Meter: 16
hi guys i got samsung z105 to unlock but not getting any gud solution
if any one have something plz share...
Old 05-29-2010, 10:18   #266 (permalink)
Member: 1313663
Hi, I have one Samsung ZV60
IMEI 354919013576211
operator Vodafone Spain
please send my one unlock code. I want to work in Vodafone Romania, its possible?
Please one code.
Manny Thanks
Old 05-29-2010, 15:44   #267 (permalink)
Crazy Poster
Member: 1103346
Thanks Meter: 9
Thanks so much hihihi ^^
Old 11-27-2010, 19:16   #268 (permalink)
Member: 1453575
Samsung SGH-z150
Hello!
I have some problems with my old Z150: after change of firmware and after some stupid moviments, the phone turns "freeze". But it not is all :-)
Now, on phone start, appears a message of some "error" in boot file and then ask me to press number 0 on keypad. After it appears yellow display with a message "UPLOAD MODE"... What its mean? Some ideas? How I can repair it?
Ou better solution is... forget about this phone?
Tnx
Old 05-03-2013, 17:54   #269 (permalink)
Member: 1903275
Can help me with unfreeze code for my samsung z140 v? IMEI:35675400122930/3. Please help me! I have the unlock code but the phone is freeze
Samsung Qualcomm tool 4.1 release! Direct unlock and repair IMEI all MSL2 phones!!! mk Z3X-Team Products 34 12-26-2008 18:19
please Mr.Elco support unlock and flash for samsung A727 ASAP tsarkh NSPRO 2 06-26-2008 10:20
Free unlocker and flasher for samsung D600 jignesh_1000 Samsung Flashers, Software, Firmware. 20 03-30-2007 08:35
Cruiser doubt... does unlocking and/or changing language erases memory? UnlockBR Cruiser Suite 9 12-29-2004 18:40
Page generated in 0.20056 seconds with 10 queries
