10-14-2008, 11:45 | #1 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Palestine
Member: 36394 Status: Offline Thanks Meter: 250 | Z240 failed to unlock using " Fast Direct Unlock " Quote:
cable used V804 and is 100% working , in fast direct unlock i used v804 cable only on RJ45 , i also tried to flash the "Z240" with "Z240E_PATCH_UNLOCK_IMEI.qst" to unlcok it , but i always get this error i finally tried to do "direct unlock" it here's the result . step 1 after i click ok , comes the result in step 2 step 2 baaaaaang , USTPRO II crashes , like for ever it does using this particular phone ..., now what i'm supposed to do ? this problem is irritating to me and i have turned down 2 customers for now . my drivers are ok , cable is good , tried 2 computers , same result . plz help SORYA VAHID , | |
10-14-2008, 12:12 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | try to do epprom reset by *2767*2878# and *2767*3855# after that put these with sim *7465625*638*00000000*00000000# and power off phone and remove sim card and do unlock procedure as you done above and reply what happen??? |
10-14-2008, 17:04 | #6 (permalink) | ||
Member: 36394 Status: Offline Thanks Meter: 250 | Quote:
and it didn't work Quote:
and as i see its common problem for many people . plz fix it . WBR | ||
10-14-2008, 19:02 | #7 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
10-17-2008, 23:48 | #9 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | Which phone 3G cant unlock whith fastunlock????? Which phone 3G cant unlock whith fastunlock?????I mean is z720,z240,z370.................whith ust ver 8.02 |
10-19-2008, 10:41 | #14 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | Quote:
i used only v804 rj45 without flashing.just fast direct unlock. Searching for UMTS phone... Detecting phone on RJ45 port... Phone has been detected! Reading data from phone... Calculating SP Data, Please WAIT... Calculate OK! Current lock status : ON (214-03) Unlocking phone... Operation successful. Elapsed Time (00:15) | |
10-19-2008, 17:47 | #15 (permalink) |
Insane Poster Join Date: Jun 2007
Member: 524556 Status: Offline Thanks Meter: 3 | i want to unlock z720m ,on direct unlock it show write patch imei unlock or rpl,wat is rpl?and by fast unlock it invalid data wat i do ?evn i m unable to write patch filr bcz wen i flash it show phone not detected |
Z720 can't unlock " Fast Direct Unlock " | A-H-T | UST Pro II | 5 | 11-19-2008 18:57 |
Direct unlock & fast direct unlock ? | vmin81 | UST Pro II | 14 | 11-05-2008 11:17 |
l760v can't unlock by fast direct unlock | tuli | UST Pro II | 3 | 10-15-2008 03:55 |
: Update 02 June 2005 : Bird S688 Fast Direct Unlock | Infinity-Box | Infinity-Box | 6 | 06-02-2005 18:02 |
easy to use and fast savvy unlocker | ardtronics | Philips | 3 | 08-28-2003 22:29 |
