03-19-2006, 04:55 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Age: 42
Member: 57566 Status: Offline Thanks Meter: 1 | 2112 signal ok but can't make a call anyone have solution??? Regards, |
03-27-2006, 16:17 | #2 (permalink) |
Insane Poster Join Date: Feb 2006
Member: 236859 Status: Offline Thanks Meter: 3 | are you sure the phone isnīt ESN negative? which country ayer you from? DO you receive a message like "RED OCUPADA" or something like that.... if you are sure that is not a software problem, and phone isnīt negative then you may have a hardware problem (Power Amplifier) |
01-05-2007, 17:18 | #5 (permalink) |
Junior Member Join Date: Jan 2007
Member: 424811 Status: Offline Thanks Meter: 2 | Hello Sir, Needed the solution for nokia 2112 cdma "SEARCHING FOR NETWORK" Needed the solution as soon as possible It would be kind enough if u can kindly send the solution with the diagram and i would be highly thankful to u |
01-10-2007, 18:50 | #7 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: India
Member: 232566 Status: Offline Thanks Meter: 150 | Quote:
Brother if u have the Ruim Mobile and has changed the esn and u are experiencing this problem then it should be ESN Problem set back it's origional ESN and check it has been testd by me number of times. Regards, Moderate. | |
N70..Signal full..but can't make or recieve call | ocha_vista | Nokia Hardware & Hardware Repair | 8 | 11-17-2009 12:02 |
2115 signal ok but can't make a call!!! | anchen | Nokia CDMA | 1 | 11-29-2008 09:13 |
huawei c210e full signal but can't make a call ! | juwanapati | Various CDMA/TDMA Cell Phones | 0 | 11-10-2008 10:30 |
c330 band change ok, but can't make a call | Bomber | Motorola Hardware Repair | 0 | 09-24-2004 11:27 |
8850 Full Signal, but can't make a call | MaRiN | Nokia Hardware & Hardware Repair | 10 | 03-01-2003 04:55 |
