Dreambox repair K800 GDFS without TP I repaired K800 GDFS without TP using new PC setup.This K800 already repaired via TP using my old PC and to my surprise i did it without TP the second time around with new PC.Maybe the box itself recognized the phone that it has been TP'd before. |
can you post the procedure and logs????? |
When you do "Security Bypass" procedure, your phone receives a pre-modified EROM that enables DreamBox features(unlock/repair/fullflash,etc). If you flash MAIN/RAW_FS with DreamBox or any other "normal" software, it will not touch on "DreamBox Modded EROM" installed in your phone and you can always use Security Bypass boot mode. You will lost the Security Bypass boot mode only with you update/repair EROM with non-tp solutions by others softwares, because it writes another patched EROM non compatible with DreamBox functionalities. Then, if you not use non-tp recover solutions you will always get a DreamBox "Security Bypass" compatible phone! Do you like the explanation? Then click "Thanks"! :D THANK YOU! |
