03-21-2007, 09:48 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: kurdistan Age: 47
Member: 101358 Status: Offline Sonork: 100.84312 Thanks Meter: 18 | and when i chose d500 unlocking done but in phone same not unlocked Reading data from box... Power ON phone... Phone detected! Setting sysol test mode... Sysol test mode ok! IMEI : 354346-01-049228 Unlocking phone... Operation successful. Elapsed Time (00:07) |
04-01-2007, 07:06 | #9 (permalink) |
Insane Poster Join Date: Jun 2006
Member: 295998 Status: Offline Thanks Meter: 34 | bassam_gsm In case anyone else has this problem Like you and I did because my USTPRO is not unlocking this model of phone T219 I get the same problem you do. This is a T-Mobile Pre Pay phone that I'm having this problem with. Solution, Select D500/D50x At the bottom click on set network locks make sure they are all 0's #7465625*638*00000000# This is what i was getting and to even get this far cause it was freezing at sysol test mode ok! I had to push 1 and 2 1 and 2 1 and 2 over and over again. I have tried setting the network lock to 00000000 using it on T219 it did not work this is the only solution i found. Can you please fix this in the next version thanks Reading data from box... Power ON phone... Phone detected! Setting sysol test mode... Sysol test mode ok! IMEI : 0A0002-00-ABABAB NCK : ««««· MCK : ««««· SCK : ««««· SPCK : ««««· Operation successful. Elapsed Time (02:25) |
04-04-2007, 04:13 | #14 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Mexicali
Member: 372188 Status: Offline Thanks Meter: 57 | If you're lazy to wait until ust pro 2 is ready, you can enter this codes: With non accepted sim card, power on phone, then write: *7465625*638*00000000*00000000# Then:#7465625*638*00000000# Power off your phone, then power it on, and is unlocked permanently... Tested on x495, x497, t209, t309, t319, USA t-mobile t809, t509, and USA cingular c417... If phone doesn't get signal is not ust pro 2 fault... Last edited by emicabher; 04-04-2007 at 04:27. |
The Following 6 Users Say Thank You to emicabher For This Useful Post: |
Samsung T219 Unlock | bassam_gsm | HWK | 30 | 08-05-2019 06:25 |
Samsung T219 Unlock | damabib | UST Pro II | 38 | 05-26-2010 14:36 |
Samsung T219 Unlock Code | jonel1983 | Samsung Flashers, Software, Firmware. | 12 | 12-10-2009 14:33 |
Samsung T219 unlock | George(LMC) | Samsung Hardware Repair | 0 | 10-03-2009 13:37 |
>>> Samsung T219s Unlocked by NS Pro <<< | zeel_zeel | NSPRO | 2 | 05-01-2009 19:59 |
