help 3105 power switch tracks (pls see. image) 1 Attachment(s) C306 C310 and R177 lost with their points printed in board, somebody can help this --- the line connected to C306--, pls see attached image thx BR |
I repost this thread for requesting of solution, somebody can help us! thx br |
1st 3105: i make a hole with needle on the lost-point till i see very small point inside, then I drop a-small tin and heat it with ****er, you will see the tin glued, VIOLA, put wire to the switch. 2nd 3105: not possible to aplly 1st trick, then i make direct connection to uem PWRONX. it lies in 7th point right side.. good luck. |
YUP, i have red ur solution on FiF web, but i'm not dare to do like that, try to make connection to under uem. thx, i will try the first solve here, to look for lost point near power switch, ur br |
