Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 01-31-2008, 14:18   #1 (permalink)
.:Morpheus:.'s Avatar
Member: 47774
Thanks Meter: 185
D900 camera problem
D900 camera Freeze i have try to flash it with camera pach and rest camera driver but still the same problem any one have fix this problem before ?
Old 03-23-2008, 12:59   #2 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
yes bos i have a same condition.................
what is sulotion?
Old 03-23-2008, 13:08   #3 (permalink)
GsmFreeShop's Avatar
Member: 567723
Thanks Meter: 314
Please try this solution.
Flash your phone whit this FFS file.
This is new camera driver.
Flash only FFS, and dont check Format FFS!!!
After flash enter the code #*9998# to load the new camera driver.
br
>>> GsmFreeShop <<<
Old 03-23-2008, 13:16   #4 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
THANKS A LOT
Sir problum is solved ......
Old 06-02-2008, 16:16   #5 (permalink)
Member: 414427
salamon alaykom
can u patch this file for me please ?
I have this problem with my d900 , when I turn on the cammera , phon say that ' preveiw error'.
thanx alot
Old 07-10-2008, 14:22   #6 (permalink)
Sengoku's Avatar
Member: 161417
Thanks Meter: 19
still have same problem?? any other solutions to try??
The Following User Says Thank You to Sengoku For This Useful Post:
Old 09-20-2008, 11:00   #7 (permalink)
07heaven's Avatar
Member: 57937
Thanks Meter: 34
I had this problem, had tried the patch file (or Pach file), and press #*9998#, but was still the same!
So flashed it with UFS, with the ticks shown in the picture below:
ENABLE CAM RESET
ENABLE MMS RESET
ENABLE Default RESET
Maybe ENABLE CAM RESET is enough, but I ticked all 3.
d900 camera problem kadour83 Samsung Hardware Repair 0 12-01-2008 10:32
D900 camera problem after flash EBRJO UST Pro II 7 11-22-2008 06:35
D900 Camera Problem Solution oldcoyoteinc NSPRO 9 10-18-2008 20:22
samsung d900 camera problem nomi Samsung Hardware Repair 3 04-18-2007 11:40
d900 camera problem spidermann UST Pro II 1 01-31-2007 11:44
Page generated in 0.15401 seconds with 10 queries
