07-20-2006, 16:37 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 68824 Status: Offline Thanks Meter: 5 | Cannot install ustpro 2 I tried 4 different pcs, also tried both xp and win2000, but no luck When installing it seems to find the smartcard drivers, but then it asks for the usd <-> serial drivers. This is where the problem starts. These drivers are not in the ust2 drivers dir. Can anyone help me solve this problem Best regards Jerrel |
07-20-2006, 17:37 | #2 (permalink) |
Freak Poster Join Date: May 2006 Location: Manchester, UK
Member: 281494 Status: Offline Thanks Meter: 6 | Are you installing it as it says on insallation pdf file? drivers first, and then box when requested?. Have you made sure you have no other schlumberger hardware connected during installation. |
07-20-2006, 18:15 | #3 (permalink) |
Member: 68824 Status: Offline Thanks Meter: 5 | Yes i did follow all the instruction in the pdf. I tried the same instructions on 4 different pc 2 windows 2000, and 2 windows xp. all 4 resulting in the same problem cannot find usb<->serial driver I contacted ustpro team, and all they say is that the drivers is in the drivers dir, but i windows cant seem to find it, and manualy i cant either What is the problem ??? Pleas help |
07-20-2006, 18:30 | #4 (permalink) |
No Life Poster Join Date: Oct 2004 Location: CAIRO _ @ _ 112 _ -= EMERGENCY ROOM =- Age: 48
Member: 86655 Status: Offline Thanks Meter: 385 | install this and setup first (reader_drivers_2kxp_manual) you 'll get this from support after this connect your box to pc and catch your drive from x/program-files /ust/driver hope it help |
