08-25-2009, 19:08 | #1 (permalink) |
Junior Member Join Date: Jul 2009 Location: Afghanistan
Member: 1069034 Status: Offline Thanks Meter: 4 | s5230 fone not found!!!!! i cant unlock s5230 see steps if it is ok 1.first i installed samsung pc suit 2.connect (Rj45+usb) both to box 3.power on fone and insert cable 4.soft gives a msg "power on .........." 5.i did and press ok at end it says fone not found help please what is mistake and which driver must be installed ??? Link ???? from support site i downloaded all broadcom and usb driver but same problem.. hope ust team help /// |
08-25-2009, 19:10 | #2 (permalink) | |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | Quote:
see this http://forum.gsmhosting.com/vbb/showthread.php?t=813176 it help you.... Br. amar181 | |
08-25-2009, 19:16 | #3 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | Quote:
Post Here Logs Or Screen Short ..... | |
08-26-2009, 02:02 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Hello!If you Connect Correct cable and have PC-Suit (Download From Samsung) after connect cable (E210) In display can appears This: Connect to PC-suit-Mass storage Etc.You need mark option PC-Suit Confirm and try. Regards Haicha |
Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 3 | 16 | 03-30-2010 10:57 |
S5230 BUG phone not found V9960 but 9954 ok | pearsonjohnboy | UST Pro II | 4 | 10-18-2009 14:37 |
i still not use it apple not found and license not found | ABDULLAHI MUHD | FuriousGold | 2 | 06-16-2009 12:57 |
Searching fone ... not found :( | mp3hot | Redbox | 9 | 10-09-2005 21:29 |
