Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 02-16-2010, 12:49   #1 (permalink)
Member: 310423
Thanks Meter: 18
help i cant repair k800 gdfs
can someone help me to write this k800 gdfs pls is urgent
--- Security Bypass------------------------------------------------------------
User selected phone K800 using Security Bypass boot mode
1) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 99000301FFFFFFFF (DB2020 / DB2030)
Sending Application ...
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 359757-01-989869-3
OTP CID = 51
EROM Color = 4 : RED
EROM CID = 53
Baseband Chip ID = 9900
Phone ID = 23804D7D15D0AAF1
Flash Chip : Intel 48F50xxM0Y0
Flash Chip ID : 0089 887E
Boot Responce = 5A
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 51
EROM CID = 53
Finalizing ...
Done.
--- Unlock and Repair----------------------------------------------------------
Boot Responce = 5A
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 51
EROM CID = 53
Reading GDFS...
Error : #3150:004B04BD 76ED85B5 00000001
Error : #3150:004B0475
Error : #3150:0033067C
Error : Failed.
Old 02-16-2010, 13:10   #2 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
--- security bypass------------------------------------------------------------
user selected phone k800 using security bypass boot mode
1) turn off the phone.
2) connect the phone to dreambox cable.
Boot responce = 5a
processor id = 99000301ffffffff (db2020 / db2030)
sending application ...
Nor flash id = 897e
otp status = locked
otp imei = 359757-01-989869-3
otp cid = 51
erom color = 4 : Red
erom cid = 53
baseband chip id = 9900
phone id = 23804d7d15d0aaf1
flash chip : Intel 48f50xxm0y0
flash chip id : 0089 887e
Boot responce = 5a
Nor flash id = 897e
otp status = locked
otp cid = 51
erom cid = 53
finalizing ...
Done.
--- unlock and repair----------------------------------------------------------
Boot responce = 5a
Nor flash id = 897e
otp status = locked
otp cid = 51
erom cid = 53
reading gdfs...
Error : #3150:004b04bd 76ed85b5 00000001
error : #3150:004b0475
error : #3150:0033067c
error : Failed.
br. Your log file shows that you only done 1. Execute security bypass operation 2. Unlock & repair security blocks
did you tryied for write gdfs?
Old 02-16-2010, 13:24   #3 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
Hello!
Tryto write GDFS in DCU60 Access Mode.
Old 02-16-2010, 18:14   #4 (permalink)
Member: 310423
Thanks Meter: 18
Originally Posted by GSM Dream View Post
Hello!
sir thx for ur reply but i still have the same problem
--- Write GDFS-----------------------------------------------------------------
User selected phone K800 using DCU60 boot mode
2) Hold <C> button and connect the phone to DCU60 cable.
Boot Responce = 5A
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 51
EROM CID = 53
Starting CS Loader GDFS Service ...
Error : #3150:004403E3
Error : #3150:00330623
Error : Failed.
Old 02-17-2010, 04:58   #5 (permalink)
Member: 592636
Thanks Meter: 674
u should testing anothere gdfs files
Old 02-17-2010, 09:34   #6 (permalink)
Member: 310423
Thanks Meter: 18
bro i have test three different types of gdfs files the i still get the same problem,so can you pls give link to download different one
Old 02-17-2010, 13:27   #7 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
Looks like hardware issue.
Old 02-17-2010, 15:52   #8 (permalink)
Member: 592636
Thanks Meter: 674
writting full flash files.
some times im tested 5 gdfs files and success
Old 02-19-2010, 14:25   #9 (permalink)
hackerbd's Avatar
Member: 247758
Sonork: 100.1574842
Thanks Meter: 259
If u got error while writing GDFS then its hardware issue.Rehit CPU not (flash ic) and try to write GDFS again.
Dreambox repair K800 GDFS without TP fretburner DreamBox 2 11-11-2009 04:00
Use easy tp1-tp2 repair k800 gdf video Merry DreamBox 2 10-22-2009 18:17
Cant repair W810 GDFS ! need Help URGENTLY PLZ !!!! boulkraa11 Cruiser Suite 1 08-06-2009 20:28
i can't repair k800 GDFS WITH SUPREME CREDIT algeriano_19 Cruiser Suite 4 07-13-2009 10:54
how to repair k800 gdfs damaged alssalafiy DreamBox 11 05-25-2009 04:01
Page generated in 0.21060 seconds with 9 queries
