Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 10-21-2006, 12:05   #1 (permalink)
Member: 8028
ZV10 freeze after unlock
Now no modem connection
if i am right then i need a patch modem file
how to solve ?
Old 10-21-2006, 12:09   #2 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,411
select Zv50 and press direct unlock
Old 10-21-2006, 12:31   #3 (permalink)
Member: 8028
Can't connect phone not found
another solution ?
Old 10-21-2006, 13:07   #4 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
reinstall phone modem driver .. if still same change modem comport lower then ust comport
Old 10-21-2006, 14:00   #5 (permalink)
Registered User
the new's Avatar
Member: 36653
Thanks Meter: 336
Wink
another solution ?
enter download mode
kipp pressed 9 and then power on the phone
it will enter in download mode then flash it
Old 10-21-2006, 15:07   #6 (permalink)
Member: 8028
no succes
all done no succes but it worked before so its must be the
software of the phone that is be changed
modem is seen in the config off pc but no communication
also no communication whit other soft .
its still said phone freezed whit simcard
any solution??
Old 10-21-2006, 17:03   #7 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
any solution??
try in other pc .. if still same then probably its an hardware fault .. check fone connector
wbr
SiRoYa
Old 10-22-2006, 06:05   #8 (permalink)
Member: 8028
Smile
wbr
SiRoYa
Well if ist a hardware fault or connector then it must be not
enable to unlock in first place ,the phone can still be
flashed and ist a new phone
Problem now solved phone 100% working
flashed and unlock
Old 10-28-2006, 07:42   #9 (permalink)
Member: 205421
Thanks Meter: 3
how can u solve ur problem
Old 10-28-2006, 10:05   #10 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
flashed and unlock
u said !!! fone is not getting connect with other sw too !!!
Old 10-28-2006, 15:00   #11 (permalink)
Member: 8028
flashing no problem but voor unlock phone not found
it saw the modem on the pc but not communicate white
ust pro or other program
i flashed and a try but won,t work
then final i flashed again whit the flash of the support
then just before the phone startsup for normal operation
choose again zv50 unlock that works for me
btw the very first time for unlock i use zv10 then freeze problem
zv10 freeze adter unlock please help me al3oshak UST Pro II 3 02-06-2007 23:20
A75 White freezing after unlock malek45 E-Gold Based Phones 0 07-05-2006 17:09
E770 freeze after unlock,any solution? maxijazz Smart-Clip 2 05-23-2006 11:02
F500i freeze after unlock GoGy TOTAL MultiServer 5 12-20-2004 03:14
J70 freezing after unlock with CTE "SLDefault"?? infogsm Sony 2 10-14-2003 12:09
Page generated in 0.17886 seconds with 9 queries
