05-24-2009, 14:29 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Mate read this thread there is step by step solution it may help you.http://forum.gsmhosting.com/vbb/showthread.php?t=753230 WBR Nawab Sahoo |
The Following User Says Thank You to NawabN Sahoo For This Useful Post: |
05-24-2009, 14:54 | #4 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,728 | Quote:
B.R. | |
05-25-2009, 05:34 | #5 (permalink) |
Member: 687312 Status: Offline Thanks Meter: 290 | Mate I dont want to spam and I have repaired in this method,Flash ,repair OTP and rebuild IMEI if you think you are very smart and dont need any help so there is no need for posting asking help. |
05-25-2009, 06:04 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Samsung B220 hang on logo Quote:
follow the steps: 1- complete flash in repair mod (by checking repair mod check box). after complete flash power on phone then next steps 2- must repair OTP back from phone (under battery S#). 3- rebuild original imei back from phone. Note: if phone have no signal then write good eeprom from support or readed from ok phone, then repeat 2-3 operations. now you have success mianlinks | |
05-25-2009, 08:16 | #8 (permalink) | |
thanks in advance | |
05-26-2009, 16:45 | #14 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | Quote:
select correct flash files press DO JOB when you see progess bar runing 1,2,3,4,5,6,%%%% plug cable to your phone and if not work just plug cable then put battery to phone this depend to your cable . | |
The Following User Says Thank You to allal123 For This Useful Post: |
B220 hang on logo | Triminity | HWK | 5 | 03-26-2011 08:08 |
B220 Hanging problem solved after flash | QAMMARSHAHBAZ | UST Pro II | 5 | 06-12-2009 14:22 |
B220 hang on startup (b220) no flash file in support | CHAPRAN | UST Pro II | 9 | 04-23-2009 15:40 |
B220 Hangs on Startup | ..::ARUN::.. | UST Pro II | 4 | 03-20-2009 15:28 |
B220 hang on logo Successfuly done by flashing | murtaza_nns | NSPRO | 3 | 02-17-2009 08:23 |
