Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 10-29-2007, 17:58   #1 (permalink)
Member: 101681
Thanks Meter: 31
Siroya/Vahid D900 I cannot remove "SIMLOCK" after full flash also please advice
Hi Siroya/Vahid, I have full flashed the D900 to remove "SIMLOCK" but its not working, I have format FFS also but no change please advice.
Old 10-29-2007, 19:19   #2 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
wot earror you get when you try to unlock ?
Old 10-29-2007, 19:32   #3 (permalink)
Member: 101681
Thanks Meter: 31
It doesn't give any error but when i press unlock it detect the phone and UST goes in process and software hangs.
Old 10-29-2007, 20:11   #4 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
try to unlock
power on the phone with battery and then press unlock and then put the cable...
try and post reply
Old 10-29-2007, 20:44   #5 (permalink)
Member: 101681
Thanks Meter: 31
well it worked but instead turning it on it was in off mode and it went in TAT mode and it became unlocked thanks for showing this procedure.
Old 10-29-2007, 20:55   #6 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
good
it always work for me
ust is the most powerfull device
when all tricks fail then i try this which always work
best of luck
LG KU311 now network after full flashe help please yane FuriousGold 5 08-31-2007 12:13
Siroya/Vahid 820 camera turns 180 degree after flash sDinesh UST Pro II 0 07-06-2006 01:10
V303 after full flash, cannot make any call. leviswang Smart-Clip 10 04-19-2006 03:13
Cannot create file after full backup of K300i duron850ph SonyEricsson (USB-Smart) 0 01-11-2006 13:16
k300i dead also cannot power on after sucessful flashing saily Cruiser Suite 4 07-31-2005 09:53
Page generated in 0.13944 seconds with 9 queries
