11-20-2008, 07:33 | #1 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | Nokia CDMA: Command Codes / Netmonitor / Hidden Menus I found this full listing of NetMonitor menus on google from a board that doesn't exist anymore. It also works on my 6585, and since the board no longer exists, I thought I would post it here for reference, before the info disappears entirely into the ether. If you have anything to add, please share! DISCLAIMER: USE AT YOUR OWN RISK entry point *3001#12345# { *Note from Mod: The following codes is PRI dependent. Some carriers may have them disabled or use *# instead of ## or using different code that spells differently for the same function (e.g. ##DATA# or ##BEARER# on some phones). } Dial-A-Codes ##837# or *#837#("VER") ... Displays version screen (also accessible by [Menu]-[6]-[2]). ##66767# or *#66767# ("MOSMS") ... Displays a selection screen to allow toggling of MO-SMS (Message Over : Simple Message Service) mode. ##743# or *#743# ("SID") ... Displays the current SID. ##24# or *#24# ("CH")... Displays the current Channel. ##786# ("RUN") ... Displays the Diagnostics menu which contains the Life Timer, Reconditioned Status, PRL, your number, and an Options menu which allows you to turn on the Service Screen (Net Monitor) or Restore Defaults (which resets the phone to factory settings). To restore defaults, you must enter the SPC/MSL code at the prompt. ##889# ("TTY") ... Displays a selection screen to allow toggling of TTY mode. (This code is referenced in the official Sprint manual.) ##7738# ("PREV") ... Displays CDMA mode menu, which allows you to select IS-95A, IS-95B, or IS-2000 modes. *#7738# ("PREV") ... Displays CDMA mode menu, which allows you to select IS-95A, IS-2000, or ????og modes. ##8626337# ("VOCODER")or *#3872# ("EVRC") ... Displays the EVRC settings menu, which allows you to select the EVRC mode as On, Off, or Home Only. ##2539# ("AKEY") ... Allows you to change the service-specific Authorization Key via the keypad. When the phone asks for Service programming code, enter the SPC/MSL for your phone. *#639# ("NEW") ... Allows you to change the MDN (phone number) registered in the phone. When the phone asks for Service programming code, enter the SPC/MSL for your phone. *#775# ("PRL") ... Allows to toggle the use of PRL. ##nnnnnn# ... Where nnnnnn is a six-digit number (no more, no less), input will return to the main screen unless the number happens to be your SPC/MSL, in which case you will be taken to the Phone Programming menu which allows you to change the MDN (phone number) registered to the phone. (I don't know if some other combinations in this domain do something or not, but they all appear to reset the display after entry unless you use the SPC/MSL, which is usually a hash derived from your ESN and is typically service-specific.) Other Codes thanks to sachin kamble wbr Hold # at the main screen for 3 seconds ... Displays the Life Timer in HH:MM format. |
11-20-2008, 07:36 | #2 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | nokia contd { Note: The following tricks may not exist or exist in different menu number combos in different phones. } There are several disabled menus throughout the phone. I have found this general rule about discovering when a menu should be there (ie, is simply "hidden") and when it is not really a menu (ie, you're shooting at a black target in the dead of night from the wrong direction). If you enter the number shortcut for the menu you seek (ie, [Menu]-[2]-[1] shows the Text Messages menu), one of two errors will occur if you do not get a valid menu: "Invalid Menu" or "Shortcut Not Available". The latter indicates that the menu is really there, but the factory or service provider has masked it from public use. Using this technique, I have found the following menus that should exist on this phone: [Menu]-[1]-[2] ... ?; Instant Messaging menu, most likely. [Menu]-[2]-[3] ... ?; Something to do with Text Messaging most likely. [Menu]-[4]-[6] ... ?; Something to do with Profiles [Menu]-[4]-[7] ... ?; Something to do with Profiles [Menu]-[4]-[8] ... ?; Something to do with Profiles [Menu]-[5]-[7] ... The Enhancement Settings menu, which can be accessed if you have ever had the phone in a cradle or a DKU-5 cable has ever been connected. It allows you to select Headset or Loopset modes. [Menu]-[9] ... ?; Applications menu, most likely. Security Settings Menu The Security Settings menu is locked on this phone by default. It allows you to set the phone lock, allowed numbers when the phone is locked, change the lock code, and enable incoming or outgoing call restrictions. The default lock code for phones is the last four digits of your MIN (phone number). You may be able to reset this code by reprogramming your MIN using the SPC/MSL code as listed above. The menu can be accessed via [Menu]-[5]-[8]. thanks to sachin kamble wbr Last edited by ~AKSingh~; 11-20-2008 at 07:44. |
11-20-2008, 07:37 | #3 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | netmonitor Net Monitor This section of the phone allows you to view diagnostic information and execute various tests. The codes are four digits long and are split into a group number (first pair) and a test number (last pair). In the code 1234, for example, 12 is the group and 34 is the test. When executed or viewed, these codes are displayed in the top-left corner of the phone in the form 12-34. The following codes I have discovered myself. While more may exist, that is unlikely as you can scroll through them by pressing the up or down arrows once you are viewing one of the codes. (If the code is a test execution, you must enter it directly through the Net Monitor menu option to execute it. Flipping to that page will simply display the name of the test.) While viewing a test screen, press and hold * until the text display changes and you can scroll through the tests in "explainatory mode" where you can see the abbreviations for the numbers you are looking at. It's kind of like a glossary for the Net Monitor. 0000 ... Disables testing and returns to the normal display mode without disabling the Net Monitor menu option Group 31: "Big Picture" & Summary Status Info 31-01 ... CSST / CHAN / SP / PPN / XF / -Rxx (Receive Strength, -dBA) / -Txx (Transmit Strength, -dBA) / SO / X / FER 31-02 ... DPCH / DTCH / IDLHO / HHO / IFIDLHO / DAHO / IBIDMO / IBHHO 31-03 ... PN(1-4) / ECK 31-04 ... PN(5-6) / ECK 31-05 ... OWNNUMBER (Own Number) / SL / P / MD / PC 31-06 ... SSS / CHAN (Channel) / SID (System ID) / NID / SD / ID / TM / CAP / ROAM or HOME (Indicates whether phone is on a roam tower or the home network) 31-07 ... V 31-08 ... SID (System ID) / NID / BaseID / PRev / MinPRev 31-09 ... CSST / MMDDYY (Date) / HHMMSS (Time) 31-10 ... TADD / TDROP / TCOMP / TTDROP / WW(1-3) 31-11 ... PP(1-4) / 0EC 31-12 ... PP(5-8) / 0EC 31-13 ... PP(9-12) / 0EC 31-14 ... PP(13-16) / 0EC 31-15 ... PP(1-4) / 0EC 31-16 ... PP(5-8) / 0EC Group 32: Current Tower Communication Info? 32-01 ... P/C / A/F / SID (System ID) / NID / PzID / PRev / MinRv 32-02 ... CSST / SO / -Rxx (Receive Strength, -dBa) / -Txx (Transmit Strength, -dBa) / FER / MUX 32-03 ... BrType / TERM / SES / CON 32-04 ... CcSt / CcEve / TxBytes / RxBytes 32-05 ... VER / RESET / ST / RTT / NAKR / PR / NAKPR / %NAK / MissFrames 32-06 ... RSt / RE / RMT / FSt / CURR / OvrFl (Overflow) / MAX / RSRq / RSGr 32-07 ... TOTL / NAK / NEW / OLD / IDLE / BLANK / FILL / INV / ER / DISCD 32-08 ... TOTAL / NAK / NEW / OLD / IDLE / BLANK / FILL 32-09 ... RMax / FMax / RUsr / FUsr / RNew / FNew / RRxm / FRxm 32-10 ... SeqTxNext / SeqTxNew / SeqTxUnack / RexmitTimer (Retransmission Timer) 32-11 ... DLen / BytesUnack / REXC / BOFFC / XMITW / CONGW 32-12 ... RMTYPE / CONTP / STATE / SO / MUX 32-13 ... RECVMM / RECVBR / SNTBR Group 33: Codec Info? 33-01 ... TYPE / VER / RTT / RESET / MXFNK / MXRNK / NGFNK / NGRNK 33-02 ... FSCH(0-1): (F)SCHID / MUX / RC / CODING 33-03 ... RSCH(0-1): (R)SCHID / MUX / RC / CODING 33-04 ... FSCH0: FSCHID / STAT / DUR / RATE / SCCLINDEX / NUMN / SRID 33-05 ... FSCH1: FSCHID / STAT / DUR / RATE / SCCLINDEX / NUMN / SRID 33-06 ... RSCH0: RSCHID / STAT / DUR / RATE / SCRM / SRID 33-07 ... RSCH1: RSCHID / STAT / DUR / RATE / SCRM / SRID 33-08 ... PKTD / SCRMD / USESCRM (SCRM on/off) / USETADD (TADD on/off) / PREARGMT Group 34: ? 34-01 ... SYNCOK / FAIL / FOCC / WOROK / WORFCO / WORFA / CTRLFI / MDRX 34-02 ... FVCFA / WFLAG / NORMRX / XSTBY / XNORRX / XNOK / XNFAIL / SYNLO 34-03 ... REP10K / FAIL / DECSAM / FOTED / R1BETT / SYNCS / MSGBET / SFLBE Group 35: ? 35-01 ... FRC / RRC / SOPT / RFCHG / PICHG / FPCM 35-02 ... NOMP / NOMPE / INIP / PS / NS / MREQ / MRSP Group 36: ????og/AMPS Info? 36-01 ... ACH REQ (Access Request) / ACH RESP (Access Response) / ACC / FAIL / T41 EXPIRED 36-02 ... SEND PRESSED / DACHORIG / PAGE RESP 36-03 ... ORIG / TOTLCALLTIME (Total Call Time) / AMPSTIME (AMPS Time) / LOS / REL / ACKF 36-04 ... 800HHO / ATMTP / PCSHHO / FAIL / CP HHO / PC HHO 36-05 ... CELAMPS / ATMP / PCSAMPS / FAIL / FRAMEOFF / SIDCHNG 36-06 ... AUTH CHALLNG (Authentication Challenge) / BSCHALLENGE (BS Challenge) / REGIST / DATA / ORIGI / PAGE 36-07 ... VOICEPRIVACY (Voice Privacy) / SSDFAIL / SME / PUBLC2PRIVAT (Public to Private on/off) / PRIVAT2PUBLC (Private to Public on/off) 36-08 ... PWR / PCH / ACC8 / MRELAMPSSYNC / NGBRSCANNOPN / GAOM / GSRM 36-09 ... RESEL / NOACC / MISMATC (Mismatch) / REJC / LOCK 36-10 ... REG / 3PwrDn (Power Down) / 0Time / 4Param / 1Pwrup (Power Up) / 5Order / 2Zone / 6Dista (Distance) 36-14 ... DSPASICSWSTK / MIPMDITIMBUS / MEMDMASRCRAM / SCHOTHERSOFT 36-18 ... NETWORK PREF / MOBILE PREF / SLOT / CYCLE / INDEX 36-20 ... PROBEHO / FAIL / ENTRYHO / FAIL / ACCCHAN / FAIL / T72TIMER 36-21 ... 1x-95HDR+GSR / 95-1xHDR+GSR / 1x-AMPS / DYNAMIC / SHO 36-23 ... RETRY TIMER / T50M / T51M / T52M / T40M / T41M / T55M Group 61: Battery Info 61-01 ... Version / Bars / Mon Bat Volt (Monitor Battery Voltage, millivolts) / Temp (Temperature, tenths of degrees Centigrade?) / Cap (Capacity) / Sby (Standby Level) / ChMo / CS / ChTy 61-02 ... VInst (millivolts) / tRem (millivolts) / VOff (millivolts) / VOn (millivolts) / Flg / Vdmf (millivolts) / BPW / Sta (Status) / VCh (millivolts) / WCh / WInt 61-03 ... Vdmf (millivolts) / Fl1 / Ips / Vbm4 (millivolts) / Fl2 / Ilo / Phi / tElpBM4 / dPhi / tRem 61-04 ... BImp / ChaAmnt (Charge Amount) / Vfull (Voltage Full, millivolts) / Vlow (Voltage Low, millivolts) / VBoot (Voltage Boot, millivolts) / V@Lo (Indicates whether battery is below ideal voltage limit) / Adj / Err 61-05 ... ActInf: byte4 / byte3 / byte2 / byte1 61-06 ... Ibattery (milliamps) / Iphone (milliamps) / Ifeature (milliamps) / disAmount (Discharge amount, milliamp hours) 61-07 ... CSIdle / ActSW / CS state / CS protocol / Batmon state 61-08 ... ChMD / Ch / Vbat (Battery Voltage, millivolts) / # / ChSt (Charger Status) / Ichr / F / AvgCh (Average Charge Rate, milliamps?) / CIch / PWM / bTp (Battery Temperature) / time 61-09 ... Chr / Old / ChM / Mod / Old / HWP / PWM / OSV / Frq / O / B / CSV 61-10 ... -DV / s-DV / dvt / CA / Vbd / BT / sum / MaT / dvt 61-12 ... Varying EM displays 1-4; can change from rel. to rel. 61-13 ... Varying EM displays 5-8; can change from rel. to rel. Group 62: Reset Info & Factory Flags 62-01 ... Reset reason / Task name (This should display "??? / NO RESET" if the phone has never been reset.) 62-02 ... Unk / Cha / Key / BOF / SW / Int / Sta / DSF / WD / Div / DSP / GSM / DSP / DSP / AWD 62-03 ... Prod / As / Un / IO / Null / Add / Alig / Flas 62-07 ... USE MENU TO DISABLE R&D (Research and Development?) TEST DISPLAYS (I would be careful about running this test!) Group 63: Phone OS Info 63-03 ... Ptr / Cntr / Task / OWrOut / SetO / Mod / Big 63-05 ... Use menu to select shown task info (asks for test input if run via the menu) 63-06 ... task0 / task1 / task2 / task3 / task4 / task5 / task6 / task7 63-07 ... task8 / ta*** / task10 / task11 / task12 / task13 / task14 / task15 63-08 ... task16 / task17 / task18 / task19 / task20 / task21 / task22 / task23 63-09 ... task24 / task25 / task26 / task27 / task28 / task29 / task30 / task31 63-10 ... task32 / task33 / task34 / task35 / task36 / task37 / task38 / task39 63-11 ... FIQ / IRQ 63-12 ... OS PRE-RESET ERROR (Should display "XX XX NO RES" on the top line if the phone has never been reset.) 63-13 ... OS CURRENT ERROR (Should display "XX XX NO DAT" on the top line if there is no error.) 63-14 ... OS PRE-RESET WARNING 63-15 ... OS CURRENT WARNING 63-16 ... OS PRE-RESET REMARK 63-17 ... OS CURRENT REMARK 63-18 ... usedbyt (Used Bytes) / blks (Used Blocks) / freebyt (Free Bytes) / blks (Free Blocks) / zz / dd / ii / cc / TT 63-19 ... Block Usage: TOP / 2nd / 3rd / 4th (in memory blocks) 63-20 ... FILE / LINE / total count Group 65: Input Flags? 65-01 ... CCTI / NB / DR / SC / WR / BO 65-02 ... PT / PB / BT / BP / BCTF / IC / IB / IT / IS / PCCC / PDCC 65-03 ... keys pressed Group 66: Organizer Flags? 66-01 ... TY / TgID / EI / VD / VC / Used / BL01 / BL02 / BL03 / VR 66-02 ... MY / MeID / Dura (Duration) / Mmos / Alrm (Alarm) / ER / VR Group 68: BER Test 68-01 ... USE MENU TO Start and Stop BER Test 68-02 ... FS / FR / FF / CRC Group 75: GPS & Location Data So far, I have only seen this area full of X's. Can anyone confirm that it works under certain conditions or why it would be masked as such? 75-01 ... LATITUDE / LONGITUDE / STATUS / METHOD 75-03 ... Orientation / Semiminor (meters) / Semimajor (meters) / Vertical (meters) 75-04 ... Time / Type / MS Date / MS Time / STATUS 75-05 ... Speed (meters per second) / Heading (degrees) / Altitude (meters) / Fix Type 75-19 ... LS Release ID / LS Release Date 75-30 ... GPS MCU Version / MCU SW Date / GPS DSP Version / DSP SW Date 75-31 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-32 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-33 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-34 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-35 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-36 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-37 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-38 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-39 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-40 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-41 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-42 ... SV(PRN) / C/No (Decibels.Hertz) / Pseudorange / Doppler (Hertz) 75-70 ... AFLT MCU Ver / MCU SW Date / AFLT DSP Ver / DSP SW Date 75-71 ... PN / Channel / Phase (Chips) / Ec/Io (Decibels) / RMS (meters) 75-72 ... PN / Channel / Phase (Chips) / Ec/Io (Decibels) / RMS (meters) 75-73 ... PN / Channel / Phase (Chips) / Ec/Io (Decibels) / RMS (meters) 75-74 ... PN / Channel / Phase (Chips) / Ec/Io (Decibels) / RMS (meters) 75-75 ... PN / Channel / Phase (Chips) / Ec/Io (Decibels) / RMS (meters) 75-76 ... PN / Channel / Phase (Chips) / Ec/Io (Decibels) / RMS (meters) 75-77 ... AFLT: PRQ(s) / NUM.FIX / TBF; GPS: PRQ(s) / NUM.FIX / TBF 75-78 ... PPhase count / Measure times / PRange count / Measure times thanks to sachin kamble wbr Last edited by ~AKSingh~; 11-20-2008 at 07:43. |
Need document NOKIA AT command | ....adolf.... | GSM Programming & Reverse Engineering | 0 | 03-13-2006 15:11 |
Nokia 2650 hidden menus | Malmis | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 12-28-2005 03:25 |
Nokia 8310 Security Code /restart When Try Codes. | crossings | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 10-17-2003 16:00 |
Nokia AT Commands | moja | GSM Programming & Reverse Engineering | 2 | 06-28-2003 18:21 |
Nokia AT-Commands | t-k4nzl3r | GSM Programming & Reverse Engineering | 7 | 11-13-2002 21:35 |
