v804ss not found Help me unlocking step by step V804SS is not found modem ok com 16 vodafone894ss modem USTPRO2 port com 3 USTPRO2 port com 4 cable R45 USB phone is flash mode Reading data from box... Searching for UMTS phone... Phone not found! Elapsed Time (00:36) 804SS step by step unlocking Help me |
hello modem com port change ex. com 5 ? or speed down ex.9600 ? |
yup modem com of the unit for ex your ust has it at 3 and 4 make your unit at 5 gets?... |
no not found com port cange com5 do not set flash mode? |
What version? Kindly check the date, |
did u put ur fone in download mode ( 9 + power on) |
1. put ur fone in download mode ( 9 + power on) IF u select ust com port 3 and 4 THEN V804SS MODEM SELECT ON COM2. EXAMPLE: AS BELOW 2. v804SS MODEM port com 2 USTPRO2 port com 3 USTPRO2 port com 4 BR saleem |
Indication with a flash mode is VOFDKK4.0. Indication of a device with a flash mode is SUMSUMGMCDMAMODEM not V804SSMODEM. Please help somebody it. |
BR saleem |
I can flash v804ss but can not unlock Searching for UMTS phone... Phone detected! : COM2 Programming flash... Operation successful. Elapsed Time (03:09) SUMSUMGMCDMAMODEM port is com5 whay Phone detected! : COM2 ??? |
could be detected if using lower version of UST...but phone would just hang up...... |
how can i change com port modem i try from device manger opened port (com and lpt)not found opened modem i found it but samsung mobile usb modem but not able to change any advice please |
Then Vahid serabi should correct this COM port bug problem, i had encountered this problem today. Good Luck... |
