10-27-2003, 02:56 | #1 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Important!!! Read here before start to use UST Pro !!! -Never flash S300 with S300M flash, or S300M with S300 flash. -Never flash xxx0 or xxx5 with xxx8 flash, for example, dont flash N620 with N628 flash or N628 with N620 flash. -Never flash S105 with S100 flash, and S100 with S105 flash. -Never do any change in smart card update file, your dongle will be damaged for ever. -Never run UST pro when "SE Fighter" dongle is connected to USB port,and never run "SE Fighter" when UST Pro dongle is connected to USB port. Last edited by VsH-GsM; 01-29-2007 at 16:00. |
10-27-2003, 20:23 | #8 (permalink) |
No Life Poster Join Date: Dec 2002 Age: 48
Member: 18855 Status: Offline Thanks Meter: 1,939 | you are wrong.... i have use others software to flash it and works ok..and also there is the sw already free..... i am using optiflash to flash S300 to s308 , s200 to s208 , v200 to v208 with no problem...and how come your ust!!!!!!!!! |
10-27-2003, 21:36 | #10 (permalink) | |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Quote:
2- There is some customized flashes , which ppl use them to convert phones to chinese system.. But for N620 >> N628 , for sure not possible without modifing sw/hw ! because flash chip sizes are different.. | |
10-27-2003, 21:45 | #11 (permalink) | |
When you insert dongle to pc, if the green led on dongle lights, this means dongle is ok, you have problem in installing drivers, download UST Pro user manual and read it.. | |
10-27-2003, 22:03 | #12 (permalink) |
Member: 18855 Status: Offline Thanks Meter: 1,939 | But for N620 >> N628 , for sure not possible without modifing sw/hw ! because flash chip sizes are different.. for me is possible...i am using the flasher with run in ms-dos and work's perfect..there is no diffrent also..i have flash N620 to N628 more then 50pcs without problem... if possible please update your flash file section..as i can see that the is few asian language flas file .. hopefuly you can upload asian flassh file for all models.. |
10-28-2003, 10:53 | #13 (permalink) |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | So you have a customized chinese flash for N620 !! Else, its not possible, ALL FLASH FILES FOR CHINESE MODELS ARE AVAILABLE IN SUPPORT AREA !!! you can try your self.. |
10-28-2003, 11:10 | #14 (permalink) |
Member: 18855 Status: Offline Thanks Meter: 1,939 | can you upload the S308M chinese version flash file at your support area??? and also please add al the models with more asian language like, thialand,Bahasa Malaysia,Indonesia |
10-28-2003, 11:18 | #15 (permalink) |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Ok, S300_07 (indonesian/malay) comming today. But about S308M, im not sure, S300M is designed for europe, not asia, by the way i will try to find this flash.. |
i need video how to use ust pro ll...please | lordceltech | UST Pro II | 4 | 01-26-2009 22:09 |
please help me.....how to use ust pro 2.............................................. | sanamsanam | UST Pro II | 2 | 10-09-2008 22:44 |
Instructions to use UST Pro | dthang8 | UST Pro II | 1 | 08-01-2007 23:25 |
Plz how to use ust-pro IIn to flash X480 and others | Cobbysyms | UST Pro II | 0 | 07-21-2007 13:23 |
how to use ust pro ii? | bestncheap | UST Pro II | 5 | 12-30-2005 14:45 |
