04-21-2005, 20:19 | #1 (permalink) |
Junior Member Join Date: Apr 2005 Age: 41
Member: 135557 Status: Offline Thanks Meter: 1 | nokia 2280 .nep file need V F100V1403.nep 07-04-04 RH-17tri <--- i need change it to RH-17 i cuz it dont work for me tri .. i really hate that tri lol well my network is CDMA i already read some thread and i just one site have flash for 2280 but i extract all those files and i need .nep file for 2280 if and plz some help me im crazy here plz i need change it to RH-17 thx |
04-22-2005, 00:05 | #2 (permalink) |
Freak Poster Join Date: Nov 2004 Location: everywhere Age: 46
Member: 94023 Status: Offline Thanks Meter: 23 | hello P1ro, when you finish flash 2280 to rh-17tri will dissapear signal you than need to configure parameters, to return signal to the phone tell me too, which network, work in your country CC. www.CeluCables.com |
04-22-2005, 13:15 | #3 (permalink) |
Member: 135557 Status: Offline Thanks Meter: 1 | hi Hi i need some help with nokia 2280 im in venezuela using movilnet( no service ) contact me with msn ( [email protected] ) icq ( 19202790 ) or yahoo ( [email protected] ) Thx ---------------------------------------------------------------------------- Hola necesito ayuda con el nokia 2280 yo estoy en venezuela usando Movilnet ( sin servicio ) contactame por msn ( [email protected] ) icq ( 19202790 ) o yahoo ( [email protected] ) gracias |
04-24-2005, 00:42 | #4 (permalink) |
Freak Poster Join Date: May 2004 Location: CeluCables Age: 47
Member: 65115 Status: Offline Sonork: 100.71218 Thanks Meter: 72 | 2280 flashing... hola piro, aladin me linkeo contigo... bueno, en tema de programacion de nokias no es tan sencilla como la mayoria de Cdma que le cargas Prl y listo, Para hacerlo ( editarle los parametros y configurar ...) debes hacerlo via el phoenix, inclusive puedes leer un telefono bueno, y guardar esa informacion para el equipo que necesites.. En nuestro caso, nosotros contamos con FLS-4. y lo hacermos facilmente, sin embargo con los archivos exactos que contamos... dime que es todo lo que estas haciendo, quiza de esa forma pueda detectar tu error. CeluCables atte CeluCables.com |
05-01-2005, 10:20 | #5 (permalink) |
Member: 135557 Status: Offline Thanks Meter: 1 | Hola, muchas gracias por la respuesta, bueno te voy a explicar desde el comienzo: resulta que olvide la contraseña de blokeo del celular y andube como loco buscando como hacer para desblikiarlo por codigo me entere que no se puede y me resigne por que en el agente autorizado nokia de mi ciudad me estaba cobrando 40.000 Bs. Por desblokiarlo y preferi comprar el cable DKU-5 que me costo 45k, despues probe con varios programas para ver que lograba hacer el unico que me daba coneccion con el telefono fue el fbusv25 que con el lo logre desblokiar despues quedo desconfigurado y nunca volvio a agarrar señal y lo lleve a el agente autorizado y me dijo que necesitaba el .nep y nfp esos para volverlo a flashear completo o algo asi nunca entendi bien cual es la diferencia pero asi me dijo la persona en el agente autorizado y que el solo tenia el .nfp pero no tenia el .nep asi que lo estoy buscando desesperado, yo no tengo aqui phoenix ni nada solo el DKU-5 un phoenix en win98 crackeado que no me reconoce el DKU-5 y mas nada y despues que paso todo eso el PcSuite me reconce el telefono como un nokia 128XA bueno creo que eso es todo si pueden me contactan por msn ( [email protected] ) ICQ ( 19202790 ) yahoo ( [email protected] ) gracias |
05-01-2005, 11:05 | #6 (permalink) |
No Life Poster Join Date: Mar 2005 Location: indiamobilesolution Age: 72
Member: 121938 Status: Offline Sonork: 1001590655 Thanks Meter: 1,028 | i donot understand ur lengues, but i can advice you for ur solution, read pm from a good phone and write in to ur phone with ufs3, its 100%iested for network singnal u want ,good luck |
05-16-2005, 00:37 | #8 (permalink) | |
Member: 135557 Status: Offline Thanks Meter: 1 | Quote:
05-21-2005, 02:06 | #10 (permalink) |
Member: 65115 Status: Offline Sonork: 100.71218 Thanks Meter: 72 | OKEY, PIRO, DISCULPA LA DEMORA, EL TEMA ES EL SIGUIENTE. PARA COMENZAR TE ADELANTO DICIENDO QUE EL CABLE DKU-5 NO SIRVE PARA DESBLOQUEAR, TAN SOLO SIRVE PARA SINCRONIZAR CON EL PC-SUITE, O SEA FOTOS, IMAGNES, AGENDA. ETC.. COSA QUE NO NOS INTERESA. LO QUE TU PRECISAS ES UN CABLE F-BUS PARA NOKIA., QUE FISICAMENTE ES IGUAL A UN DKU-5 SERIAL, PERO QUE TIENE DIFERENTE CIRCUITO INTERNO. TENGO ALGUNOS CLIENTES EN VENEZUELA QUE CREO VENDEN ELLO, EN CASO NO LO UBIQUES ME ESCRIBES A [email protected] SEGUNDO ERROR. EL PROGRAMA QUE USASTE, FBUSXXX, ES PARA DESBLOQUEAR GSM, Y TU FONO ES CDMA. SOLUCION: LO QUE SE PRECISA AHORA ES QUE FLASHEES EL EQUIPO. PARA LO CUAL NECESITAS UN HARDWARE ESPECIALIZADO. SIN ELLO, ES UN SUEÑO SOLUCIONAR TU CASO. escribeme a [email protected] para porder responderte en la brevedad. saludos Ginocell CC. www.celucables.com |
05-21-2005, 05:28 | #11 (permalink) |
Freak Poster Join Date: Apr 2003 Age: 44
Member: 26420 Status: Offline Thanks Meter: 22 | @celucables need to know how to write rpl to cdma phone, i got phoenix black box. till now i still dono how to use it... would u like to explain it step by step.... thank's |
05-21-2005, 08:49 | #13 (permalink) |
Member: 26420 Status: Offline Thanks Meter: 22 | I got pbb,tornado n griffin but how to write it, i have try it so many times but not working.... what command i should do.. write as pm or what pls explain it detail.. thank's |
05-22-2005, 01:14 | #15 (permalink) |
Member: 65115 Status: Offline Sonork: 100.71218 Thanks Meter: 72 | hi friends.. To write rpl, you must read ask file. buy logs to griffin or ufsx server... after you should change physical UEM in the phone in dct4-phone. (open phone, disolder uem, put new empty.) and write the rpl but really, 2280 is cheap phone to make all this procedure, so i think I recomend to to buy new one good lucky ginocell www.celucables.com Last edited by celucables; 05-22-2005 at 02:35. |
nokia 2112 flash file need | mirax | Nokia CDMA | 12 | 10-01-2009 16:25 |
nokia 6020 pm file needed | gbada | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 08-02-2009 12:07 |
Nokia 9500 "PM" file need!!!! | gsm_research | WD2 & APE (Symbian Phones) | 0 | 12-27-2005 17:08 |
Nokia 7250i flash files needed | FoneFixUk | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-06-2004 13:30 |
