K800 Red Blink but cant attatch got one K800 in red blink condition. but the problem is when i try to attatch/ read info it just started to blink and wont attatch. |
make sure battery has good charge. and try on se tool flash both rj45 and usb. if u have universal box u can also try on that. if u have no look the phone is short circuiting. |
its HW fault............... |
you can try with setools to become sure if you can connect with setool then try again with dream if cant connect try to rehot connect ic and component for connection (hardware) BR Gsmlover |
my brother hitting in flash ic& power then chech by dream box |
hi, k800 redblinking atteched dream box show lick this -- Reading Info--------------------------------------------------------------- User selected phone K800 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone K800 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359087-01-256520-0 OTP CID = 51 Error : Failed. please help how to do |
yes i confirm its a hardware problem. solved just by rehot the flsaher |
