Sagem Hardware Repair Area All the Discussions for Repairing Sagem Phones are located here, No software Probelms you can find, all inside are Hardware Problems. |
02-12-2005, 22:16 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: iTs mY sTYle Age: 38
Member: 73601 Status: Offline Thanks Meter: 3 | Repair your dead Sagem dongles with single click Click Here to download software. How to repair? Connect your dongle with LPT & also connect USB cable or adaptor for power and run our program, press "Program" button and wait untill it says "Successfully Dongle Repaired" if you have any problem about it then post here about it, we try to rid your problem. AND also post here how many peoples repair their dongles with our software. Last edited by iamWaQas; 02-12-2005 at 22:45. |
02-13-2005, 00:51 | #2 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: turkey all FORUM BADDDDDDDDDDDDDDDDDDDDDDDDDDD Age: 46
Member: 100470 Status: Offline Thanks Meter: 8 | Quote:
??????? SAGEM CODE reader und sagem master what repair | |
02-13-2005, 07:36 | #4 (permalink) |
Member: 73601 Status: Offline Thanks Meter: 3 | Use attached software and if you receive same error then Note down Error Code & Error Detail & send it to me ..i try to remove your error .. Click Here for full detail about this software. because i test this software different 3 version of Windows 98 Thanks. |
02-13-2005, 17:21 | #7 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | Quote:
i confirm fleshazo this is what we call a dongle f u k e r | |
02-14-2005, 23:27 | #12 (permalink) | |
Sorry !!!! It was a very bad mistake saying this. Mu first test to rpair my dead dongle didn't work because i used won 2000 pro But now, i confirm, this soft works perfectly on WIN 98 SE Thanks a lot an BR form ALGERIA | |
02-14-2005, 23:30 | #13 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 39
Member: 73867 Status: Offline Thanks Meter: 5 | easy worked way to make dongle repair!! HI! You need to creat an easy pin out converter and connect it to dongle and computer LPT port and use USB for power supli. For make repair use the good PonyProgV205a and this option: 1; select ATMEGA 16 device and programer setup is Avr ISP I/O and LPT 1 2; ERASE chip 3; Security and Configuration bits BOTSZ1 - selected BOTSZ0 - selected BOOTRST - selected CKSEL2 - selected then OK 4; Open device file (choice the flash in bin format) 5; Write device (use only Write device button) the program run automaticaly and after write procedure make a verify . that's all! link for PonyProg: www.lancos.com |
02-15-2005, 05:10 | #15 (permalink) | |
Member: 73601 Status: Offline Thanks Meter: 3 | Quote:
But there is problem to make new cable if anyone want to use PonyProg. But if you want to use Computer's Hospital's dongle repair software then no need to make new cable just connect your dongle and press program. -------------------- DONOT USE ORIGINAL DONGLES -------------------------- -------------------- DONOT USE ORIGINAL DONGLES -------------------------- -------------------- DONOT USE ORIGINAL DONGLES -------------------------- -------------------- DONOT USE ORIGINAL DONGLES -------------------------- Note: If anybody want to test our software then connect your cloned dongle and select "ERASE ONLY" and press program, when software ask that "Dongle Successfully Erased" then close your software and try to connect this dongle with any software.. now your dongle is dead .............. now if you want to repair your dongle then open our software and press program .. now your dongle is perfect..... -------------------- DONOT USE ORIGINAL DONGLES -------------------------- -------------------- DONOT USE ORIGINAL DONGLES -------------------------- -------------------- DONOT USE ORIGINAL DONGLES -------------------------- -------------------- DONOT USE ORIGINAL DONGLES -------------------------- Thanks WaQas | |
The Following User Says Thank You to iamWaQas For This Useful Post: |
send MULTIPLE SMS with single click to single user | hafizjee | Nokia Multimedia | 1 | 09-13-2009 17:11 |
no more dead c-m-s35 download and repair your dead phone | duyhan | x1x to x45/x50 | 2 | 11-28-2002 03:21 |
I'll repair your dead C/S25 at SPb. | te | x1x to x45/x50 | 4 | 10-22-2000 14:03 |
