Off Topic Zone Here all other messages... |
02-10-2010, 12:26 | #1 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | zfrank Winner58 need help ! how can pc to pc file sharing help. with internet modem with ip address. help i use ptcl modem : zxdsl Last edited by >>.123.<<; 02-10-2010 at 12:32. |
02-10-2010, 12:34 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Mor
Member: 1006514 Status: Offline Thanks Meter: 641 | >>.123.<< : 911 help me 911 : hello what wrong with you >>.123.<< : there an ant on my shop , come help me please !!!!!!!!!!!!!!! 911 : damn ! another stupid caller !!!! it's like this use any server /file / ftp sharing ( google it ) |
02-10-2010, 12:40 | #4 (permalink) | |
Member: 1116719 Status: Offline Thanks Meter: 542 | Quote:
allread use internet but not file sharing how can file sharing ? | |
02-10-2010, 13:02 | #5 (permalink) |
Member: 1006514 Status: Offline Thanks Meter: 641 | Follow these steps on any Windows XP computer to share file resources across a local network. Individual files, an entire folder, or an entire Windows drive can be shared with Windows XP network configuration. Difficulty: Easy Time Required: < 1 minute Here's How:
02-10-2010, 13:06 | #6 (permalink) |
Member: 1006514 Status: Offline Thanks Meter: 641 | and this another tip How to configure a LAN file sharing server In this tutorial, I will show you how to setup a file sharing server on your local Microsoft Network. First of all, to enable sharing on a Microsoft network, all computers that will access a shared resource must be in the same Workgroup or Domain. To check this, go to Control Panel - System. Choose the Computer Name tab like shown bellow and check the Computer name and Workgroup. Computer names must be different in order to identify themselves in the network; they must share the same workgroup to access network resources in that segment. The computer description box is not mandatory; it gives you the possibility to write a small text that will appear next to your computer's name in order to identify it easier on the network (you can put something like "The computer next to the door" for example if that's the case). If you want to do any modifications, choose the Change button and edit any information as needed. Be sure to do this on all the computers, to check if the informations are ok. The next step is to create the sharing directory on the computer that will act as a server. As a best practice, go to the root directory (C:\) and create there a folder that will be shared accross the network. Right click on it and select Sharing and Security. Now select 'Share this folder on the network' and give it a share name. If you have older computers running legacy operating systems like Windows 95/98, give the folder a maximum of 8 charachters in the name. Otherwise, use any name you'd like. If you want to use this folder for uploading purposes too, check the "Allow network users to change my files" box. This will mark the folder with the read/write permissions, and any user accessing the network can put, get and create files in that shared folder. Click Ok and you are done for the server side. As far as the client side, you can find the resource in several ways. The easiest is to use Map network drives. Open an explorer, click Tools Select Map network drive. Choose the letter you want (usually Z and then the path you'd like to use. The path to a shared resource looks like this: \\computername\shared_folder\ Click ok and then Z: will be in the My Computer interface, linking to the shared folder on the network. |
02-10-2010, 13:06 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: philippines
Member: 418718 Status: Offline Sonork: 100.1589777 Thanks Meter: 360 | Quote:
nxt time bro u may search on google first before to make a new thread and cry like a baby who wait for others help | |
02-11-2010, 00:46 | #10 (permalink) |
Freak Poster Join Date: Jul 2009 Location: i life on a planet
Member: 1080766 Status: Offline Sonork: Sonork Thanks Meter: 39 | why you dont just try to send files with yahoo messenger or msn messenger or send by email or ICQ some of this mesengers also provide the possibility to make a shared folder so the partner can choose what the like |
02-11-2010, 11:45 | #11 (permalink) |
Member: 1006514 Status: Offline Thanks Meter: 641 | there are other few link to help you http://support.microsoft.com/kb/304040 http://www.practicallynetworked.com/...ilesharing.htm http://www.theeldergeek.com/quick_gu...le_sharing.htm |
Respective AboAli,Zfrank,Winner58 | syed tuqeer | Board, Server and Login Problems/Support | 2 | 12-30-2010 22:10 |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
need help from winner58 | .::Indian::. | Board, Server and Login Problems/Support | 7 | 06-28-2004 21:55 |
@ Winner58 PLZ help ME45 dead i need MAP THNX | eddiŽ | Phone Unlocking Codes & Maps | 1 | 07-27-2002 02:21 |
