QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
09-26-2006, 19:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Z130 All night was charging .. now dead My friends Z130 was left with connected charger all night long, and in the morning he found it not turning on ... One thing, when I connect charger in phone, charger connector led gets RED ! I cant flash it with MultiDownloader and USB cable, as it cant enter flash mode with pressing 4 + power on (are these correct buttons?) ... I cant use LG7050 COM cable with this multidownloader as it works via USB I guess ! Maybe its hardware problem, or maybe battery is dead (voltage is up to 4 though!), I have no other battery here yet Any ideas ? |
09-27-2006, 21:23 | #3 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | u can try what Pandemonio100 said before for Download mode hold 9 and press power on the Z130 MultiLoader v5.2 work with USB (same Z140-LG3G usb cable) unlock work with COM cable (LG7050) |
09-28-2006, 16:40 | #4 (permalink) |
Member: 75765 Status: Offline Thanks Meter: 722 | Nothing happens after pressing 4+9+power on PC is not detecting anyhing with Z130 usb cable connected with phone ! I dont understand where to connect external supply (5v ?) .. And I dont want to fck up the phone wholly, I am not good in hardware but if you could tell me what to check/remove/short I`ll ask my hardwarer to do when I`m at work Regards, B |
09-28-2006, 18:15 | #5 (permalink) |
Major Poster Join Date: Sep 2006 Location: Milton Keynes Age: 37
Member: 358941 Status: Offline Thanks Meter: 1 | R.E Z130 All night was charging .. now dead : ur best bet is obtain a new charger and battry, if this doesn't work then ur fone's capacitors r ****ed if da fone woz chargd switchd on on standby mode like with a couple of my motorola e1000s they r as ****ed as anything coz they were left on standby mode whist charging, if u do get ur fone fixd, switchoff the fone b4 stickin it on charge m8 |
09-28-2006, 18:42 | #6 (permalink) |
No Life Poster Join Date: Dec 2000 Location: CHANDIGARH - INDIA Age: 59
Member: 2822 Status: Offline Thanks Meter: 152 | @BB-gsm this sometime happens, when you put the phone on charging while you go to sleep, and in next morning you wake-up but phone does not . ie it dies. so now lets come to the point 1. as already said first try with other good charger and battery. 2. if other charger is not available, simply check if the old charger is giving output voltage or not. if there is about 4 to 6 volts DC, you can assume it as good, no need to change it. 3. attach the charger with the phone , donot put battery in the phone, quickly check if there is any voltage at the battery connectoer fo the phone, there should be some voltage , it varies from set to set, you can get min 1.8 or maximum about 4 to 5 volts. 4. if you get these voltages, you can assume that at least charging + some part of power ic is working. 5. if you dont get any voltage at the battery terminals it means charging section is not working. 6. if you dont get charging voltage at the battery terminals , normally , its due to fuse is ****n up., it can be bypassed with very thin wire. 7. if you find fuse is OK and still no volatge at battery terminals , it means there is some short circuit in the charging section. 8. this can also be identified very easily, to do so pls open your set , attach charger to it , wait for few mins, than quickly check by touching various parts , near to the charging connector and tha rest of the board, you will find few small parts heating up . Normally these parts are either capacitors or protection diode , which are grounded by one end, you need to identifies these over heating parts, once you find it, simply remove it , no need to put new in replacement. by doing so now you must get DC voltage at battery terminal of the phone. |
09-28-2006, 19:42 | #8 (permalink) | |
Member: 111457 Status: Offline Thanks Meter: 967 | Quote:
use 4.2V from external power supply remove batterie, and put + of external power supply to + Vbatt and - of power supply to - Vbatt if in current indicator u see more than 0 mA, therefore ur phone have a shorted circuit (damaged circuit) if not try | |
09-28-2006, 20:10 | #9 (permalink) |
Member: 2822 Status: Offline Thanks Meter: 152 | [QUOTE=BouRRi_GSM;2007203]if u have external power supply with current and voltage indicator, use 4.2V from external power supply remove batterie, and put + of external power supply to + Vbatt and - of power supply to - Vbatt if in current indicator u see more than 0 mA, therefore ur phone have a shorted circuit (damaged circuit) ************************************************ To make it more clear if you get excevie current drain @more than 150ma in power off position than there is short circuit . before doing any such thing pls set current limit to 150 mA in your regulated power supply unit. other wise it can do more damage. br AshwaniGaur |
09-28-2006, 20:59 | #10 (permalink) |
Member: 2822 Status: Offline Thanks Meter: 152 | Charging Solution Let us try to understand with more clear vision: pic no 1 is flow chart for CHARGING PROBLEM. Pic no2 is Circuit for Charging Section. If Charger is tested OK and still you get no voltage at battery terminals of the phone , pls try removeing parts with RED marking. ENJOY br AshwaniGaur |
09-28-2006, 21:47 | #12 (permalink) |
Member: 2822 Status: Offline Thanks Meter: 152 | IF set does not power on or consumes more current@>=100mA AND flashing also not possible pls check as in the pic: ENJOY br AshwaniGaur |
09-28-2006, 22:20 | #14 (permalink) |
Member: 2822 Status: Offline Thanks Meter: 152 | IF set still demands more current pls remove first COIL F803 and check again if current becomes normal than either C824 OR C827 OR BT-Module is FAULTY. This can further tested by fixing again F803 and remove C823+827, if still Battery terminal shows SHORTING or Leackage than BT-Module is Faulty. ENJOY br AshwaniGaur |
I was charged $350 today and today is monday! | chrisonic | Universalbox | 9 | 11-18-2008 04:31 |
Flashing tking all night still not done! | Spock789 | Sony Ericsson | 3 | 01-15-2008 16:45 |
Lg U8330 Scrached All 4 Testpoints ,now Dead | crossings | LG | 2 | 11-09-2005 17:26 |
