How to unlock T639 Hello friends I need help on how to unlock a Samsung T639 with UST-Pro II. I press direct unlock on SW but not unlock the phone Reading data from box... Searching for UMTS phone on box port... Phone detected on box port! Error : MSL Bypass failed! Write PATCHED FLASH to phone and try again! Can anybody post the procedure? or anybody has this Patched flash? Thanks |
OK, The problem is that i just bought my UST Pro II box, and received it last saturday. So i am a begineer on this tool. First, i got trouble with the new version v7.00, didnt run. i found a v7.00_fixed version, ok then, the direct unlock on T639 does not work i need now a patched file I was searching the patched file on ust-pro2.org, but is not there. it is in ustpro2.org , but i found another problem, the server is down since 5-15-08 and i cant download the file. So, Anybody can share this file? Thanks. |
anyway support server is back so u can download the patch from ther |
Ok!! I got now Thanks so much lets see if i can unlock it with this patched flash |
i think by code test now |
T639 Quote:
>>> T639 successfully unlocked <<< tried unlocking T639 successfully p.s thanks siroya 1.flash phone with T639_Patch_Unlock_IMEI.qcr tick FFS format 2. DIRECT unlock "CHECK" Remove all locks whilr DirectUnlock cable used E210 Rj45/USB |
ver 7.12 direct unlock. no need pacth file..........1000%ok |
