Sagem Hardware Repair Area All the Discussions for Repairing Sagem Phones are located here, No software Probelms you can find, all inside are Hardware Problems. |
03-26-2004, 20:22 | #4 (permalink) | |
Freak Poster Join Date: Jan 2002 Location: Moldova Age: 44
Member: 8442 Status: Offline Thanks Meter: 0 | Quote:
03-31-2004, 20:46 | #5 (permalink) | |
Freak Poster Join Date: Apr 2002 Age: 46
Member: 10679 Status: Offline Thanks Meter: 35 | Quote:
But on another phone I face the following problem: charging isn't working correctly, it discharges the battery entirely (to 0V!) when I try to load. Which IC is faulty? Any suggestion? | |
04-01-2004, 21:20 | #6 (permalink) | |
For disgarging repair you have to: 1) change sound amp - litle 8-pin TSOP IC below and left from battery connector. Attention: it has soldering pad on the bottom, so use only hot air gun, not soldering iron! 2) change charge controller - 6-pin IC - far right from the SIM connector, in names X4H or X4G. Good luck! | |
04-22-2004, 09:31 | #7 (permalink) |
Member: 10679 Status: Offline Thanks Meter: 35 | OK. So did I. Phone worked until I tried to charge it for the first time - since then when I switch it on the earth picture comes, and then phone keeps flashing as it does with desoldered EEPROM. I have checked everything in the sound amps neighborhood, I swapped most of them as well, but the problem remains. I suppose I had a short circuit and it killed something - but what? |
04-22-2004, 12:20 | #8 (permalink) | |
Member: 8442 Status: Offline Thanks Meter: 0 | Seems to be you had not only hw, but sw problem too. During repair operations you, may be, cause CPU or Flash damage (desoldering). Try to resolder them using hot air gun or BGA soldering station. If you'll flashing again, then rewrite eeprom IC. Quote:
04-22-2004, 18:46 | #9 (permalink) |
Member: 10679 Status: Offline Thanks Meter: 35 | Hmmm.... I suppose BGA resoldering is a bad idea since all BGA ICs are glued. I hate it. But I've swapped the EEPROM, phone is able to switch on now. I'm curious whether the replaced one is dead, and whether another charge attempt would kill the new one as well. Besides, you deserve more than a bottle of beer for your attempts. If I can help you with anything please let me know. I really appreciate your help. |
04-22-2004, 19:48 | #10 (permalink) | |
Member: 8442 Status: Offline Thanks Meter: 0 | You are welcome Will be fine to test, if you don't have an shorten VCC to GND in EEPROM or sound amp neighbor. Good luck, mate Quote:
motorola c117 noisy speaker | barthosyn | Motorola Hardware Repair | 1 | 03-25-2007 23:01 |
Noisy Speaker | moienshah | Sony Ericsson Hardware Repair | 0 | 05-23-2006 22:32 |
z600 noisy speaker | gibso | Sony Ericsson Hardware Repair | 0 | 12-06-2005 18:25 |
Many Ericsson T2x noisy speaker | dannyogolo | Sony Ericsson Hardware Repair | 3 | 10-03-2003 14:39 |
M35, sound noisy when connecting...WHY??? | CellM@n | x1x to x45/x50 | 1 | 06-01-2001 12:22 |
