Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 08-19-2008, 13:50   #1 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
samsung F480 unlock problem
hi
hello
i m send ask to my resaler and my resaler give me rpl when i m write rpl software always give error plz help me.
The Following User Says Thank You to Sahil2007 For This Useful Post:
Old 08-19-2008, 14:38   #2 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
Flash The Phone And Then Write Rpl Or May Be Rpl Is Corrupted
Old 08-19-2008, 16:05   #3 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
Originally Posted by Sahil2007 View Post
hi
hello
check rpl i m buy from resaler.
Old 08-19-2008, 16:15   #4 (permalink)
GSM MIND's Avatar
Member: 20645
Sonork: 100.1579175
Thanks Meter: 635
Originally Posted by sahil2007 View Post
check Rpl I M Buy From Resaler.
I Think Ur Rpl Is Currpet Try To Contact Ur Rseller
Old 08-19-2008, 18:05   #5 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
flash ur fone and read ask again
send ur to reseller
Old 08-20-2008, 11:37   #6 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
send ur to reseller
i m flash my phone
phone not flash
Loading flash file...
Flash file loaded OK!
Searching for UMTS phone...
Phone detected! : COM5
Programming flash...
ERR_WRITE_TIMEOUT
Elapsed Time (00:17)
MODEM Stop at 22%
set dead plz help me
Old 08-21-2008, 13:21   #7 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
i m flash my phone
phone not flash
ERR_WRITE_TIMEOUT
MODEM Stop at 22%
hi
hello
i m solve my problem self no body help me. i m unlock my set Successful.
Old 08-23-2008, 09:33   #8 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 29
Question how u unlocked
pls help how u unlocked it
Old 08-23-2008, 11:33   #9 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
before read ask flash your phone with multi loader and read ask with ust pro2 and send to ust pro2 support team when u recive rpl flash your phone again and write rpl with ust pro2 after rpl write done press unlock. Enjoy.
Old 08-27-2008, 21:45   #10 (permalink)
Member: 683086
Thanks Meter: 15
f480
hi mr
can i ask you which cable you use to flash the phone and how mauch you buy rpl file .
Old 08-28-2008, 06:49   #11 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
Originally Posted by falah1 View Post
hi mr
use orignal cable.
Old 08-28-2008, 14:21   #12 (permalink)
MAHRES's Avatar
Member: 560291
Thanks Meter: 11
why ust pro unlock several models by rpl and which cost money ? in other hand we find other box's support it for free !!
plz explain that ust pro team ?
wbr
MAHRES
Old 08-29-2008, 18:22   #13 (permalink)
Member: 7352
Thanks Meter: 13
when putting the fone in to flash mode do i hold volume, camara and power button?
also when flashing fone do i flash it with normal e210 or with e210 joint with usb ?
also when flashing fone do i check or uncheck ffs format ?
do i leave battery inside fone or remove battery ?
tried to flash the fone with F480_25_HPHG3.qst keep getting error message shown below.
Phone detected! : COM3
ERR_WRITE_TIMEOUT
Elapsed Time (01:55)
Old 08-30-2008, 01:54   #14 (permalink)
Member: 502415
Thanks Meter: 18
ithink that ower have problem in his cable yu must change a comagedable may be end
Old 08-30-2008, 06:51   #15 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
ERR_WRITE_TIMEOUT
use orignal cable and flash with Multiloader Flasher.
Samsung F480 Touching problem...Pls help. td99 QUALCOMM Models (3G) 9 10-06-2011 11:31
samsung f480 unlock problem gamesandgrooves Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 08-25-2009 06:38
Samsung F480 unlock problem..... abdulwajid147 Easy-Unlocker 5 06-21-2009 15:55
samsung F480 Unlcok problem..... abdulwajid147 Easy-Unlocker 3 05-30-2009 09:15
samsung F480 charging problem lxa786 Samsung Hardware Repair 5 03-30-2009 13:22
Page generated in 0.30848 seconds with 10 queries
