D500 bluetooth and infrared problem pls,help whenever i want to on the bluetooth or infrared on my D500, it will read bluetooth error or infrared error.what am i going to do.pls helpppppppp. |
Rebuild IMEI , or > Full Erase Flash+WriteFLS+FFS+FormatFFS+RebuildIMEI |
It is hardware problem, my friend. No soft operation can repair it. BR Mike |
hallo,do u have the hardware solution? tell us plz |
D500 Bluetooth-infrared Error :( :( I gave it a full flash but i got the same result.pls nidal01 what is the hardware solution.or anyone with the solution. |
send it 2 me,i will do it. |
Just do it what Vahid has said above tested working 100% (Rebuild IMEI , or > Full Erase Flash+WriteFLS+FFS+FormatFFS+RebuildIMEI) its not hardware Br |
its a bluethoot id problem and it solve when the phone is full flush;) ;) |
try to change IMEI and BT No. |
change infrared ............ |
try rehot bluetooth its not ok change bluetooth ic.................. |
YES BUT HE NEED ID ADRESSE TO SOVE HIS PROBLEM |
d500 bluetooth and infrared pro......still no solution? |
Problem Hard Y a un problem hard, "la trappe de la tresse" mon ami . :) |
i fix this problem by changing bluetooth ic and was working after i can activate infrared and bt Best Regards |
