04-01-2008, 10:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lost in this Field Age: 39
Member: 154513 Status: Offline Thanks Meter: 160 | Unlocked 25 W200 in last night and this Morning check and count DreamBox Team is the best to provide that solution because all credits goes to their team not to us [QUOTE][31/03/2008 21:36:07] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:36:10] User selected phone W200 using Test Point boot mode [31/03/2008 21:36:10] Stage 1 started [31/03/2008 21:36:10] 1) Turn OFF the phone. [31/03/2008 21:36:10] 2) Connect the phone to DreamBox cable. [31/03/2008 21:36:11] Boot Responce = 5A [31/03/2008 21:36:11] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:36:13] NOR Flash ID = 897E [31/03/2008 21:36:13] OTP Status = LOCKED [31/03/2008 21:36:13] OTP IMEI = 357354-01-810818-3 [31/03/2008 21:36:13] OTP CID = 51 [31/03/2008 21:36:13] EROM Color = 4 : RED [31/03/2008 21:36:13] EROM CID = 52 [31/03/2008 21:37:18] Hint : Now the probe might be disconnected [31/03/2008 21:37:28] Processing ... [31/03/2008 21:37:28] Stage 1 completed succesfully [31/03/2008 21:37:29] Stage 2 start [31/03/2008 21:37:53] Timeout detected [31/03/2008 21:37:53] Error : Failed. [31/03/2008 21:37:53] [31/03/2008 21:37:55] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:37:55] User selected phone W200 using Test Point boot mode [31/03/2008 21:37:56] Stage 2 start [31/03/2008 21:38:22] Hint : Now the probe might be disconnected [31/03/2008 21:38:30] Processing... [31/03/2008 21:38:33] Entering Security Bypass mode ... [31/03/2008 21:38:33] 1) Turn OFF the phone. [31/03/2008 21:38:33] 2) Connect the phone to DreamBox cable. [31/03/2008 21:38:34] Boot Responce = 5A [31/03/2008 21:38:34] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:38:36] Baseband Chip ID = 8040 [31/03/2008 21:38:36] Phone ID = 2380EA731520F4C5 [31/03/2008 21:38:36] Finalizing ... [31/03/2008 21:38:39] Stage 2 completed succesfully [31/03/2008 21:38:39] Done. [31/03/2008 21:38:39] [31/03/2008 21:38:45] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 21:38:45] User selected phone W200 using Security Bypass boot mode [31/03/2008 21:38:46] 1) Turn OFF the phone. [31/03/2008 21:38:46] 2) Connect the phone to DreamBox cable. [31/03/2008 21:38:46] Boot Responce = 5A [31/03/2008 21:38:46] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:38:48] Baseband Chip ID = 8040 [31/03/2008 21:38:49] Phone ID = 2380EA731520F4C5 [31/03/2008 21:38:49] Reading GDFS... [31/03/2008 21:38:51] Testing security ... [31/03/2008 21:38:51] GDFS 0013 Hash OK [31/03/2008 21:38:51] GDFS 0006 Hash OK [31/03/2008 21:38:51] GDFS 000E Hash OK [31/03/2008 21:38:51] GDFS 001C Hash OK [31/03/2008 21:38:51] Unlocking ... [31/03/2008 21:38:51] Testing security ... [31/03/2008 21:38:51] GDFS 0013 Hash OK [31/03/2008 21:38:52] GDFS 0006 Hash OK [31/03/2008 21:38:52] GDFS 000E Hash OK [31/03/2008 21:38:52] GDFS 001C Hash OK [31/03/2008 21:38:52] Generating GDFS... [31/03/2008 21:38:52] Writing GDFS... [31/03/2008 21:39:02] Done. [31/03/2008 21:39:02] [31/03/2008 21:42:49] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:42:50] User selected phone W200 using Test Point boot mode [31/03/2008 21:42:50] Stage 1 started [31/03/2008 21:42:50] 1) Turn OFF the phone. [31/03/2008 21:42:50] 2) Connect the phone to DreamBox cable. [31/03/2008 21:42:50] Boot Responce = 5A [31/03/2008 21:42:50] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:42:53] NOR Flash ID = 897E [31/03/2008 21:42:53] OTP Status = LOCKED [31/03/2008 21:42:53] OTP IMEI = 357354-01-927596-5 [31/03/2008 21:42:53] OTP CID = 51 [31/03/2008 21:42:53] EROM Color = 4 : RED [31/03/2008 21:42:53] EROM CID = 52 [31/03/2008 21:43:21] Hint : Now the probe might be disconnected [31/03/2008 21:43:28] Processing ... - [31/03/2008 21:43:28] Error : Testpoint failed. Check pin and try again. [31/03/2008 21:43:28] Error : Failed. [31/03/2008 21:43:28] [31/03/2008 21:43:31] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:43:32] User selected phone W200 using Test Point boot mode [31/03/2008 21:43:32] Stage 1 started [31/03/2008 21:43:32] 1) Turn OFF the phone. [31/03/2008 21:43:32] 2) Connect the phone to DreamBox cable. [31/03/2008 21:43:32] Boot Responce = 5A [31/03/2008 21:43:32] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:43:35] NOR Flash ID = 897E [31/03/2008 21:43:35] OTP Status = LOCKED [31/03/2008 21:43:35] OTP IMEI = 357354-01-927596-5 [31/03/2008 21:43:35] OTP CID = 51 [31/03/2008 21:43:35] EROM Color = 4 : RED [31/03/2008 21:43:35] EROM CID = 52 [31/03/2008 21:43:46] Hint : Now the probe might be disconnected [31/03/2008 21:43:53] Processing ... / [31/03/2008 21:43:53] Error : Testpoint failed. Check pin and try again. [31/03/2008 21:43:53] Error : Failed. [31/03/2008 21:43:53] [31/03/2008 21:43:56] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:43:56] User selected phone W200 using Test Point boot mode [31/03/2008 21:43:57] Stage 1 started [31/03/2008 21:43:57] 1) Turn OFF the phone. [31/03/2008 21:43:57] 2) Connect the phone to DreamBox cable. [31/03/2008 21:43:57] Boot Responce = 5A [31/03/2008 21:43:57] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:43:59] NOR Flash ID = 897E [31/03/2008 21:43:59] OTP Status = LOCKED [31/03/2008 21:43:59] OTP IMEI = 357354-01-927596-5 [31/03/2008 21:43:59] OTP CID = 51 [31/03/2008 21:43:59] EROM Color = 4 : RED [31/03/2008 21:43:59] EROM CID = 52 [31/03/2008 21:44:24] Hint : Now the probe might be disconnected [31/03/2008 21:44:31] Processing ... | [31/03/2008 21:44:31] Error : Testpoint failed. Check pin and try again. [31/03/2008 21:44:31] Error : Failed. [31/03/2008 21:44:31] [31/03/2008 21:44:33] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:44:33] User selected phone W200 using Test Point boot mode [31/03/2008 21:44:34] Stage 1 started [31/03/2008 21:44:34] 1) Turn OFF the phone. [31/03/2008 21:44:34] 2) Connect the phone to DreamBox cable. [31/03/2008 21:44:34] Boot Responce = 5A [31/03/2008 21:44:34] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 21:44:36] NOR Flash ID = 897E [31/03/2008 21:44:36] OTP Status = LOCKED [31/03/2008 21:44:36] OTP IMEI = 357354-01-927596-5 [31/03/2008 21:44:36] OTP CID = 51 [31/03/2008 21:44:36] EROM Color = 4 : RED [31/03/2008 21:44:36] EROM CID = 52 [31/03/2008 21:44:57] Hint : Now the probe might be disconnected [31/03/2008 21:45:07] Processing ... [31/03/2008 21:45:07] Stage 1 completed succesfully [31/03/2008 21:45:08] Stage 2 start [31/03/2008 21:47:24] Timeout detected [31/03/2008 21:47:24] Error : Failed. [31/03/2008 21:47:24] [31/03/2008 21:47:28] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:47:28] User selected phone W200 using Test Point boot mode [31/03/2008 21:47:29] Stage 2 start [31/03/2008 21:48:23] Timeout detected [31/03/2008 21:48:23] Error : Failed. [31/03/2008 21:48:23] [31/03/2008 21:48:25] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:48:25] User selected phone W200 using Test Point boot mode [31/03/2008 21:48:26] Stage 2 start [31/03/2008 21:48:45] Timeout detected [31/03/2008 21:48:45] Error : Failed. [31/03/2008 21:48:45] [31/03/2008 21:48:47] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:48:47] User selected phone W200 using Test Point boot mode [31/03/2008 21:48:49] Stage 2 start [31/03/2008 21:49:45] Timeout detected [31/03/2008 21:49:45] Error : Failed. [31/03/2008 21:49:45] [31/03/2008 21:49:48] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:49:48] User selected phone W200 using Test Point boot mode [31/03/2008 21:49:49] Stage 2 start [31/03/2008 21:50:07] Timeout detected [31/03/2008 21:50:07] Error : Failed. [31/03/2008 21:50:07] [31/03/2008 21:50:09] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:50:09] User selected phone W200 using Test Point boot mode [31/03/2008 21:50:10] Stage 2 start [31/03/2008 21:50:27] Timeout detected [31/03/2008 21:50:27] Error : Failed. [31/03/2008 21:50:27] [31/03/2008 21:50:34] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:50:34] User selected phone W200 using Test Point boot mode [31/03/2008 21:50:35] Stage 2 start [31/03/2008 21:50:54] Timeout detected [31/03/2008 21:50:54] Error : Failed. [31/03/2008 21:50:54] [31/03/2008 21:53:10] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:53:10] User selected phone W200 using Test Point boot mode [31/03/2008 21:53:11] Stage 2 start [31/03/2008 21:53:41] Timeout detected [31/03/2008 21:53:41] Error : Failed. [31/03/2008 21:53:41] [31/03/2008 21:53:47] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:53:47] User selected phone W200 using Test Point boot mode [31/03/2008 21:53:48] Stage 2 start [31/03/2008 21:54:11] Timeout detected [31/03/2008 21:54:11] Error : Failed. [31/03/2008 21:54:11] [31/03/2008 21:54:47] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:54:47] User selected phone W200 using Test Point boot mode [31/03/2008 21:54:48] Stage 2 start [31/03/2008 21:55:01] Timeout detected [31/03/2008 21:55:01] Error : Failed. [31/03/2008 21:55:01] [31/03/2008 21:55:03] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:55:03] User selected phone W200 using Test Point boot mode [31/03/2008 21:55:04] Stage 2 start [31/03/2008 21:58:00] [31/03/2008 21:58:00] DBSS Start 3.1.2 [31/03/2008 21:58:05] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:58:08] User selected phone W200 using Test Point boot mode [31/03/2008 21:58:09] Stage 2 start [31/03/2008 21:58:24] Warning : Aborted by user. [31/03/2008 21:58:24] [31/03/2008 21:58:25] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:58:25] User selected phone W200 using Test Point boot mode [31/03/2008 21:58:26] Stage 2 start [31/03/2008 21:58:43] Timeout detected [31/03/2008 21:58:43] Error : Failed. [31/03/2008 21:58:43] [31/03/2008 21:58:44] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:58:45] User selected phone W200 using Test Point boot mode [31/03/2008 21:58:46] Stage 2 start [31/03/2008 21:59:03] Timeout detected [31/03/2008 21:59:04] Error : Failed. [31/03/2008 21:59:04] [31/03/2008 21:59:06] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:59:06] User selected phone W200 using Test Point boot mode [31/03/2008 21:59:07] Stage 2 start [31/03/2008 21:59:51] Timeout detected [31/03/2008 21:59:51] Error : Failed. [31/03/2008 21:59:51] [31/03/2008 21:59:52] --- Security Bypass------------------------------------------------------------ [31/03/2008 21:59:52] User selected phone W200 using Test Point boot mode [31/03/2008 21:59:53] Stage 2 start [31/03/2008 22:00:31] Timeout detected [31/03/2008 22:00:31] Error : Failed. [31/03/2008 22:00:31] [31/03/2008 22:01:57] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:01:57] User selected phone W200 using Test Point boot mode [31/03/2008 22:01:57] Stage 1 started [31/03/2008 22:01:57] 1) Turn OFF the phone. [31/03/2008 22:01:57] 2) Connect the phone to DreamBox cable. [31/03/2008 22:01:59] Boot Responce = 5A [31/03/2008 22:02:10] Warning : Aborted by user. [31/03/2008 22:02:10] [31/03/2008 22:02:12] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:02:12] User selected phone W200 using Test Point boot mode [31/03/2008 22:02:12] Stage 1 started [31/03/2008 22:02:12] 1) Turn OFF the phone. [31/03/2008 22:02:12] 2) Connect the phone to DreamBox cable. [31/03/2008 22:02:13] Boot Responce = 5A [31/03/2008 22:02:13] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:02:15] NOR Flash ID = 897E [31/03/2008 22:02:15] OTP Status = LOCKED [31/03/2008 22:02:15] OTP IMEI = 357354-01-729306-9 [31/03/2008 22:02:15] OTP CID = 51 [31/03/2008 22:02:15] EROM Color = 4 : RED [31/03/2008 22:02:15] EROM CID = 52 [31/03/2008 22:03:21] Error : Failed. [31/03/2008 22:03:21] [31/03/2008 22:04:55] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:04:55] User selected phone W200 using Test Point boot mode [31/03/2008 22:04:56] Stage 1 started [31/03/2008 22:04:56] 1) Turn OFF the phone. [31/03/2008 22:04:56] 2) Connect the phone to DreamBox cable. [31/03/2008 22:04:56] Boot Responce = 5A [31/03/2008 22:04:56] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:04:58] NOR Flash ID = 897E [31/03/2008 22:04:59] OTP Status = LOCKED [31/03/2008 22:04:59] OTP IMEI = 357354-01-729306-9 [31/03/2008 22:04:59] OTP CID = 51 [31/03/2008 22:04:59] EROM Color = 4 : RED [31/03/2008 22:04:59] EROM CID = 52 [31/03/2008 22:05:13] Hint : Now the probe might be disconnected [31/03/2008 22:05:21] Processing ... | [31/03/2008 22:05:21] Error : Testpoint failed. Check pin and try again. [31/03/2008 22:05:21] Error : Failed. [31/03/2008 22:05:21] [31/03/2008 22:05:23] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:05:24] User selected phone W200 using Test Point boot mode [31/03/2008 22:05:24] Stage 1 started [31/03/2008 22:05:24] 1) Turn OFF the phone. [31/03/2008 22:05:24] 2) Connect the phone to DreamBox cable. [31/03/2008 22:05:24] Boot Responce = 5A [31/03/2008 22:05:24] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:05:27] NOR Flash ID = 897E [31/03/2008 22:05:27] OTP Status = LOCKED [31/03/2008 22:05:27] OTP IMEI = 357354-01-729306-9 [31/03/2008 22:05:27] OTP CID = 51 [31/03/2008 22:05:27] EROM Color = 4 : RED [31/03/2008 22:05:27] EROM CID = 52 [31/03/2008 22:05:40] Hint : Now the probe might be disconnected [31/03/2008 22:05:47] Processing ... \ [31/03/2008 22:05:47] Error : Testpoint failed. Check pin and try again. [31/03/2008 22:05:47] Error : Failed. [31/03/2008 22:05:47] [31/03/2008 22:05:49] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:05:49] User selected phone W200 using Test Point boot mode [31/03/2008 22:05:50] Stage 1 started [31/03/2008 22:05:50] 1) Turn OFF the phone. [31/03/2008 22:05:50] 2) Connect the phone to DreamBox cable. [31/03/2008 22:05:50] Boot Responce = 5A [31/03/2008 22:05:50] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:05:52] NOR Flash ID = 897E [31/03/2008 22:05:52] OTP Status = LOCKED [31/03/2008 22:05:52] OTP IMEI = 357354-01-729306-9 [31/03/2008 22:05:52] OTP CID = 51 [31/03/2008 22:05:52] EROM Color = 4 : RED [31/03/2008 22:05:52] EROM CID = 52 [31/03/2008 22:06:07] Hint : Now the probe might be disconnected [31/03/2008 22:06:18] Processing ... [31/03/2008 22:06:18] Stage 1 completed succesfully [31/03/2008 22:06:18] Stage 2 start [31/03/2008 22:06:31] Hint : Now the probe might be disconnected [31/03/2008 22:06:40] Processing... [31/03/2008 22:06:43] Entering Security Bypass mode ... [31/03/2008 22:06:43] 1) Turn OFF the phone. [31/03/2008 22:06:43] 2) Connect the phone to DreamBox cable. [31/03/2008 22:06:43] Boot Responce = 5A [31/03/2008 22:06:43] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:06:46] Baseband Chip ID = 8040 [31/03/2008 22:06:46] Phone ID = 2380EA7315A00DB2 [31/03/2008 22:06:46] Finalizing ... [31/03/2008 22:06:48] Stage 2 completed succesfully [31/03/2008 22:06:48] Done. [31/03/2008 22:06:48] [31/03/2008 22:06:52] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 22:06:52] User selected phone W200 using Security Bypass boot mode [31/03/2008 22:06:52] 1) Turn OFF the phone. [31/03/2008 22:06:52] 2) Connect the phone to DreamBox cable. [31/03/2008 22:06:52] Boot Responce = 5A [31/03/2008 22:06:52] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:06:55] Baseband Chip ID = 8040 [31/03/2008 22:06:55] Phone ID = 2380EA7315A00DB2 [31/03/2008 22:06:55] Reading GDFS... [31/03/2008 22:06:57] Testing security ... [31/03/2008 22:06:57] GDFS 0013 Hash OK [31/03/2008 22:06:57] GDFS 0006 Hash OK [31/03/2008 22:06:57] GDFS 000E Hash OK [31/03/2008 22:06:57] GDFS 001C Hash OK [31/03/2008 22:06:57] Unlocking ... [31/03/2008 22:06:58] Testing security ... [31/03/2008 22:06:58] GDFS 0013 Hash OK [31/03/2008 22:06:58] GDFS 0006 Hash OK [31/03/2008 22:06:58] GDFS 000E Hash OK [31/03/2008 22:06:58] GDFS 001C Hash OK [31/03/2008 22:06:58] Generating GDFS... [31/03/2008 22:06:58] Writing GDFS... [31/03/2008 22:07:08] Done. [31/03/2008 22:07:08] [31/03/2008 22:09:50] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:09:50] User selected phone W200 using Test Point boot mode [31/03/2008 22:09:52] Stage 2 start [31/03/2008 22:10:17] Timeout detected [31/03/2008 22:10:17] Error : Failed. [31/03/2008 22:10:17] [31/03/2008 22:10:18] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:10:18] User selected phone W200 using Test Point boot mode [31/03/2008 22:10:19] Stage 2 start [31/03/2008 22:10:47] Timeout detected [31/03/2008 22:10:47] Error : Failed. [31/03/2008 22:10:47] [31/03/2008 22:10:50] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:10:50] User selected phone W200 using Test Point boot mode [31/03/2008 22:10:51] Stage 2 start [31/03/2008 22:12:39] Warning : Aborted by user. [31/03/2008 22:12:39] [31/03/2008 22:12:40] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:12:40] User selected phone W200 using Test Point boot mode [31/03/2008 22:12:41] Stage 2 start [31/03/2008 22:13:33] Warning : Aborted by user. [31/03/2008 22:13:33] [31/03/2008 22:13:34] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:13:34] User selected phone W200 using Test Point boot mode [31/03/2008 22:13:35] Stage 2 start [31/03/2008 22:14:04] Warning : Aborted by user. [31/03/2008 22:14:04] [31/03/2008 22:14:05] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:14:05] User selected phone W200 using Test Point boot mode [31/03/2008 22:14:06] Stage 2 start [31/03/2008 22:14:36] Timeout detected [31/03/2008 22:14:36] Error : Failed. [31/03/2008 22:14:36] [31/03/2008 22:14:37] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:14:37] User selected phone W200 using Test Point boot mode [31/03/2008 22:14:38] Stage 2 start [31/03/2008 22:15:00] Warning : Aborted by user. [31/03/2008 22:15:00] [31/03/2008 22:15:01] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:15:01] User selected phone W200 using Test Point boot mode [31/03/2008 22:15:02] Stage 2 start [31/03/2008 22:15:21] Timeout detected [31/03/2008 22:15:21] Error : Failed. [31/03/2008 22:15:21] [31/03/2008 22:15:23] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:15:23] User selected phone W200 using Test Point boot mode [31/03/2008 22:15:24] Stage 2 start [31/03/2008 22:15:47] Timeout detected [31/03/2008 22:15:47] Error : Failed. [31/03/2008 22:15:47] [31/03/2008 22:15:52] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:15:52] User selected phone W200 using Test Point boot mode [31/03/2008 22:15:53] Stage 2 start [31/03/2008 22:16:11] Warning : Aborted by user. [31/03/2008 22:16:11] [31/03/2008 22:16:13] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:16:13] User selected phone W200 using Test Point boot mode [31/03/2008 22:16:15] Stage 2 start [31/03/2008 22:16:38] Timeout detected [31/03/2008 22:16:38] Error : Failed. [31/03/2008 22:16:38] [31/03/2008 22:17:07] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:17:07] User selected phone W200 using Test Point boot mode [31/03/2008 22:17:08] Stage 2 start [31/03/2008 22:19:55] Error : Failed. [31/03/2008 22:19:55] [31/03/2008 22:19:56] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:19:56] User selected phone W200 using Test Point boot mode [31/03/2008 22:19:57] Stage 2 start [31/03/2008 22:20:31] Hint : Now the probe might be disconnected [31/03/2008 22:20:39] Processing... [31/03/2008 22:20:43] Entering Security Bypass mode ... [31/03/2008 22:20:43] 1) Turn OFF the phone. [31/03/2008 22:20:43] 2) Connect the phone to DreamBox cable. [31/03/2008 22:20:43] Boot Responce = 5A [31/03/2008 22:20:43] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:20:45] Baseband Chip ID = 8040 [31/03/2008 22:20:45] Phone ID = 2380EA7315C076E2 [31/03/2008 22:20:46] Finalizing ... [31/03/2008 22:20:48] Stage 2 completed succesfully [31/03/2008 22:20:48] Done. [31/03/2008 22:20:48] [31/03/2008 22:20:52] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 22:20:52] User selected phone W200 using Security Bypass boot mode [31/03/2008 22:20:52] 1) Turn OFF the phone. [31/03/2008 22:20:52] 2) Connect the phone to DreamBox cable. [31/03/2008 22:20:53] Boot Responce = 5A [31/03/2008 22:20:53] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:20:55] Baseband Chip ID = 8040 [31/03/2008 22:20:55] Phone ID = 2380EA7315C076E2 [31/03/2008 22:20:55] Reading GDFS... [31/03/2008 22:20:57] Testing security ... [31/03/2008 22:20:57] GDFS 0013 Hash OK [31/03/2008 22:20:57] GDFS 0006 Hash OK [31/03/2008 22:20:57] GDFS 000E Hash OK [31/03/2008 22:20:57] GDFS 001C Hash OK [31/03/2008 22:20:57] Unlocking ... [31/03/2008 22:20:58] Testing security ... [31/03/2008 22:20:58] GDFS 0013 Hash OK [31/03/2008 22:20:58] GDFS 0006 Hash OK [31/03/2008 22:20:58] GDFS 000E Hash OK [31/03/2008 22:20:58] GDFS 001C Hash OK [31/03/2008 22:20:58] Generating GDFS... [31/03/2008 22:20:58] Writing GDFS... [31/03/2008 22:21:08] Done. [31/03/2008 22:21:08] [31/03/2008 22:26:46] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:26:46] User selected phone W200 using Test Point boot mode [31/03/2008 22:26:47] Stage 1 started [31/03/2008 22:26:47] 1) Turn OFF the phone. [31/03/2008 22:26:47] 2) Connect the phone to DreamBox cable. [31/03/2008 22:26:47] Boot Responce = 5A [31/03/2008 22:26:47] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:26:49] NOR Flash ID = 897E [31/03/2008 22:26:49] OTP Status = LOCKED [31/03/2008 22:26:49] OTP IMEI = 357354-01-927418-2 [31/03/2008 22:26:49] OTP CID = 51 [31/03/2008 22:26:49] EROM Color = 4 : RED [31/03/2008 22:26:49] EROM CID = 52 [31/03/2008 22:33:36] Error : Failed. [31/03/2008 22:33:36] [31/03/2008 22:33:37] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:33:37] User selected phone W200 using Test Point boot mode [31/03/2008 22:33:37] Stage 1 started [31/03/2008 22:33:37] 1) Turn OFF the phone. [31/03/2008 22:33:37] 2) Connect the phone to DreamBox cable. [31/03/2008 22:33:38] Boot Responce = 5A [31/03/2008 22:33:38] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:33:40] NOR Flash ID = 897E [31/03/2008 22:33:40] OTP Status = LOCKED [31/03/2008 22:33:40] OTP IMEI = 357354-01-927418-2 [31/03/2008 22:33:40] OTP CID = 51 [31/03/2008 22:33:40] EROM Color = 4 : RED [31/03/2008 22:33:40] EROM CID = 52 [31/03/2008 22:33:57] Hint : Now the probe might be disconnected [31/03/2008 22:34:07] Processing ... [31/03/2008 22:34:07] Stage 1 completed succesfully [31/03/2008 22:34:08] Stage 2 start [31/03/2008 22:37:13] Error : Failed. [31/03/2008 22:37:13] [31/03/2008 22:37:14] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:37:15] User selected phone W200 using Test Point boot mode [31/03/2008 22:37:16] Stage 2 start [31/03/2008 22:39:56] Error : Failed. [31/03/2008 22:39:56] [31/03/2008 22:40:04] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:40:04] User selected phone W200 using Test Point boot mode [31/03/2008 22:40:06] Stage 2 start [31/03/2008 22:43:04] Error : Failed. [31/03/2008 22:43:04] [31/03/2008 22:43:05] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:43:05] User selected phone W200 using Test Point boot mode [31/03/2008 22:43:06] Stage 2 start [31/03/2008 22:43:27] Hint : Now the probe might be disconnected [31/03/2008 22:43:36] Processing... [31/03/2008 22:43:39] Entering Security Bypass mode ... [31/03/2008 22:43:39] 1) Turn OFF the phone. [31/03/2008 22:43:39] 2) Connect the phone to DreamBox cable. [31/03/2008 22:43:39] Boot Responce = 5A [31/03/2008 22:43:39] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:43:42] Baseband Chip ID = 8040 [31/03/2008 22:43:42] Phone ID = 2380EA7315A06BE2 [31/03/2008 22:43:42] Finalizing ... [31/03/2008 22:43:44] Stage 2 completed succesfully [31/03/2008 22:43:44] Done. [31/03/2008 22:43:44] [31/03/2008 22:43:50] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 22:43:50] User selected phone W200 using Security Bypass boot mode [31/03/2008 22:43:51] 1) Turn OFF the phone. [31/03/2008 22:43:51] 2) Connect the phone to DreamBox cable. [31/03/2008 22:43:51] Boot Responce = 5A [31/03/2008 22:43:51] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:43:53] Baseband Chip ID = 8040 [31/03/2008 22:43:53] Phone ID = 2380EA7315A06BE2 [31/03/2008 22:43:53] Reading GDFS... [31/03/2008 22:43:55] Testing security ... [31/03/2008 22:43:56] GDFS 0013 Hash OK [31/03/2008 22:43:56] GDFS 0006 Hash OK [31/03/2008 22:43:56] GDFS 000E Hash OK [31/03/2008 22:43:56] GDFS 001C Hash OK [31/03/2008 22:43:56] Unlocking ... [31/03/2008 22:43:56] Testing security ... [31/03/2008 22:43:56] GDFS 0013 Hash OK [31/03/2008 22:43:56] GDFS 0006 Hash OK [31/03/2008 22:43:56] GDFS 000E Hash OK [31/03/2008 22:43:56] GDFS 001C Hash OK [31/03/2008 22:43:56] Generating GDFS... [31/03/2008 22:43:57] Writing GDFS... [31/03/2008 22:44:07] Done. [31/03/2008 22:44:07] [31/03/2008 22:47:14] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:47:15] User selected phone W200 using Test Point boot mode [31/03/2008 22:47:15] Stage 1 started [31/03/2008 22:47:15] 1) Turn OFF the phone. [31/03/2008 22:47:15] 2) Connect the phone to DreamBox cable. [31/03/2008 22:47:15] Boot Responce = 5A [31/03/2008 22:47:15] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:47:18] NOR Flash ID = 897E [31/03/2008 22:47:18] OTP Status = LOCKED [31/03/2008 22:47:18] OTP IMEI = 357354-01-927758-1 [31/03/2008 22:47:18] OTP CID = 51 [31/03/2008 22:47:18] EROM Color = 4 : RED [31/03/2008 22:47:18] EROM CID = 52 [31/03/2008 22:47:38] Hint : Now the probe might be disconnected [31/03/2008 22:47:49] Processing ... [31/03/2008 22:47:49] Stage 1 completed succesfully [31/03/2008 22:47:49] Stage 2 start [31/03/2008 22:48:11] Warning : Aborted by user. [31/03/2008 22:48:11] [31/03/2008 22:48:12] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:48:12] User selected phone W200 using Test Point boot mode [31/03/2008 22:48:12] Stage 1 started [31/03/2008 22:48:12] 1) Turn OFF the phone. [31/03/2008 22:48:12] 2) Connect the phone to DreamBox cable. [31/03/2008 22:48:13] Boot Responce = 5A [31/03/2008 22:48:13] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:48:15] NOR Flash ID = 897E [31/03/2008 22:48:15] OTP Status = LOCKED [31/03/2008 22:48:15] OTP IMEI = 357354-01-927758-1 [31/03/2008 22:48:15] OTP CID = 51 [31/03/2008 22:48:15] EROM Color = 4 : RED [31/03/2008 22:48:15] EROM CID = 52 [31/03/2008 22:48:23] Hint : Now the probe might be disconnected [31/03/2008 22:48:31] Processing ... / [31/03/2008 22:48:31] Error : Testpoint failed. Check pin and try again. [31/03/2008 22:48:31] Error : Failed. [31/03/2008 22:48:31] [31/03/2008 22:48:35] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:48:36] User selected phone W200 using Test Point boot mode [31/03/2008 22:48:37] Stage 2 start [31/03/2008 22:48:58] Hint : Now the probe might be disconnected [31/03/2008 22:49:06] Processing... [31/03/2008 22:49:10] Entering Security Bypass mode ... [31/03/2008 22:49:10] 1) Turn OFF the phone. [31/03/2008 22:49:10] 2) Connect the phone to DreamBox cable. [31/03/2008 22:49:10] Boot Responce = 5A [31/03/2008 22:49:10] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:49:12] Baseband Chip ID = 8040 [31/03/2008 22:49:12] Phone ID = 2380EA7315E080E2 [31/03/2008 22:49:12] Finalizing ... [31/03/2008 22:49:14] Stage 2 completed succesfully [31/03/2008 22:49:14] Done. [31/03/2008 22:49:14] [31/03/2008 22:49:19] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 22:49:19] User selected phone W200 using Security Bypass boot mode [31/03/2008 22:49:20] 1) Turn OFF the phone. [31/03/2008 22:49:20] 2) Connect the phone to DreamBox cable. [31/03/2008 22:49:20] Boot Responce = 5A [31/03/2008 22:49:20] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:49:22] Baseband Chip ID = 8040 [31/03/2008 22:49:22] Phone ID = 2380EA7315E080E2 [31/03/2008 22:49:22] Reading GDFS... [31/03/2008 22:49:24] Testing security ... [31/03/2008 22:49:25] GDFS 0013 Hash OK [31/03/2008 22:49:25] GDFS 0006 Hash OK [31/03/2008 22:49:25] GDFS 000E Hash OK [31/03/2008 22:49:25] GDFS 001C Hash OK [31/03/2008 22:49:25] Unlocking ... [31/03/2008 22:49:25] Testing security ... [31/03/2008 22:49:25] GDFS 0013 Hash OK [31/03/2008 22:49:25] GDFS 0006 Hash OK [31/03/2008 22:49:25] GDFS 000E Hash OK [31/03/2008 22:49:25] GDFS 001C Hash OK [31/03/2008 22:49:25] Generating GDFS... [31/03/2008 22:49:26] Writing GDFS... [31/03/2008 22:49:35] Done. [31/03/2008 22:49:35] [31/03/2008 22:52:27] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:52:27] User selected phone W200 using Test Point boot mode [31/03/2008 22:52:28] Stage 1 started [31/03/2008 22:52:28] 1) Turn OFF the phone. [31/03/2008 22:52:28] 2) Connect the phone to DreamBox cable. [31/03/2008 22:52:28] Boot Responce = 5A [31/03/2008 22:52:55] Warning : Aborted by user. [31/03/2008 22:52:55] [31/03/2008 22:52:57] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:52:57] User selected phone W200 using Test Point boot mode [31/03/2008 22:52:58] Stage 1 started [31/03/2008 22:52:58] 1) Turn OFF the phone. [31/03/2008 22:52:58] 2) Connect the phone to DreamBox cable. [31/03/2008 22:52:58] Boot Responce = 5A [31/03/2008 22:52:58] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:53:00] NOR Flash ID = 897E [31/03/2008 22:53:00] OTP Status = LOCKED [31/03/2008 22:53:00] OTP IMEI = 357354-01-926962-0 [31/03/2008 22:53:00] OTP CID = 51 [31/03/2008 22:53:01] EROM Color = 4 : RED [31/03/2008 22:53:01] EROM CID = 52 [31/03/2008 22:53:39] Hint : Now the probe might be disconnected [31/03/2008 22:53:46] Processing ... | [31/03/2008 22:53:46] Error : Testpoint failed. Check pin and try again. [31/03/2008 22:53:46] Error : Failed. [31/03/2008 22:53:46] [31/03/2008 22:53:49] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:53:49] User selected phone W200 using Test Point boot mode [31/03/2008 22:53:49] Stage 1 started [31/03/2008 22:53:49] 1) Turn OFF the phone. [31/03/2008 22:53:49] 2) Connect the phone to DreamBox cable. [31/03/2008 22:53:50] Boot Responce = 5A [31/03/2008 22:53:50] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 22:53:52] NOR Flash ID = 897E [31/03/2008 22:53:52] OTP Status = LOCKED [31/03/2008 22:53:52] OTP IMEI = 357354-01-926962-0 [31/03/2008 22:53:52] OTP CID = 51 [31/03/2008 22:53:52] EROM Color = 4 : RED [31/03/2008 22:53:52] EROM CID = 52 [31/03/2008 22:54:06] Hint : Now the probe might be disconnected [31/03/2008 22:54:16] Processing ... [31/03/2008 22:54:16] Stage 1 completed succesfully [31/03/2008 22:54:16] Stage 2 start [31/03/2008 22:59:20] Error : Failed. [31/03/2008 22:59:20] [31/03/2008 22:59:21] --- Security Bypass------------------------------------------------------------ [31/03/2008 22:59:21] User selected phone W200 using Test Point boot mode [31/03/2008 22:59:22] Stage 2 start [31/03/2008 23:02:37] Error : Failed. [31/03/2008 23:02:37] [31/03/2008 23:02:38] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:02:38] User selected phone W200 using Test Point boot mode [31/03/2008 23:02:39] Stage 2 start [31/03/2008 23:03:10] Hint : Now the probe might be disconnected [31/03/2008 23:03:18] Processing... [31/03/2008 23:03:21] Entering Security Bypass mode ... [31/03/2008 23:03:21] 1) Turn OFF the phone. [31/03/2008 23:03:21] 2) Connect the phone to DreamBox cable. [31/03/2008 23:03:21] Boot Responce = 5A [31/03/2008 23:03:21] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:03:24] Baseband Chip ID = 8040 [31/03/2008 23:03:24] Phone ID = 2380EA7315204FE2 [31/03/2008 23:03:24] Finalizing ... [31/03/2008 23:03:26] Stage 2 completed succesfully [31/03/2008 23:03:26] Done. [31/03/2008 23:03:26] [31/03/2008 23:03:29] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 23:03:29] User selected phone W200 using Security Bypass boot mode [31/03/2008 23:03:29] 1) Turn OFF the phone. [31/03/2008 23:03:29] 2) Connect the phone to DreamBox cable. [31/03/2008 23:03:30] Boot Responce = 5A [31/03/2008 23:03:30] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:03:32] Baseband Chip ID = 8040 [31/03/2008 23:03:32] Phone ID = 2380EA7315204FE2 [31/03/2008 23:03:32] Reading GDFS... [31/03/2008 23:03:34] Testing security ... [31/03/2008 23:03:34] GDFS 0013 Hash OK [31/03/2008 23:03:34] GDFS 0006 Hash OK [31/03/2008 23:03:34] GDFS 000E Hash OK [31/03/2008 23:03:34] GDFS 001C Hash OK [31/03/2008 23:03:34] Unlocking ... [31/03/2008 23:03:35] Testing security ... [31/03/2008 23:03:35] GDFS 0013 Hash OK [31/03/2008 23:03:35] GDFS 0006 Hash OK [31/03/2008 23:03:35] GDFS 000E Hash OK [31/03/2008 23:03:35] GDFS 001C Hash OK [31/03/2008 23:03:35] Generating GDFS... [31/03/2008 23:03:35] Writing GDFS... [31/03/2008 23:03:45] Done. [31/03/2008 23:03:45] [31/03/2008 23:07:31] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:07:31] User selected phone W200 using Test Point boot mode [31/03/2008 23:07:32] Stage 1 started [31/03/2008 23:07:32] 1) Turn OFF the phone. [31/03/2008 23:07:32] 2) Connect the phone to DreamBox cable. [31/03/2008 23:07:32] Boot Responce = 5A [31/03/2008 23:07:32] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:07:34] NOR Flash ID = 897E [31/03/2008 23:07:35] OTP Status = LOCKED [31/03/2008 23:07:35] OTP IMEI = 359707-01-920072-1 [31/03/2008 23:07:35] OTP CID = 51 [31/03/2008 23:07:35] EROM Color = 4 : RED [31/03/2008 23:07:35] EROM CID = 52 [31/03/2008 23:08:03] Hint : Now the probe might be disconnected [31/03/2008 23:08:13] Processing ... [31/03/2008 23:08:13] Stage 1 completed succesfully [31/03/2008 23:08:14] Stage 2 start [31/03/2008 23:08:53] Hint : Now the probe might be disconnected [31/03/2008 23:09:35] Warning : Aborted by user. [31/03/2008 23:09:35] [31/03/2008 23:09:37] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:09:37] User selected phone W200 using Test Point boot mode [31/03/2008 23:09:38] Stage 2 start [31/03/2008 23:10:03] Timeout detected [31/03/2008 23:10:03] Error : Failed. [31/03/2008 23:10:03] [31/03/2008 23:10:06] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:10:06] User selected phone W200 using Test Point boot mode [31/03/2008 23:10:07] Stage 2 start [31/03/2008 23:11:21] Timeout detected [31/03/2008 23:11:21] Error : Failed. [31/03/2008 23:11:21] [31/03/2008 23:11:23] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:11:23] User selected phone W200 using Test Point boot mode [31/03/2008 23:11:24] Stage 2 start [31/03/2008 23:11:52] Timeout detected [31/03/2008 23:11:52] Error : Failed. [31/03/2008 23:11:52] [31/03/2008 23:11:55] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:11:55] User selected phone W200 using Test Point boot mode [31/03/2008 23:11:56] Stage 2 start [31/03/2008 23:12:20] Timeout detected [31/03/2008 23:12:20] Error : Failed. [31/03/2008 23:12:20] [31/03/2008 23:13:37] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:13:37] User selected phone W200 using Test Point boot mode [31/03/2008 23:13:39] Stage 2 start [31/03/2008 23:14:24] Timeout detected [31/03/2008 23:14:24] Error : Failed. [31/03/2008 23:14:24] [31/03/2008 23:14:25] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:14:25] User selected phone W200 using Test Point boot mode [31/03/2008 23:14:27] Stage 2 start [31/03/2008 23:14:43] Warning : Aborted by user. [31/03/2008 23:14:43] [31/03/2008 23:14:44] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:14:44] User selected phone W200 using Test Point boot mode [31/03/2008 23:14:45] Stage 2 start [31/03/2008 23:18:22] Warning : Aborted by user. [31/03/2008 23:18:22] [31/03/2008 23:18:33] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:18:33] User selected phone W200 using Test Point boot mode [31/03/2008 23:18:34] Stage 2 start [31/03/2008 23:18:55] Hint : Now the probe might be disconnected [31/03/2008 23:19:03] Processing... [31/03/2008 23:19:06] Entering Security Bypass mode ... [31/03/2008 23:19:06] 1) Turn OFF the phone. [31/03/2008 23:19:06] 2) Connect the phone to DreamBox cable. [31/03/2008 23:19:07] Boot Responce = 5A [31/03/2008 23:19:07] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:19:09] Baseband Chip ID = 8040 [31/03/2008 23:19:09] Phone ID = 23801B7D1580A0E0 [31/03/2008 23:19:09] Finalizing ... [31/03/2008 23:19:11] Stage 2 completed succesfully [31/03/2008 23:19:11] Done. [31/03/2008 23:19:11] [31/03/2008 23:19:15] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 23:19:15] User selected phone W200 using Security Bypass boot mode [31/03/2008 23:19:16] 1) Turn OFF the phone. [31/03/2008 23:19:16] 2) Connect the phone to DreamBox cable. [31/03/2008 23:19:16] Boot Responce = 5A [31/03/2008 23:19:16] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:19:18] Baseband Chip ID = 8040 [31/03/2008 23:19:18] Phone ID = 23801B7D1580A0E0 [31/03/2008 23:19:18] Reading GDFS... [31/03/2008 23:19:20] Testing security ... [31/03/2008 23:19:21] GDFS 0013 Hash OK [31/03/2008 23:19:21] GDFS 0006 Hash OK [31/03/2008 23:19:21] GDFS 000E Hash OK [31/03/2008 23:19:21] GDFS 001C Hash OK [31/03/2008 23:19:21] Unlocking ... [31/03/2008 23:19:21] Testing security ... [31/03/2008 23:19:21] GDFS 0013 Hash OK [31/03/2008 23:19:21] GDFS 0006 Hash OK [31/03/2008 23:19:21] GDFS 000E Hash OK [31/03/2008 23:19:21] GDFS 001C Hash OK [31/03/2008 23:19:21] Generating GDFS... [31/03/2008 23:19:21] Writing GDFS... [31/03/2008 23:19:31] Done. [31/03/2008 23:19:31] [31/03/2008 23:21:36] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:21:36] User selected phone W200 using Test Point boot mode [31/03/2008 23:21:37] Stage 1 started [31/03/2008 23:21:37] 1) Turn OFF the phone. [31/03/2008 23:21:37] 2) Connect the phone to DreamBox cable. [31/03/2008 23:21:37] Boot Responce = 5A [31/03/2008 23:21:37] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:21:39] NOR Flash ID = 897E [31/03/2008 23:21:39] OTP Status = LOCKED [31/03/2008 23:21:39] OTP IMEI = 357354-01-810760-7 [31/03/2008 23:21:39] OTP CID = 51 [31/03/2008 23:21:39] EROM Color = 4 : RED [31/03/2008 23:21:39] EROM CID = 52 [31/03/2008 23:22:14] Hint : Now the probe might be disconnected [31/03/2008 23:22:24] Processing ... [31/03/2008 23:22:24] Stage 1 completed succesfully [31/03/2008 23:22:25] Stage 2 start [31/03/2008 23:23:36] Warning : Aborted by user. [31/03/2008 23:23:36] [31/03/2008 23:23:37] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:23:37] User selected phone W200 using Test Point boot mode [31/03/2008 23:23:37] Stage 1 started [31/03/2008 23:23:38] 1) Turn OFF the phone. [31/03/2008 23:23:38] 2) Connect the phone to DreamBox cable. [31/03/2008 23:23:38] Boot Responce = 5A [31/03/2008 23:23:38] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:23:40] NOR Flash ID = 897E [31/03/2008 23:23:40] OTP Status = LOCKED [31/03/2008 23:23:40] OTP IMEI = 357354-01-810760-7 [31/03/2008 23:23:40] OTP CID = 51 [31/03/2008 23:23:40] EROM Color = 4 : RED [31/03/2008 23:23:40] EROM CID = 52 [31/03/2008 23:23:43] Error : Failed. [31/03/2008 23:23:43] [31/03/2008 23:23:46] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:23:46] User selected phone W200 using Test Point boot mode [31/03/2008 23:23:47] Stage 2 start [31/03/2008 23:24:05] Warning : Aborted by user. [31/03/2008 23:24:05] [31/03/2008 23:24:06] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:24:06] User selected phone W200 using Test Point boot mode [31/03/2008 23:24:07] Stage 2 start [31/03/2008 23:26:45] Timeout detected [31/03/2008 23:26:45] Error : Failed. [31/03/2008 23:26:45] [31/03/2008 23:26:46] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:26:46] User selected phone W200 using Test Point boot mode [31/03/2008 23:26:47] Stage 2 start [31/03/2008 23:27:17] Timeout detected [31/03/2008 23:27:17] Error : Failed. [31/03/2008 23:27:17] [31/03/2008 23:27:18] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:27:18] User selected phone W200 using Test Point boot mode [31/03/2008 23:27:19] Stage 2 start [31/03/2008 23:27:40] Warning : Aborted by user. [31/03/2008 23:27:40] [31/03/2008 23:27:41] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:27:41] User selected phone W200 using Test Point boot mode [31/03/2008 23:27:42] Stage 2 start [31/03/2008 23:28:02] Warning : Aborted by user. [31/03/2008 23:28:02] [31/03/2008 23:28:03] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:28:03] User selected phone W200 using Test Point boot mode [31/03/2008 23:28:04] Stage 2 start [31/03/2008 23:28:18] Hint : Now the probe might be disconnected [31/03/2008 23:28:26] Processing... [31/03/2008 23:28:30] Entering Security Bypass mode ... [31/03/2008 23:28:30] 1) Turn OFF the phone. [31/03/2008 23:28:30] 2) Connect the phone to DreamBox cable. [31/03/2008 23:28:30] Boot Responce = 5A [31/03/2008 23:28:30] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:28:32] Baseband Chip ID = 8040 [31/03/2008 23:28:33] Phone ID = 2380EA731580F0C5 [31/03/2008 23:28:33] Finalizing ... [31/03/2008 23:28:35] Stage 2 completed succesfully [31/03/2008 23:28:35] Done. [31/03/2008 23:28:35] [31/03/2008 23:28:37] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 23:28:37] User selected phone W200 using Security Bypass boot mode [31/03/2008 23:28:38] 1) Turn OFF the phone. [31/03/2008 23:28:38] 2) Connect the phone to DreamBox cable. [31/03/2008 23:28:38] Boot Responce = 5A [31/03/2008 23:28:38] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:28:40] Baseband Chip ID = 8040 [31/03/2008 23:28:40] Phone ID = 2380EA731580F0C5 [31/03/2008 23:28:41] Reading GDFS... [31/03/2008 23:28:43] Testing security ... [31/03/2008 23:28:43] GDFS 0013 Hash OK [31/03/2008 23:28:43] GDFS 0006 Hash OK [31/03/2008 23:28:43] GDFS 000E Hash OK [31/03/2008 23:28:43] GDFS 001C Hash OK [31/03/2008 23:28:43] Unlocking ... [31/03/2008 23:28:43] Testing security ... [31/03/2008 23:28:43] GDFS 0013 Hash OK [31/03/2008 23:28:43] GDFS 0006 Hash OK [31/03/2008 23:28:43] GDFS 000E Hash OK [31/03/2008 23:28:44] GDFS 001C Hash OK [31/03/2008 23:28:44] Generating GDFS... [31/03/2008 23:28:44] Writing GDFS... [31/03/2008 23:28:53] Done. [31/03/2008 23:28:53] [31/03/2008 23:30:49] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:30:49] User selected phone W200 using Test Point boot mode [31/03/2008 23:30:50] Stage 1 started [31/03/2008 23:30:50] 1) Turn OFF the phone. [31/03/2008 23:30:50] 2) Connect the phone to DreamBox cable. [31/03/2008 23:30:50] Boot Responce = 5A [31/03/2008 23:30:50] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:30:52] NOR Flash ID = 2019 [31/03/2008 23:30:52] OTP Status = LOCKED [31/03/2008 23:30:52] OTP IMEI = 357354-01-811029-6 [31/03/2008 23:30:52] OTP CID = 51 [31/03/2008 23:30:52] EROM Color = 4 : RED [31/03/2008 23:30:52] EROM CID = 52 [31/03/2008 23:31:35] Hint : Now the probe might be disconnected [31/03/2008 23:31:44] Processing ... [31/03/2008 23:31:44] Stage 1 completed succesfully [31/03/2008 23:31:45] Stage 2 start [31/03/2008 23:32:25] Timeout detected [31/03/2008 23:32:25] Error : Failed. [31/03/2008 23:32:25] [31/03/2008 23:32:27] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:32:28] User selected phone W200 using Test Point boot mode [31/03/2008 23:32:29] Stage 2 start [31/03/2008 23:33:30] Hint : Now the probe might be disconnected [31/03/2008 23:33:38] Processing... [31/03/2008 23:33:41] Entering Security Bypass mode ... [31/03/2008 23:33:41] 1) Turn OFF the phone. [31/03/2008 23:33:41] 2) Connect the phone to DreamBox cable. [31/03/2008 23:33:41] Boot Responce = 5A [31/03/2008 23:33:42] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:33:44] Baseband Chip ID = 8040 [31/03/2008 23:33:44] Phone ID = 2380EA73155001C6 [31/03/2008 23:33:44] Finalizing ... [31/03/2008 23:33:46] Stage 2 completed succesfully [31/03/2008 23:33:46] Done. [31/03/2008 23:33:46] [31/03/2008 23:33:52] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 23:33:52] User selected phone W200 using Security Bypass boot mode [31/03/2008 23:33:52] 1) Turn OFF the phone. [31/03/2008 23:33:52] 2) Connect the phone to DreamBox cable. [31/03/2008 23:33:52] Boot Responce = 5A [31/03/2008 23:33:52] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:33:55] Baseband Chip ID = 8040 [31/03/2008 23:33:55] Phone ID = 2380EA73155001C6 [31/03/2008 23:33:55] Reading GDFS... [31/03/2008 23:33:57] Testing security ... [31/03/2008 23:33:57] GDFS 0013 Hash OK [31/03/2008 23:33:57] GDFS 0006 Hash OK [31/03/2008 23:33:57] GDFS 000E Hash OK [31/03/2008 23:33:57] GDFS 001C Hash OK [31/03/2008 23:33:57] Unlocking ... [31/03/2008 23:33:58] Testing security ... [31/03/2008 23:33:58] GDFS 0013 Hash OK [31/03/2008 23:33:58] GDFS 0006 Hash OK [31/03/2008 23:33:58] GDFS 000E Hash OK [31/03/2008 23:33:58] GDFS 001C Hash OK [31/03/2008 23:33:58] Generating GDFS... [31/03/2008 23:33:58] Writing GDFS... [31/03/2008 23:34:07] Done. [31/03/2008 23:34:07] [31/03/2008 23:35:43] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:35:43] User selected phone W200 using Test Point boot mode [31/03/2008 23:35:43] Stage 1 started [31/03/2008 23:35:43] 1) Turn OFF the phone. [31/03/2008 23:35:43] 2) Connect the phone to DreamBox cable. [31/03/2008 23:35:43] Boot Responce = 5A [31/03/2008 23:35:44] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:35:46] NOR Flash ID = 897E [31/03/2008 23:35:46] OTP Status = LOCKED [31/03/2008 23:35:46] OTP IMEI = 359707-01-923281-5 [31/03/2008 23:35:46] OTP CID = 51 [31/03/2008 23:35:46] EROM Color = 4 : RED [31/03/2008 23:35:46] EROM CID = 52 [31/03/2008 23:36:29] Hint : Now the probe might be disconnected [31/03/2008 23:36:39] Processing ... [31/03/2008 23:36:39] Stage 1 completed succesfully [31/03/2008 23:36:39] Stage 2 start [31/03/2008 23:39:46] Error : Failed. [31/03/2008 23:39:46] [31/03/2008 23:39:58] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:39:58] User selected phone W200 using Test Point boot mode [31/03/2008 23:39:59] Stage 2 start [31/03/2008 23:43:29] Error : Failed. [31/03/2008 23:43:29] [31/03/2008 23:43:29] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:43:30] User selected phone W200 using Test Point boot mode [31/03/2008 23:43:31] Stage 2 start [31/03/2008 23:44:02] Warning : Aborted by user. [31/03/2008 23:44:02] [31/03/2008 23:44:03] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:44:03] User selected phone W200 using Test Point boot mode [31/03/2008 23:44:04] Stage 2 start [31/03/2008 23:44:25] Timeout detected [31/03/2008 23:44:26] Error : Failed. [31/03/2008 23:44:26] [31/03/2008 23:44:28] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:44:28] User selected phone W200 using Test Point boot mode [31/03/2008 23:44:29] Stage 2 start [31/03/2008 23:44:43] Warning : Aborted by user. [31/03/2008 23:44:43] [31/03/2008 23:44:44] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:44:44] User selected phone W200 using Test Point boot mode [31/03/2008 23:44:45] Stage 2 start [31/03/2008 23:45:13] Warning : Aborted by user. [31/03/2008 23:45:13] [31/03/2008 23:45:14] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:45:14] User selected phone W200 using Test Point boot mode [31/03/2008 23:45:15] Stage 2 start [31/03/2008 23:45:28] Warning : Aborted by user. [31/03/2008 23:45:28] [31/03/2008 23:45:29] --- Security Bypass------------------------------------------------------------ [31/03/2008 23:45:29] User selected phone W200 using Test Point boot mode [31/03/2008 23:45:31] Stage 2 start [31/03/2008 23:46:17] Hint : Now the probe might be disconnected [31/03/2008 23:46:25] Processing... [31/03/2008 23:46:29] Entering Security Bypass mode ... [31/03/2008 23:46:29] 1) Turn OFF the phone. [31/03/2008 23:46:29] 2) Connect the phone to DreamBox cable. [31/03/2008 23:46:29] Boot Responce = 5A [31/03/2008 23:46:29] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:46:31] Baseband Chip ID = 8040 [31/03/2008 23:46:31] Phone ID = 23801B7D151069E1 [31/03/2008 23:46:31] Finalizing ... [31/03/2008 23:46:34] Stage 2 completed succesfully [31/03/2008 23:46:34] Done. [31/03/2008 23:46:34] [31/03/2008 23:46:41] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 23:46:41] User selected phone W200 using Security Bypass boot mode [31/03/2008 23:46:41] 1) Turn OFF the phone. [31/03/2008 23:46:41] 2) Connect the phone to DreamBox cable. [31/03/2008 23:46:42] Boot Responce = 5A [31/03/2008 23:46:42] Processor ID = 8040030101010101 (DB2012 R3A) [31/03/2008 23:46:44] Baseband Chip ID = 8040 [31/03/2008 23:46:44] Phone ID = 23801B7D151069E1 [31/03/2008 23:46:44] Reading GDFS... [31/03/2008 23:46:46] Testing security ... [31/03/2008 23:46:46] GDFS 0013 Hash OK [31/03/2008 23:46:46] GDFS 0006 Hash OK [31/03/2008 23:46:46] GDFS 000E Hash OK [31/03/2008 23:46:46] GDFS 001C Hash OK [31/03/2008 23:46:46] Unlocking ... [31/03/2008 23:46:47] Testing security ... [31/03/2008 23:46:47] GDFS 0013 Hash OK [31/03/2008 23:46:47] GDFS 0006 Hash OK [31/03/2008 23:46:47] GDFS 000E Hash OK [31/03/2008 23:46:47] GDFS 001C Hash OK [31/03/2008 23:46:47] Generating GDFS... [31/03/2008 23:46:47] Writing GDFS... [31/03/2008 23:46:57] Done. [31/03/2008 23:46:57] [01/04/2008 09:35:38] [01/04/2008 09:35:38] DBSS Start 3.1.2 [01/04/2008 09:35:59] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:36:02] User selected phone W200 using Test Point boot mode [01/04/2008 09:36:03] Stage 1 started [01/04/2008 09:36:03] 1) Turn OFF the phone. [01/04/2008 09:36:03] 2) Connect the phone to DreamBox cable. [01/04/2008 09:36:03] Boot Responce = 5A [01/04/2008 09:36:03] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:36:05] NOR Flash ID = 897E [01/04/2008 09:36:05] OTP Status = LOCKED [01/04/2008 09:36:05] OTP IMEI = 359707-01-918389-3 [01/04/2008 09:36:05] OTP CID = 51 [01/04/2008 09:36:05] EROM Color = 4 : RED [01/04/2008 09:36:05] EROM CID = 52 [01/04/2008 09:36:27] Hint : Now the probe might be disconnected [01/04/2008 09:36:36] Processing ... - [01/04/2008 09:36:36] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:36:36] Error : Failed. [01/04/2008 09:36:36] [01/04/2008 09:36:47] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:36:47] User selected phone W200 using Test Point boot mode [01/04/2008 09:36:48] Stage 1 started [01/04/2008 09:36:48] 1) Turn OFF the phone. [01/04/2008 09:36:48] 2) Connect the phone to DreamBox cable. [01/04/2008 09:36:48] Boot Responce = 5A [01/04/2008 09:36:48] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:36:50] NOR Flash ID = 897E [01/04/2008 09:36:50] OTP Status = LOCKED [01/04/2008 09:36:50] OTP IMEI = 359707-01-918389-3 [01/04/2008 09:36:50] OTP CID = 51 [01/04/2008 09:36:50] EROM Color = 4 : RED [01/04/2008 09:36:50] EROM CID = 52 [01/04/2008 09:37:04] Hint : Now the probe might be disconnected [01/04/2008 09:37:11] Processing ... - [01/04/2008 09:37:11] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:37:11] Error : Failed. [01/04/2008 09:37:11] [01/04/2008 09:37:14] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:37:14] User selected phone W200 using Test Point boot mode [01/04/2008 09:37:15] Stage 1 started [01/04/2008 09:37:15] 1) Turn OFF the phone. [01/04/2008 09:37:15] 2) Connect the phone to DreamBox cable. [01/04/2008 09:37:15] Boot Responce = 5A [01/04/2008 09:37:15] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:37:18] NOR Flash ID = 897E [01/04/2008 09:37:18] OTP Status = LOCKED [01/04/2008 09:37:18] OTP IMEI = 359707-01-918389-3 [01/04/2008 09:37:18] OTP CID = 51 [01/04/2008 09:37:18] EROM Color = 4 : RED [01/04/2008 09:37:18] EROM CID = 52 [01/04/2008 09:37:30] Hint : Now the probe might be disconnected [01/04/2008 09:37:38] Processing ... / [01/04/2008 09:37:38] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:37:38] Error : Failed. [01/04/2008 09:37:38] [01/04/2008 09:37:44] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:37:44] User selected phone W200 using Test Point boot mode [01/04/2008 09:37:45] Stage 1 started [01/04/2008 09:37:45] 1) Turn OFF the phone. [01/04/2008 09:37:45] 2) Connect the phone to DreamBox cable. [01/04/2008 09:37:45] Boot Responce = 5A [01/04/2008 09:37:45] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:37:47] NOR Flash ID = 897E [01/04/2008 09:37:48] OTP Status = LOCKED [01/04/2008 09:37:48] OTP IMEI = 359707-01-918389-3 [01/04/2008 09:37:48] OTP CID = 51 [01/04/2008 09:37:48] EROM Color = 4 : RED [01/04/2008 09:37:48] EROM CID = 52 [01/04/2008 09:38:08] Hint : Now the probe might be disconnected [01/04/2008 09:38:15] Processing ... | [01/04/2008 09:38:15] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:38:15] Error : Failed. [01/04/2008 09:38:15] [01/04/2008 09:38:19] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:38:20] User selected phone W200 using Test Point boot mode [01/04/2008 09:38:20] Stage 1 started [01/04/2008 09:38:20] 1) Turn OFF the phone. [01/04/2008 09:38:20] 2) Connect the phone to DreamBox cable. [01/04/2008 09:38:20] Boot Responce = 5A [01/04/2008 09:38:20] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:38:23] NOR Flash ID = 897E [01/04/2008 09:38:23] OTP Status = LOCKED [01/04/2008 09:38:23] OTP IMEI = 359707-01-918389-3 [01/04/2008 09:38:23] OTP CID = 51 [01/04/2008 09:38:23] EROM Color = 4 : RED [01/04/2008 09:38:23] EROM CID = 52 [01/04/2008 09:38:40] Hint : Now the probe might be disconnected [01/04/2008 09:38:47] Processing ... \ [01/04/2008 09:38:47] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:38:47] Error : Failed. [01/04/2008 09:38:47] [01/04/2008 09:38:51] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:38:51] User selected phone W200 using Test Point boot mode [01/04/2008 09:38:52] Stage 1 started [01/04/2008 09:38:52] 1) Turn OFF the phone. [01/04/2008 09:38:52] 2) Connect the phone to DreamBox cable. [01/04/2008 09:38:52] Boot Responce = 5A [01/04/2008 09:38:52] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:38:55] NOR Flash ID = 897E [01/04/2008 09:38:55] OTP Status = LOCKED [01/04/2008 09:38:55] OTP IMEI = 359707-01-918389-3 [01/04/2008 09:38:55] OTP CID = 51 [01/04/2008 09:38:55] EROM Color = 4 : RED [01/04/2008 09:38:55] EROM CID = 52 [01/04/2008 09:39:40] Hint : Now the probe might be disconnected [01/04/2008 09:39:50] Processing ... [01/04/2008 09:39:50] Stage 1 completed succesfully [01/04/2008 09:39:51] Stage 2 start [01/04/2008 09:40:19] Timeout detected [01/04/2008 09:40:19] Error : Failed. [01/04/2008 09:40:19] [01/04/2008 09:40:23] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:40:23] User selected phone W200 using Test Point boot mode [01/04/2008 09:40:24] Stage 2 start [01/04/2008 09:41:04] Warning : Aborted by user. [01/04/2008 09:41:04] [01/04/2008 09:41:05] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:41:05] User selected phone W200 using Test Point boot mode [01/04/2008 09:41:06] Stage 2 start [01/04/2008 09:41:37] Timeout detected [01/04/2008 09:41:37] Error : Failed. [01/04/2008 09:41:37] [01/04/2008 09:41:39] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:41:39] User selected phone W200 using Test Point boot mode [01/04/2008 09:41:40] Stage 2 start [01/04/2008 09:42:08] Timeout detected [01/04/2008 09:42:08] Error : Failed. [01/04/2008 09:42:08] [01/04/2008 09:42:10] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:42:10] User selected phone W200 using Test Point boot mode [01/04/2008 09:42:11] Stage 2 start [01/04/2008 09:42:38] Warning : Aborted by user. [01/04/2008 09:42:38] [01/04/2008 09:42:39] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:42:39] User selected phone W200 using Test Point boot mode [01/04/2008 09:42:40] Stage 2 start [01/04/2008 09:43:36] Timeout detected [01/04/2008 09:43:36] Error : Failed. [01/04/2008 09:43:36] [01/04/2008 09:43:38] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:43:38] User selected phone W200 using Test Point boot mode [01/04/2008 09:43:39] Stage 2 start [01/04/2008 09:45:21] Hint : Now the probe might be disconnected [01/04/2008 09:45:29] Processing... [01/04/2008 09:45:32] Entering Security Bypass mode ... [01/04/2008 09:45:32] 1) Turn OFF the phone. [01/04/2008 09:45:32] 2) Connect the phone to DreamBox cable. [01/04/2008 09:45:32] Boot Responce = 5A [01/04/2008 09:45:32] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:45:35] Baseband Chip ID = 8040 [01/04/2008 09:45:35] Phone ID = 23801B7D155037E0 [01/04/2008 09:45:35] Finalizing ... [01/04/2008 09:45:37] Stage 2 completed succesfully [01/04/2008 09:45:37] Done. [01/04/2008 09:45:37] [01/04/2008 09:45:41] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 09:45:41] User selected phone W200 using Security Bypass boot mode [01/04/2008 09:45:42] 1) Turn OFF the phone. [01/04/2008 09:45:42] 2) Connect the phone to DreamBox cable. [01/04/2008 09:45:42] Boot Responce = 5A [01/04/2008 09:45:42] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:45:45] Baseband Chip ID = 8040 [01/04/2008 09:45:45] Phone ID = 23801B7D155037E0 [01/04/2008 09:45:45] Reading GDFS... [01/04/2008 09:45:47] Testing security ... [01/04/2008 09:45:47] GDFS 0013 Hash OK [01/04/2008 09:45:47] GDFS 0006 Hash OK [01/04/2008 09:45:47] GDFS 000E Hash OK [01/04/2008 09:45:47] GDFS 001C Hash OK [01/04/2008 09:45:47] Unlocking ... [01/04/2008 09:45:47] Testing security ... [01/04/2008 09:45:48] GDFS 0013 Hash OK [01/04/2008 09:45:48] GDFS 0006 Hash OK [01/04/2008 09:45:48] GDFS 000E Hash OK [01/04/2008 09:45:48] GDFS 001C Hash OK [01/04/2008 09:45:48] Generating GDFS... [01/04/2008 09:45:48] Writing GDFS... [01/04/2008 09:45:57] Done. [01/04/2008 09:45:57] [01/04/2008 09:49:06] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:49:06] User selected phone W200 using Test Point boot mode [01/04/2008 09:49:07] Stage 1 started [01/04/2008 09:49:07] 1) Turn OFF the phone. [01/04/2008 09:49:07] 2) Connect the phone to DreamBox cable. [01/04/2008 09:49:07] Boot Responce = 5A [01/04/2008 09:49:07] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:49:09] NOR Flash ID = 897E [01/04/2008 09:49:09] OTP Status = LOCKED [01/04/2008 09:49:09] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:49:09] OTP CID = 51 [01/04/2008 09:49:09] EROM Color = 4 : RED [01/04/2008 09:49:09] EROM CID = 52 [01/04/2008 09:49:37] Hint : Now the probe might be disconnected [01/04/2008 09:49:37] Processing ... [01/04/2008 09:49:37] Error : Invalid GDFS structure and/or configuration. [01/04/2008 09:49:37] Hint : Try to flash firmware. [01/04/2008 09:49:37] Error : Failed. [01/04/2008 09:49:37] [01/04/2008 09:49:42] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:49:42] User selected phone W200 using Test Point boot mode [01/04/2008 09:49:43] Stage 1 started [01/04/2008 09:49:43] 1) Turn OFF the phone. [01/04/2008 09:49:43] 2) Connec |
04-01-2008, 10:42 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lost in this Field Age: 39
Member: 154513 Status: Offline Thanks Meter: 160 | Here is left some not comes in 1st post Code: [01/04/2008 09:49:42] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:49:42] User selected phone W200 using Test Point boot mode [01/04/2008 09:49:43] Stage 1 started [01/04/2008 09:49:43] 1) Turn OFF the phone. [01/04/2008 09:49:43] 2) Connect the phone to DreamBox cable. [01/04/2008 09:49:43] Boot Responce = 5A [01/04/2008 09:49:43] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:49:45] NOR Flash ID = 897E [01/04/2008 09:49:45] OTP Status = LOCKED [01/04/2008 09:49:45] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:49:45] OTP CID = 51 [01/04/2008 09:49:45] EROM Color = 4 : RED [01/04/2008 09:49:45] EROM CID = 52 [01/04/2008 09:49:56] Hint : Now the probe might be disconnected [01/04/2008 09:50:03] Processing ... / [01/04/2008 09:50:03] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:50:03] Error : Failed. [01/04/2008 09:50:03] [01/04/2008 09:50:06] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:50:06] User selected phone W200 using Test Point boot mode [01/04/2008 09:50:07] Stage 1 started [01/04/2008 09:50:07] 1) Turn OFF the phone. [01/04/2008 09:50:07] 2) Connect the phone to DreamBox cable. [01/04/2008 09:50:07] Boot Responce = 5A [01/04/2008 09:50:07] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:50:09] NOR Flash ID = 897E [01/04/2008 09:50:09] OTP Status = LOCKED [01/04/2008 09:50:09] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:50:09] OTP CID = 51 [01/04/2008 09:50:09] EROM Color = 4 : RED [01/04/2008 09:50:09] EROM CID = 52 [01/04/2008 09:50:17] Hint : Now the probe might be disconnected [01/04/2008 09:50:25] Processing ... / [01/04/2008 09:50:25] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:50:25] Error : Failed. [01/04/2008 09:50:25] [01/04/2008 09:50:28] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:50:28] User selected phone W200 using Test Point boot mode [01/04/2008 09:50:28] Stage 1 started [01/04/2008 09:50:28] 1) Turn OFF the phone. [01/04/2008 09:50:28] 2) Connect the phone to DreamBox cable. [01/04/2008 09:50:29] Boot Responce = 5A [01/04/2008 09:50:29] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:50:31] NOR Flash ID = 897E [01/04/2008 09:50:31] OTP Status = LOCKED [01/04/2008 09:50:31] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:50:31] OTP CID = 51 [01/04/2008 09:50:31] EROM Color = 4 : RED [01/04/2008 09:50:31] EROM CID = 52 [01/04/2008 09:50:43] Hint : Now the probe might be disconnected [01/04/2008 09:50:50] Processing ... | [01/04/2008 09:50:50] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:50:50] Error : Failed. [01/04/2008 09:50:50] [01/04/2008 09:50:54] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:50:54] User selected phone W200 using Test Point boot mode [01/04/2008 09:50:55] Stage 1 started [01/04/2008 09:50:55] 1) Turn OFF the phone. [01/04/2008 09:50:55] 2) Connect the phone to DreamBox cable. [01/04/2008 09:50:55] Boot Responce = 5A [01/04/2008 09:50:55] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:50:57] NOR Flash ID = 897E [01/04/2008 09:50:57] OTP Status = LOCKED [01/04/2008 09:50:57] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:50:57] OTP CID = 51 [01/04/2008 09:50:57] EROM Color = 4 : RED [01/04/2008 09:50:57] EROM CID = 52 [01/04/2008 09:51:13] Hint : Now the probe might be disconnected [01/04/2008 09:51:30] Processing ... / [01/04/2008 09:51:30] Error : Loader failed to dump GDFS. [01/04/2008 09:51:30] Hint : Power on the phone and change settings/contacts/theme e.t.c. [01/04/2008 09:51:30] Hint : This will reorganize GDFS structure and possibly fix the error. [01/04/2008 09:51:30] Error : Failed. [01/04/2008 09:51:30] [01/04/2008 09:53:10] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:53:10] User selected phone W200 using Test Point boot mode [01/04/2008 09:53:11] Stage 1 started [01/04/2008 09:53:11] 1) Turn OFF the phone. [01/04/2008 09:53:11] 2) Connect the phone to DreamBox cable. [01/04/2008 09:53:11] Boot Responce = 5A [01/04/2008 09:53:11] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:53:13] NOR Flash ID = 897E [01/04/2008 09:53:13] OTP Status = LOCKED [01/04/2008 09:53:13] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:53:13] OTP CID = 51 [01/04/2008 09:53:13] EROM Color = 4 : RED [01/04/2008 09:53:13] EROM CID = 52 [01/04/2008 09:53:24] Hint : Now the probe might be disconnected [01/04/2008 09:53:32] Processing ... | [01/04/2008 09:53:32] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:53:32] Error : Failed. [01/04/2008 09:53:32] [01/04/2008 09:53:35] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:53:35] User selected phone W200 using Test Point boot mode [01/04/2008 09:53:36] Stage 1 started [01/04/2008 09:53:36] 1) Turn OFF the phone. [01/04/2008 09:53:36] 2) Connect the phone to DreamBox cable. [01/04/2008 09:53:36] Boot Responce = 5A [01/04/2008 09:53:36] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:53:38] NOR Flash ID = 897E [01/04/2008 09:53:38] OTP Status = LOCKED [01/04/2008 09:53:38] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:53:38] OTP CID = 51 [01/04/2008 09:53:38] EROM Color = 4 : RED [01/04/2008 09:53:38] EROM CID = 52 [01/04/2008 09:53:47] Hint : Now the probe might be disconnected [01/04/2008 09:53:55] Processing ... | [01/04/2008 09:53:55] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:53:55] Error : Failed. [01/04/2008 09:53:55] [01/04/2008 09:53:58] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:53:58] User selected phone W200 using Test Point boot mode [01/04/2008 09:53:59] Stage 1 started [01/04/2008 09:53:59] 1) Turn OFF the phone. [01/04/2008 09:53:59] 2) Connect the phone to DreamBox cable. [01/04/2008 09:53:59] Boot Responce = 5A [01/04/2008 09:53:59] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:54:01] NOR Flash ID = 897E [01/04/2008 09:54:01] OTP Status = LOCKED [01/04/2008 09:54:01] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:54:01] OTP CID = 51 [01/04/2008 09:54:01] EROM Color = 4 : RED [01/04/2008 09:54:01] EROM CID = 52 [01/04/2008 09:54:16] Hint : Now the probe might be disconnected [01/04/2008 09:54:23] Processing ... \ [01/04/2008 09:54:23] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:54:23] Error : Failed. [01/04/2008 09:54:23] [01/04/2008 09:54:26] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:54:26] User selected phone W200 using Test Point boot mode [01/04/2008 09:54:27] Stage 1 started [01/04/2008 09:54:27] 1) Turn OFF the phone. [01/04/2008 09:54:27] 2) Connect the phone to DreamBox cable. [01/04/2008 09:54:27] Boot Responce = 5A [01/04/2008 09:54:27] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:54:29] NOR Flash ID = 897E [01/04/2008 09:54:30] OTP Status = LOCKED [01/04/2008 09:54:30] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:54:30] OTP CID = 51 [01/04/2008 09:54:30] EROM Color = 4 : RED [01/04/2008 09:54:30] EROM CID = 52 [01/04/2008 09:54:33] Hint : Now the probe might be disconnected [01/04/2008 09:54:41] Processing ... - [01/04/2008 09:54:41] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:54:41] Error : Failed. [01/04/2008 09:54:41] [01/04/2008 09:54:43] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:54:43] User selected phone W200 using Test Point boot mode [01/04/2008 09:54:44] Stage 1 started [01/04/2008 09:54:44] 1) Turn OFF the phone. [01/04/2008 09:54:44] 2) Connect the phone to DreamBox cable. [01/04/2008 09:54:44] Boot Responce = 5A [01/04/2008 09:54:44] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:54:46] NOR Flash ID = 897E [01/04/2008 09:54:46] OTP Status = LOCKED [01/04/2008 09:54:46] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:54:46] OTP CID = 51 [01/04/2008 09:54:46] EROM Color = 4 : RED [01/04/2008 09:54:46] EROM CID = 52 [01/04/2008 09:55:08] Hint : Now the probe might be disconnected [01/04/2008 09:55:16] Processing ... / [01/04/2008 09:55:16] Error : Testpoint failed. Check pin and try again. [01/04/2008 09:55:16] Error : Failed. [01/04/2008 09:55:16] [01/04/2008 09:55:18] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:55:18] User selected phone W200 using Test Point boot mode [01/04/2008 09:55:19] Stage 1 started [01/04/2008 09:55:19] 1) Turn OFF the phone. [01/04/2008 09:55:19] 2) Connect the phone to DreamBox cable. [01/04/2008 09:55:19] Boot Responce = 5A [01/04/2008 09:55:19] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:55:21] NOR Flash ID = 897E [01/04/2008 09:55:21] OTP Status = LOCKED [01/04/2008 09:55:21] OTP IMEI = 359707-01-923192-4 [01/04/2008 09:55:21] OTP CID = 51 [01/04/2008 09:55:22] EROM Color = 4 : RED [01/04/2008 09:55:22] EROM CID = 52 [01/04/2008 09:55:57] Hint : Now the probe might be disconnected [01/04/2008 09:56:08] Processing ... [01/04/2008 09:56:08] Stage 1 completed succesfully [01/04/2008 09:56:08] Stage 2 start [01/04/2008 09:56:43] Warning : Aborted by user. [01/04/2008 09:56:43] [01/04/2008 09:56:45] --- Security Bypass------------------------------------------------------------ [01/04/2008 09:56:45] User selected phone W200 using Test Point boot mode [01/04/2008 09:56:46] Stage 2 start [01/04/2008 09:57:05] Hint : Now the probe might be disconnected [01/04/2008 09:57:13] Processing... [01/04/2008 09:57:17] Entering Security Bypass mode ... [01/04/2008 09:57:17] 1) Turn OFF the phone. [01/04/2008 09:57:17] 2) Connect the phone to DreamBox cable. [01/04/2008 09:57:17] Boot Responce = 5A [01/04/2008 09:57:17] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:57:19] Baseband Chip ID = 8040 [01/04/2008 09:57:19] Phone ID = 23801B7D158063E1 [01/04/2008 09:57:19] Finalizing ... [01/04/2008 09:57:22] Stage 2 completed succesfully [01/04/2008 09:57:22] Done. [01/04/2008 09:57:22] [01/04/2008 09:57:25] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 09:57:25] User selected phone W200 using Security Bypass boot mode [01/04/2008 09:57:26] 1) Turn OFF the phone. [01/04/2008 09:57:26] 2) Connect the phone to DreamBox cable. [01/04/2008 09:57:26] Boot Responce = 5A [01/04/2008 09:57:26] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 09:57:29] Baseband Chip ID = 8040 [01/04/2008 09:57:29] Phone ID = 23801B7D158063E1 [01/04/2008 09:57:29] Reading GDFS... [01/04/2008 09:57:31] Testing security ... [01/04/2008 09:57:31] GDFS 0013 Hash OK [01/04/2008 09:57:31] GDFS 0006 Hash OK [01/04/2008 09:57:31] GDFS 000E Hash OK [01/04/2008 09:57:31] GDFS 001C Hash OK [01/04/2008 09:57:31] Unlocking ... [01/04/2008 09:57:32] Testing security ... [01/04/2008 09:57:32] GDFS 0013 Hash OK [01/04/2008 09:57:32] GDFS 0006 Hash OK [01/04/2008 09:57:32] GDFS 000E Hash OK [01/04/2008 09:57:32] GDFS 001C Hash OK [01/04/2008 09:57:32] Generating GDFS... [01/04/2008 09:57:32] Writing GDFS... [01/04/2008 09:57:42] Done. [01/04/2008 09:57:42] [01/04/2008 10:00:45] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:00:45] User selected phone W200 using Test Point boot mode [01/04/2008 10:00:45] Stage 1 started [01/04/2008 10:00:45] 1) Turn OFF the phone. [01/04/2008 10:00:45] 2) Connect the phone to DreamBox cable. [01/04/2008 10:00:46] Boot Responce = 5A [01/04/2008 10:00:46] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:00:48] NOR Flash ID = 897E [01/04/2008 10:00:48] OTP Status = LOCKED [01/04/2008 10:00:48] OTP IMEI = 357354-01-810966-0 [01/04/2008 10:00:48] OTP CID = 51 [01/04/2008 10:00:48] EROM Color = 4 : RED [01/04/2008 10:00:48] EROM CID = 52 [01/04/2008 10:01:10] Hint : Now the probe might be disconnected [01/04/2008 10:01:17] Processing ... - [01/04/2008 10:01:17] Error : Testpoint failed. Check pin and try again. [01/04/2008 10:01:17] Error : Failed. [01/04/2008 10:01:17] [01/04/2008 10:01:20] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:01:20] User selected phone W200 using Test Point boot mode [01/04/2008 10:01:21] Stage 1 started [01/04/2008 10:01:21] 1) Turn OFF the phone. [01/04/2008 10:01:21] 2) Connect the phone to DreamBox cable. [01/04/2008 10:01:21] Boot Responce = 5A [01/04/2008 10:01:21] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:01:23] NOR Flash ID = 897E [01/04/2008 10:01:23] OTP Status = LOCKED [01/04/2008 10:01:23] OTP IMEI = 357354-01-810966-0 [01/04/2008 10:01:23] OTP CID = 51 [01/04/2008 10:01:23] EROM Color = 4 : RED [01/04/2008 10:01:23] EROM CID = 52 [01/04/2008 10:01:43] Hint : Now the probe might be disconnected [01/04/2008 10:01:53] Processing ... [01/04/2008 10:01:53] Stage 1 completed succesfully [01/04/2008 10:01:54] Stage 2 start [01/04/2008 10:02:32] Hint : Now the probe might be disconnected [01/04/2008 10:02:40] Processing... [01/04/2008 10:02:43] Entering Security Bypass mode ... [01/04/2008 10:02:43] 1) Turn OFF the phone. [01/04/2008 10:02:43] 2) Connect the phone to DreamBox cable. [01/04/2008 10:02:43] Boot Responce = 5A [01/04/2008 10:02:43] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:02:46] Baseband Chip ID = 8040 [01/04/2008 10:02:46] Phone ID = 2380EA731560FDC5 [01/04/2008 10:02:46] Finalizing ... [01/04/2008 10:02:48] Stage 2 completed succesfully [01/04/2008 10:02:48] Done. [01/04/2008 10:02:48] [01/04/2008 10:03:01] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 10:03:02] User selected phone W200 using Security Bypass boot mode [01/04/2008 10:03:02] 1) Turn OFF the phone. [01/04/2008 10:03:02] 2) Connect the phone to DreamBox cable. [01/04/2008 10:03:02] Boot Responce = 5A [01/04/2008 10:03:02] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:03:05] Baseband Chip ID = 8040 [01/04/2008 10:03:05] Phone ID = 2380EA731560FDC5 [01/04/2008 10:03:05] Reading GDFS... [01/04/2008 10:03:07] Testing security ... [01/04/2008 10:03:07] GDFS 0013 Hash OK [01/04/2008 10:03:07] GDFS 0006 Hash OK [01/04/2008 10:03:07] GDFS 000E Hash OK [01/04/2008 10:03:07] GDFS 001C Hash OK [01/04/2008 10:03:07] Unlocking ... [01/04/2008 10:03:08] Testing security ... [01/04/2008 10:03:08] GDFS 0013 Hash OK [01/04/2008 10:03:08] GDFS 0006 Hash OK [01/04/2008 10:03:08] GDFS 000E Hash OK [01/04/2008 10:03:08] GDFS 001C Hash OK [01/04/2008 10:03:08] Generating GDFS... [01/04/2008 10:03:08] Writing GDFS... [01/04/2008 10:03:18] Done. [01/04/2008 10:03:18] [01/04/2008 10:05:55] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:05:55] User selected phone W200 using Test Point boot mode [01/04/2008 10:05:56] Stage 1 started [01/04/2008 10:05:56] 1) Turn OFF the phone. [01/04/2008 10:05:56] 2) Connect the phone to DreamBox cable. [01/04/2008 10:05:56] Boot Responce = 5A [01/04/2008 10:05:56] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:05:58] NOR Flash ID = 897E [01/04/2008 10:05:58] OTP Status = LOCKED [01/04/2008 10:05:58] OTP IMEI = 359707-01-920061-4 [01/04/2008 10:05:58] OTP CID = 51 [01/04/2008 10:05:58] EROM Color = 4 : RED [01/04/2008 10:05:58] EROM CID = 52 [01/04/2008 10:06:25] Hint : Now the probe might be disconnected [01/04/2008 10:06:35] Processing ... [01/04/2008 10:06:35] Stage 1 completed succesfully [01/04/2008 10:06:36] Stage 2 start [01/04/2008 10:08:08] Hint : Now the probe might be disconnected [01/04/2008 10:08:16] Processing... [01/04/2008 10:08:19] Entering Security Bypass mode ... [01/04/2008 10:08:19] 1) Turn OFF the phone. [01/04/2008 10:08:19] 2) Connect the phone to DreamBox cable. [01/04/2008 10:08:19] Boot Responce = 5A [01/04/2008 10:08:19] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:08:22] Baseband Chip ID = 8040 [01/04/2008 10:08:22] Phone ID = 23801B7D15D09FE0 [01/04/2008 10:08:22] Finalizing ... [01/04/2008 10:08:24] Stage 2 completed succesfully [01/04/2008 10:08:24] Done. [01/04/2008 10:08:24] [01/04/2008 10:08:27] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 10:08:28] User selected phone W200 using Security Bypass boot mode [01/04/2008 10:08:28] 1) Turn OFF the phone. [01/04/2008 10:08:28] 2) Connect the phone to DreamBox cable. [01/04/2008 10:08:28] Boot Responce = 5A [01/04/2008 10:08:29] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:08:31] Baseband Chip ID = 8040 [01/04/2008 10:08:31] Phone ID = 23801B7D15D09FE0 [01/04/2008 10:08:31] Reading GDFS... [01/04/2008 10:08:33] Testing security ... [01/04/2008 10:08:33] GDFS 0013 Hash OK [01/04/2008 10:08:33] GDFS 0006 Hash OK [01/04/2008 10:08:33] GDFS 000E Hash OK [01/04/2008 10:08:33] GDFS 001C Hash OK [01/04/2008 10:08:33] Unlocking ... [01/04/2008 10:08:34] Testing security ... [01/04/2008 10:08:34] GDFS 0013 Hash OK [01/04/2008 10:08:34] GDFS 0006 Hash OK [01/04/2008 10:08:34] GDFS 000E Hash OK [01/04/2008 10:08:34] GDFS 001C Hash OK [01/04/2008 10:08:34] Generating GDFS... [01/04/2008 10:08:34] Writing GDFS... [01/04/2008 10:08:45] Done. [01/04/2008 10:08:45] [01/04/2008 10:11:36] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:11:36] User selected phone W200 using Test Point boot mode [01/04/2008 10:11:37] Stage 1 started [01/04/2008 10:11:37] 1) Turn OFF the phone. [01/04/2008 10:11:37] 2) Connect the phone to DreamBox cable. [01/04/2008 10:11:37] Boot Responce = 5A [01/04/2008 10:11:37] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:11:39] NOR Flash ID = 897E [01/04/2008 10:11:40] OTP Status = LOCKED [01/04/2008 10:11:40] OTP IMEI = 359707-01-919706-7 [01/04/2008 10:11:40] OTP CID = 51 [01/04/2008 10:11:40] EROM Color = 4 : RED [01/04/2008 10:11:40] EROM CID = 52 [01/04/2008 10:11:59] Hint : Now the probe might be disconnected [01/04/2008 10:12:10] Processing ... [01/04/2008 10:12:10] Stage 1 completed succesfully [01/04/2008 10:12:10] Stage 2 start [01/04/2008 10:13:20] Hint : Now the probe might be disconnected [01/04/2008 10:13:28] Processing... [01/04/2008 10:13:31] Entering Security Bypass mode ... [01/04/2008 10:13:31] 1) Turn OFF the phone. [01/04/2008 10:13:31] 2) Connect the phone to DreamBox cable. [01/04/2008 10:13:31] Boot Responce = 5A [01/04/2008 10:13:31] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:13:34] Baseband Chip ID = 8040 [01/04/2008 10:13:34] Phone ID = 23801B7D15A089E0 [01/04/2008 10:13:34] Finalizing ... [01/04/2008 10:13:36] Stage 2 completed succesfully [01/04/2008 10:13:36] Done. [01/04/2008 10:13:36] [01/04/2008 10:13:39] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 10:13:39] User selected phone W200 using Security Bypass boot mode [01/04/2008 10:13:39] 1) Turn OFF the phone. [01/04/2008 10:13:39] 2) Connect the phone to DreamBox cable. [01/04/2008 10:13:40] Boot Responce = 5A [01/04/2008 10:13:40] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:13:42] Baseband Chip ID = 8040 [01/04/2008 10:13:42] Phone ID = 23801B7D15A089E0 [01/04/2008 10:13:42] Reading GDFS... [01/04/2008 10:13:44] Testing security ... [01/04/2008 10:13:44] GDFS 0013 Hash OK [01/04/2008 10:13:45] GDFS 0006 Hash OK [01/04/2008 10:13:45] GDFS 000E Hash OK [01/04/2008 10:13:45] GDFS 001C Hash OK [01/04/2008 10:13:45] Unlocking ... [01/04/2008 10:13:45] Testing security ... [01/04/2008 10:13:45] GDFS 0013 Hash OK [01/04/2008 10:13:45] GDFS 0006 Hash OK [01/04/2008 10:13:45] GDFS 000E Hash OK [01/04/2008 10:13:45] GDFS 001C Hash OK [01/04/2008 10:13:45] Generating GDFS... [01/04/2008 10:13:45] Writing GDFS... [01/04/2008 10:13:55] Done. [01/04/2008 10:13:55] [01/04/2008 10:16:48] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:16:49] User selected phone W200 using Test Point boot mode [01/04/2008 10:16:49] Stage 1 started [01/04/2008 10:16:49] 1) Turn OFF the phone. [01/04/2008 10:16:49] 2) Connect the phone to DreamBox cable. [01/04/2008 10:16:49] Boot Responce = 5A [01/04/2008 10:16:49] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:16:52] NOR Flash ID = 897E [01/04/2008 10:16:52] OTP Status = LOCKED [01/04/2008 10:16:52] OTP IMEI = 359707-01-917283-9 [01/04/2008 10:16:52] OTP CID = 51 [01/04/2008 10:16:52] EROM Color = 4 : RED [01/04/2008 10:16:52] EROM CID = 52 [01/04/2008 10:17:14] Hint : Now the probe might be disconnected [01/04/2008 10:17:21] Processing ... / [01/04/2008 10:17:21] Error : Testpoint failed. Check pin and try again. [01/04/2008 10:17:21] Error : Failed. [01/04/2008 10:17:21] [01/04/2008 10:17:23] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:17:23] User selected phone W200 using Test Point boot mode [01/04/2008 10:17:24] Stage 1 started [01/04/2008 10:17:24] 1) Turn OFF the phone. [01/04/2008 10:17:24] 2) Connect the phone to DreamBox cable. [01/04/2008 10:17:24] Boot Responce = 5A [01/04/2008 10:17:24] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:17:27] NOR Flash ID = 897E [01/04/2008 10:17:27] OTP Status = LOCKED [01/04/2008 10:17:27] OTP IMEI = 359707-01-917283-9 [01/04/2008 10:17:27] OTP CID = 51 [01/04/2008 10:17:27] EROM Color = 4 : RED [01/04/2008 10:17:27] EROM CID = 52 [01/04/2008 10:17:42] Hint : Now the probe might be disconnected [01/04/2008 10:17:49] Processing ... | [01/04/2008 10:17:49] Error : Testpoint failed. Check pin and try again. [01/04/2008 10:17:49] Error : Failed. [01/04/2008 10:17:49] [01/04/2008 10:17:52] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:17:52] User selected phone W200 using Test Point boot mode [01/04/2008 10:17:53] Stage 1 started [01/04/2008 10:17:53] 1) Turn OFF the phone. [01/04/2008 10:17:53] 2) Connect the phone to DreamBox cable. [01/04/2008 10:17:53] Boot Responce = 5A [01/04/2008 10:17:53] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:17:56] NOR Flash ID = 897E [01/04/2008 10:17:56] OTP Status = LOCKED [01/04/2008 10:17:56] OTP IMEI = 359707-01-917283-9 [01/04/2008 10:17:56] OTP CID = 51 [01/04/2008 10:17:56] EROM Color = 4 : RED [01/04/2008 10:17:56] EROM CID = 52 [01/04/2008 10:18:16] Hint : Now the probe might be disconnected [01/04/2008 10:18:26] Processing ... [01/04/2008 10:18:26] Stage 1 completed succesfully [01/04/2008 10:18:27] Stage 2 start [01/04/2008 10:18:53] Hint : Now the probe might be disconnected [01/04/2008 10:19:01] Processing... [01/04/2008 10:19:05] Entering Security Bypass mode ... [01/04/2008 10:19:05] 1) Turn OFF the phone. [01/04/2008 10:19:05] 2) Connect the phone to DreamBox cable. [01/04/2008 10:19:05] Boot Responce = 5A [01/04/2008 10:19:05] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:19:08] Baseband Chip ID = 8040 [01/04/2008 10:19:08] Phone ID = 23801B7D1530F2DF [01/04/2008 10:19:08] Finalizing ... [01/04/2008 10:19:10] Stage 2 completed succesfully [01/04/2008 10:19:10] Done. [01/04/2008 10:19:10] [01/04/2008 10:19:14] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 10:19:14] User selected phone W200 using Security Bypass boot mode [01/04/2008 10:19:15] 1) Turn OFF the phone. [01/04/2008 10:19:15] 2) Connect the phone to DreamBox cable. [01/04/2008 10:19:15] Boot Responce = 5A [01/04/2008 10:19:15] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:19:17] Baseband Chip ID = 8040 [01/04/2008 10:19:17] Phone ID = 23801B7D1530F2DF [01/04/2008 10:19:17] Reading GDFS... [01/04/2008 10:19:19] Testing security ... [01/04/2008 10:19:20] GDFS 0013 Hash OK [01/04/2008 10:19:20] GDFS 0006 Hash OK [01/04/2008 10:19:20] GDFS 000E Hash OK [01/04/2008 10:19:20] GDFS 001C Hash OK [01/04/2008 10:19:20] Unlocking ... [01/04/2008 10:19:20] Testing security ... [01/04/2008 10:19:20] GDFS 0013 Hash OK [01/04/2008 10:19:20] GDFS 0006 Hash OK [01/04/2008 10:19:20] GDFS 000E Hash OK [01/04/2008 10:19:20] GDFS 001C Hash OK [01/04/2008 10:19:20] Generating GDFS... [01/04/2008 10:19:21] Writing GDFS... [01/04/2008 10:19:30] Done. [01/04/2008 10:19:30] [01/04/2008 10:23:06] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:23:06] User selected phone W200 using Test Point boot mode [01/04/2008 10:23:07] Stage 1 started [01/04/2008 10:23:07] 1) Turn OFF the phone. [01/04/2008 10:23:07] 2) Connect the phone to DreamBox cable. [01/04/2008 10:23:07] Boot Responce = 5A [01/04/2008 10:23:07] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:23:09] NOR Flash ID = 897E [01/04/2008 10:23:09] OTP Status = LOCKED [01/04/2008 10:23:09] OTP IMEI = 359707-01-923169-2 [01/04/2008 10:23:09] OTP CID = 51 [01/04/2008 10:23:09] EROM Color = 4 : RED [01/04/2008 10:23:09] EROM CID = 52 [01/04/2008 10:23:38] Hint : Now the probe might be disconnected [01/04/2008 10:23:48] Processing ... [01/04/2008 10:23:48] Stage 1 completed succesfully [01/04/2008 10:23:49] Stage 2 start [01/04/2008 10:24:31] Timeout detected [01/04/2008 10:24:31] Error : Failed. [01/04/2008 10:24:31] [01/04/2008 10:24:34] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:24:34] User selected phone W200 using Test Point boot mode [01/04/2008 10:24:35] Stage 2 start [01/04/2008 10:24:54] Hint : Now the probe might be disconnected [01/04/2008 10:25:02] Processing... [01/04/2008 10:25:06] Entering Security Bypass mode ... [01/04/2008 10:25:06] 1) Turn OFF the phone. [01/04/2008 10:25:06] 2) Connect the phone to DreamBox cable. [01/04/2008 10:25:06] Boot Responce = 5A [01/04/2008 10:25:06] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:25:09] Baseband Chip ID = 8040 [01/04/2008 10:25:09] Phone ID = 23801B7D151062E1 [01/04/2008 10:25:09] Finalizing ... [01/04/2008 10:25:11] Stage 2 completed succesfully [01/04/2008 10:25:11] Done. [01/04/2008 10:25:11] [01/04/2008 10:25:14] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 10:25:14] User selected phone W200 using Security Bypass boot mode [01/04/2008 10:25:14] 1) Turn OFF the phone. [01/04/2008 10:25:14] 2) Connect the phone to DreamBox cable. [01/04/2008 10:25:15] Boot Responce = 5A [01/04/2008 10:25:15] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:25:17] Baseband Chip ID = 8040 [01/04/2008 10:25:17] Phone ID = 23801B7D151062E1 [01/04/2008 10:25:17] Reading GDFS... [01/04/2008 10:25:19] Testing security ... [01/04/2008 10:25:19] GDFS 0013 Hash OK [01/04/2008 10:25:20] GDFS 0006 Hash OK [01/04/2008 10:25:20] GDFS 000E Hash OK [01/04/2008 10:25:20] GDFS 001C Hash OK [01/04/2008 10:25:20] Unlocking ... [01/04/2008 10:25:20] Testing security ... [01/04/2008 10:25:20] GDFS 0013 Hash OK [01/04/2008 10:25:20] GDFS 0006 Hash OK [01/04/2008 10:25:20] GDFS 000E Hash OK [01/04/2008 10:25:20] GDFS 001C Hash OK [01/04/2008 10:25:20] Generating GDFS... [01/04/2008 10:25:21] Writing GDFS... [01/04/2008 10:25:30] Done. [01/04/2008 10:25:30] [01/04/2008 10:31:48] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:31:48] User selected phone W200 using Test Point boot mode [01/04/2008 10:31:48] Stage 1 started [01/04/2008 10:31:48] 1) Turn OFF the phone. [01/04/2008 10:31:48] 2) Connect the phone to DreamBox cable. [01/04/2008 10:31:48] Boot Responce = 5A [01/04/2008 10:31:49] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:31:51] NOR Flash ID = 897E [01/04/2008 10:31:51] OTP Status = LOCKED [01/04/2008 10:31:51] OTP IMEI = 359707-01-918275-4 [01/04/2008 10:31:51] OTP CID = 51 [01/04/2008 10:31:51] EROM Color = 4 : RED [01/04/2008 10:31:51] EROM CID = 52 [01/04/2008 10:32:03] Hint : Now the probe might be disconnected [01/04/2008 10:32:03] Processing ... [01/04/2008 10:32:03] Error : Invalid GDFS structure and/or configuration. [01/04/2008 10:32:03] Hint : Try to flash firmware. [01/04/2008 10:32:04] Error : Failed. [01/04/2008 10:32:04] [01/04/2008 10:32:06] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:32:06] User selected phone W200 using Test Point boot mode [01/04/2008 10:32:07] Stage 1 started [01/04/2008 10:32:07] 1) Turn OFF the phone. [01/04/2008 10:32:07] 2) Connect the phone to DreamBox cable. [01/04/2008 10:32:07] Boot Responce = 5A [01/04/2008 10:32:07] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:32:10] NOR Flash ID = 897E [01/04/2008 10:32:10] OTP Status = LOCKED [01/04/2008 10:32:10] OTP IMEI = 359707-01-918275-4 [01/04/2008 10:32:10] OTP CID = 51 [01/04/2008 10:32:10] EROM Color = 4 : RED [01/04/2008 10:32:10] EROM CID = 52 [01/04/2008 10:32:50] Warning : Aborted by user. [01/04/2008 10:32:50] [01/04/2008 10:32:51] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:32:51] User selected phone W200 using Test Point boot mode [01/04/2008 10:32:52] Stage 1 started [01/04/2008 10:32:52] 1) Turn OFF the phone. [01/04/2008 10:32:52] 2) Connect the phone to DreamBox cable. [01/04/2008 10:32:52] Boot Responce = 5A [01/04/2008 10:32:52] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:32:54] NOR Flash ID = 897E [01/04/2008 10:32:54] OTP Status = LOCKED [01/04/2008 10:32:54] OTP IMEI = 359707-01-918275-4 [01/04/2008 10:32:54] OTP CID = 51 [01/04/2008 10:32:54] EROM Color = 4 : RED [01/04/2008 10:32:54] EROM CID = 52 [01/04/2008 10:33:05] Hint : Now the probe might be disconnected [01/04/2008 10:33:15] Processing ... [01/04/2008 10:33:15] Stage 1 completed succesfully [01/04/2008 10:33:16] Stage 2 start [01/04/2008 10:33:37] Hint : Now the probe might be disconnected [01/04/2008 10:33:45] Processing... [01/04/2008 10:33:48] Entering Security Bypass mode ... [01/04/2008 10:33:48] 1) Turn OFF the phone. [01/04/2008 10:33:48] 2) Connect the phone to DreamBox cable. [01/04/2008 10:33:48] Boot Responce = 5A [01/04/2008 10:33:48] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:33:51] Baseband Chip ID = 8040 [01/04/2008 10:33:51] Phone ID = 23801B7D153030E0 [01/04/2008 10:33:51] Finalizing ... [01/04/2008 10:33:53] Stage 2 completed succesfully [01/04/2008 10:33:53] Done. [01/04/2008 10:33:53] [01/04/2008 10:33:57] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 10:33:57] User selected phone W200 using Security Bypass boot mode [01/04/2008 10:33:58] 1) Turn OFF the phone. [01/04/2008 10:33:58] 2) Connect the phone to DreamBox cable. [01/04/2008 10:33:58] Boot Responce = 5A [01/04/2008 10:33:58] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:34:01] Baseband Chip ID = 8040 [01/04/2008 10:34:01] Phone ID = 23801B7D153030E0 [01/04/2008 10:34:01] Reading GDFS... [01/04/2008 10:34:03] Testing security ... [01/04/2008 10:34:03] GDFS 0013 Hash OK [01/04/2008 10:34:03] GDFS 0006 Hash OK [01/04/2008 10:34:03] GDFS 000E Hash OK [01/04/2008 10:34:03] GDFS 001C Hash OK [01/04/2008 10:34:03] Unlocking ... [01/04/2008 10:34:03] Testing security ... [01/04/2008 10:34:04] GDFS 0013 Hash OK [01/04/2008 10:34:04] GDFS 0006 Hash OK [01/04/2008 10:34:04] GDFS 000E Hash OK [01/04/2008 10:34:04] GDFS 001C Hash OK [01/04/2008 10:34:04] Generating GDFS... [01/04/2008 10:34:04] Writing GDFS... [01/04/2008 10:34:14] Done. [01/04/2008 10:34:14] [01/04/2008 10:37:01] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:37:01] User selected phone W200 using Test Point boot mode [01/04/2008 10:37:02] Stage 1 started [01/04/2008 10:37:02] 1) Turn OFF the phone. [01/04/2008 10:37:02] 2) Connect the phone to DreamBox cable. [01/04/2008 10:37:02] Boot Responce = 5A [01/04/2008 10:37:02] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 10:37:04] NOR Flash ID = 897E [01/04/2008 10:37:04] OTP Status = LOCKED [01/04/2008 10:37:04] OTP IMEI = 357354-01-811061-9 [01/04/2008 10:37:04] OTP CID = 51 [01/04/2008 10:37:04] EROM Color = 4 : RED [01/04/2008 10:37:04] EROM CID = 52 [01/04/2008 10:37:22] Hint : Now the probe might be disconnected [01/04/2008 10:37:30] Processing ... [01/04/2008 10:37:30] Stage 1 completed succesfully [01/04/2008 10:37:31] Stage 2 start [01/04/2008 10:38:19] Timeout detected [01/04/2008 10:38:19] Error : Failed. [01/04/2008 10:38:19] [01/04/2008 10:46:59] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:46:59] User selected phone W200 using Test Point boot mode [01/04/2008 10:47:00] Stage 2 start [01/04/2008 10:47:24] Timeout detected [01/04/2008 10:47:24] Error : Failed. [01/04/2008 10:47:24] [01/04/2008 10:47:30] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:47:30] User selected phone W200 using Test Point boot mode [01/04/2008 10:47:31] Stage 2 start [01/04/2008 10:48:02] Timeout detected [01/04/2008 10:48:02] Error : Failed. [01/04/2008 10:48:02] [01/04/2008 10:48:04] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:48:04] User selected phone W200 using Test Point boot mode [01/04/2008 10:48:06] Stage 2 start [01/04/2008 10:48:27] Timeout detected [01/04/2008 10:48:27] Error : Failed. [01/04/2008 10:48:27] [01/04/2008 10:52:08] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:52:08] User selected phone W200 using Test Point boot mode [01/04/2008 10:52:09] Stage 2 start [01/04/2008 10:52:14] Warning : Aborted by user. [01/04/2008 10:52:14] [01/04/2008 10:52:15] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:52:15] User selected phone W200 using Test Point boot mode [01/04/2008 10:52:16] Stage 2 start [01/04/2008 10:52:39] Timeout detected [01/04/2008 10:52:39] Error : Failed. [01/04/2008 10:52:39] [01/04/2008 10:52:41] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:52:41] User selected phone W200 using Test Point boot mode [01/04/2008 10:52:43] Stage 2 start [01/04/2008 10:53:03] Timeout detected [01/04/2008 10:53:03] Error : Failed. [01/04/2008 10:53:03] [01/04/2008 10:53:11] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:53:11] User selected phone W200 using Test Point boot mode [01/04/2008 10:53:12] Stage 2 start [01/04/2008 10:53:43] Timeout detected [01/04/2008 10:53:43] Error : Failed. [01/04/2008 10:53:43] [01/04/2008 10:53:45] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:53:45] User selected phone W200 using Test Point boot mode [01/04/2008 10:53:46] Stage 2 start [01/04/2008 10:54:32] Timeout detected [01/04/2008 10:54:32] Error : Failed. [01/04/2008 10:54:32] [01/04/2008 10:54:40] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:54:40] User selected phone W200 using Test Point boot mode [01/04/2008 10:54:41] Stage 2 start [01/04/2008 10:56:19] Timeout detected [01/04/2008 10:56:19] Error : Failed. [01/04/2008 10:56:19] [01/04/2008 10:58:50] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:58:50] User selected phone W200 using Test Point boot mode [01/04/2008 10:58:52] Stage 2 start [01/04/2008 10:59:15] Timeout detected [01/04/2008 10:59:16] Error : Failed. [01/04/2008 10:59:16] [01/04/2008 10:59:17] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:59:17] User selected phone W200 using Test Point boot mode [01/04/2008 10:59:18] Stage 2 start [01/04/2008 10:59:44] Timeout detected [01/04/2008 10:59:44] Error : Failed. [01/04/2008 10:59:44] [01/04/2008 10:59:46] --- Security Bypass------------------------------------------------------------ [01/04/2008 10:59:46] User selected phone W200 using Test Point boot mode [01/04/2008 10:59:47] Stage 2 start [01/04/2008 11:00:09] Hint : Now the probe might be disconnected [01/04/2008 11:00:35] Warning : Aborted by user. [01/04/2008 11:00:35] [01/04/2008 11:00:36] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:00:36] User selected phone W200 using Test Point boot mode [01/04/2008 11:00:37] Stage 2 start [01/04/2008 11:00:58] Warning : Aborted by user. [01/04/2008 11:00:58] [01/04/2008 11:00:58] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:00:58] User selected phone W200 using Test Point boot mode [01/04/2008 11:00:59] Stage 2 start [01/04/2008 11:01:22] Timeout detected [01/04/2008 11:01:23] Error : Failed. [01/04/2008 11:01:23] [01/04/2008 11:01:24] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:01:24] User selected phone W200 using Test Point boot mode [01/04/2008 11:01:25] Stage 2 start [01/04/2008 11:01:36] Hint : Now the probe might be disconnected [01/04/2008 11:01:44] Processing... [01/04/2008 11:01:48] Entering Security Bypass mode ... [01/04/2008 11:01:48] 1) Turn OFF the phone. [01/04/2008 11:01:48] 2) Connect the phone to DreamBox cable. [01/04/2008 11:01:48] Boot Responce = 5A [01/04/2008 11:01:48] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:01:50] Baseband Chip ID = 8040 [01/04/2008 11:01:51] Phone ID = 2380EA73155003C6 [01/04/2008 11:01:51] Finalizing ... [01/04/2008 11:01:53] Stage 2 completed succesfully [01/04/2008 11:01:53] Done. [01/04/2008 11:01:53] [01/04/2008 11:01:57] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 11:01:57] User selected phone W200 using Security Bypass boot mode [01/04/2008 11:01:58] 1) Turn OFF the phone. [01/04/2008 11:01:58] 2) Connect the phone to DreamBox cable. [01/04/2008 11:01:58] Boot Responce = 5A [01/04/2008 11:01:58] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:02:01] Baseband Chip ID = 8040 [01/04/2008 11:02:01] Phone ID = 2380EA73155003C6 [01/04/2008 11:02:01] Reading GDFS... [01/04/2008 11:02:03] Testing security ... [01/04/2008 11:02:03] GDFS 0013 Hash OK [01/04/2008 11:02:03] GDFS 0006 Hash OK [01/04/2008 11:02:03] GDFS 000E Hash OK [01/04/2008 11:02:03] GDFS 001C Hash OK [01/04/2008 11:02:03] Unlocking ... [01/04/2008 11:02:04] Testing security ... [01/04/2008 11:02:04] GDFS 0013 Hash OK [01/04/2008 11:02:04] GDFS 0006 Hash OK [01/04/2008 11:02:04] GDFS 000E Hash OK [01/04/2008 11:02:04] GDFS 001C Hash OK [01/04/2008 11:02:04] Generating GDFS... [01/04/2008 11:02:04] Writing GDFS... [01/04/2008 11:02:14] Done. [01/04/2008 11:02:14] [01/04/2008 11:07:29] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:07:29] User selected phone W200 using Test Point boot mode [01/04/2008 11:07:30] Stage 1 started [01/04/2008 11:07:30] 1) Turn OFF the phone. [01/04/2008 11:07:30] 2) Connect the phone to DreamBox cable. [01/04/2008 11:07:30] Boot Responce = 5A [01/04/2008 11:07:30] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:07:33] NOR Flash ID = 2019 [01/04/2008 11:07:33] OTP Status = LOCKED [01/04/2008 11:07:33] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:07:33] OTP CID = 51 [01/04/2008 11:07:33] EROM Color = 4 : RED [01/04/2008 11:07:33] EROM CID = 52 [01/04/2008 11:08:15] Hint : Now the probe might be disconnected [01/04/2008 11:08:19] Processing ... / [01/04/2008 11:08:19] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:08:19] Error : Failed. [01/04/2008 11:08:19] [01/04/2008 11:08:24] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:08:24] User selected phone W200 using Test Point boot mode [01/04/2008 11:08:24] Stage 1 started [01/04/2008 11:08:24] 1) Turn OFF the phone. [01/04/2008 11:08:24] 2) Connect the phone to DreamBox cable. [01/04/2008 11:08:25] Boot Responce = 5A [01/04/2008 11:08:25] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:08:27] NOR Flash ID = 2019 [01/04/2008 11:08:27] OTP Status = LOCKED [01/04/2008 11:08:27] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:08:27] OTP CID = 51 [01/04/2008 11:08:27] EROM Color = 4 : RED [01/04/2008 11:08:27] EROM CID = 52 [01/04/2008 11:09:00] Hint : Now the probe might be disconnected [01/04/2008 11:09:07] Processing ... / [01/04/2008 11:09:07] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:09:08] Error : Failed. [01/04/2008 11:09:08] [01/04/2008 11:09:18] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:09:18] User selected phone W200 using Test Point boot mode [01/04/2008 11:09:18] Stage 1 started [01/04/2008 11:09:18] 1) Turn OFF the phone. [01/04/2008 11:09:18] 2) Connect the phone to DreamBox cable. [01/04/2008 11:09:18] Boot Responce = 5A [01/04/2008 11:09:19] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:09:21] NOR Flash ID = 2019 [01/04/2008 11:09:21] OTP Status = LOCKED [01/04/2008 11:09:21] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:09:21] OTP CID = 51 [01/04/2008 11:09:21] EROM Color = 4 : RED [01/04/2008 11:09:21] EROM CID = 52 [01/04/2008 11:09:31] Hint : Now the probe might be disconnected [01/04/2008 11:09:38] Processing ... | [01/04/2008 11:09:38] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:09:38] Error : Failed. [01/04/2008 11:09:38] [01/04/2008 11:09:48] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:09:48] User selected phone W200 using Test Point boot mode [01/04/2008 11:09:49] Stage 1 started [01/04/2008 11:09:49] 1) Turn OFF the phone. [01/04/2008 11:09:49] 2) Connect the phone to DreamBox cable. [01/04/2008 11:09:49] Boot Responce = 5A [01/04/2008 11:09:49] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:09:51] NOR Flash ID = 2019 [01/04/2008 11:09:51] OTP Status = LOCKED [01/04/2008 11:09:51] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:09:51] OTP CID = 51 [01/04/2008 11:09:51] EROM Color = 4 : RED [01/04/2008 11:09:51] EROM CID = 52 [01/04/2008 11:10:25] Hint : Now the probe might be disconnected [01/04/2008 11:10:29] Processing ... | [01/04/2008 11:10:29] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:10:29] Error : Failed. [01/04/2008 11:10:29] [01/04/2008 11:10:39] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:10:39] User selected phone W200 using Test Point boot mode [01/04/2008 11:10:39] Stage 1 started [01/04/2008 11:10:39] 1) Turn OFF the phone. [01/04/2008 11:10:39] 2) Connect the phone to DreamBox cable. [01/04/2008 11:10:39] Boot Responce = 5A [01/04/2008 11:10:40] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:10:42] NOR Flash ID = 2019 [01/04/2008 11:10:42] OTP Status = LOCKED [01/04/2008 11:10:42] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:10:42] OTP CID = 51 [01/04/2008 11:10:42] EROM Color = 4 : RED [01/04/2008 11:10:42] EROM CID = 52 [01/04/2008 11:10:58] Hint : Now the probe might be disconnected [01/04/2008 11:11:04] Processing ... - [01/04/2008 11:11:04] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:11:04] Error : Failed. [01/04/2008 11:11:04] [01/04/2008 11:11:06] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:11:06] User selected phone W200 using Test Point boot mode [01/04/2008 11:11:07] Stage 1 started [01/04/2008 11:11:07] 1) Turn OFF the phone. [01/04/2008 11:11:07] 2) Connect the phone to DreamBox cable. [01/04/2008 11:11:07] Boot Responce = 5A [01/04/2008 11:11:07] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:11:09] NOR Flash ID = 2019 [01/04/2008 11:11:10] OTP Status = LOCKED [01/04/2008 11:11:10] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:11:10] OTP CID = 51 [01/04/2008 11:11:10] EROM Color = 4 : RED [01/04/2008 11:11:10] EROM CID = 52 [01/04/2008 11:16:54] Warning : Aborted by user. [01/04/2008 11:16:54] [01/04/2008 11:16:55] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:16:55] User selected phone W200 using Test Point boot mode [01/04/2008 11:16:55] Stage 1 started [01/04/2008 11:16:56] 1) Turn OFF the phone. [01/04/2008 11:16:56] 2) Connect the phone to DreamBox cable. [01/04/2008 11:17:03] Boot Responce = 5A [01/04/2008 11:17:03] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:17:05] NOR Flash ID = 2019 [01/04/2008 11:17:05] OTP Status = LOCKED [01/04/2008 11:17:05] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:17:05] OTP CID = 51 [01/04/2008 11:17:05] EROM Color = 4 : RED [01/04/2008 11:17:05] EROM CID = 52 [01/04/2008 11:17:48] Hint : Now the probe might be disconnected [01/04/2008 11:17:54] Processing ... | [01/04/2008 11:17:54] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:17:54] Error : Failed. [01/04/2008 11:17:54] [01/04/2008 11:17:57] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:17:57] User selected phone W200 using Test Point boot mode [01/04/2008 11:17:58] Stage 1 started [01/04/2008 11:17:58] 1) Turn OFF the phone. [01/04/2008 11:17:58] 2) Connect the phone to DreamBox cable. [01/04/2008 11:17:58] Boot Responce = 5A [01/04/2008 11:17:58] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:18:00] NOR Flash ID = 2019 [01/04/2008 11:18:00] OTP Status = LOCKED [01/04/2008 11:18:00] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:18:00] OTP CID = 51 [01/04/2008 11:18:00] EROM Color = 4 : RED [01/04/2008 11:18:00] EROM CID = 52 [01/04/2008 11:18:27] Hint : Now the probe might be disconnected [01/04/2008 11:18:35] Processing ... \ [01/04/2008 11:18:35] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:18:35] Error : Failed. [01/04/2008 11:18:35] [01/04/2008 11:21:13] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:21:13] User selected phone W200 using Test Point boot mode [01/04/2008 11:21:14] Stage 1 started [01/04/2008 11:21:14] 1) Turn OFF the phone. [01/04/2008 11:21:14] 2) Connect the phone to DreamBox cable. [01/04/2008 11:21:14] Boot Responce = 5A [01/04/2008 11:21:14] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:21:16] NOR Flash ID = 2019 [01/04/2008 11:21:16] OTP Status = LOCKED [01/04/2008 11:21:16] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:21:16] OTP CID = 51 [01/04/2008 11:21:16] EROM Color = 4 : RED [01/04/2008 11:21:16] EROM CID = 52 [01/04/2008 11:21:46] Hint : Now the probe might be disconnected [01/04/2008 11:21:53] Processing ... - [01/04/2008 11:21:53] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:21:54] Error : Failed. [01/04/2008 11:21:54] [01/04/2008 11:21:57] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:21:57] User selected phone W200 using Test Point boot mode [01/04/2008 11:21:58] Stage 1 started [01/04/2008 11:21:58] 1) Turn OFF the phone. [01/04/2008 11:21:58] 2) Connect the phone to DreamBox cable. [01/04/2008 11:21:58] Boot Responce = 5A [01/04/2008 11:21:58] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:22:00] NOR Flash ID = 2019 [01/04/2008 11:22:00] OTP Status = LOCKED [01/04/2008 11:22:00] OTP IMEI = 357355-01-958479-3 [01/04/2008 11:22:00] OTP CID = 51 [01/04/2008 11:22:00] EROM Color = 4 : RED [01/04/2008 11:22:00] EROM CID = 52 [01/04/2008 11:22:32] Hint : Now the probe might be disconnected [01/04/2008 11:22:42] Processing ... [01/04/2008 11:22:42] Stage 1 completed succesfully [01/04/2008 11:22:43] Stage 2 start [01/04/2008 11:23:19] Hint : Now the probe might be disconnected [01/04/2008 11:23:27] Processing... [01/04/2008 11:23:31] Entering Security Bypass mode ... [01/04/2008 11:23:31] 1) Turn OFF the phone. [01/04/2008 11:23:31] 2) Connect the phone to DreamBox cable. [01/04/2008 11:23:31] Boot Responce = 5A [01/04/2008 11:23:31] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:23:33] Baseband Chip ID = 8040 [01/04/2008 11:23:33] Phone ID = 2380EB7315F000EA [01/04/2008 11:23:33] Finalizing ... [01/04/2008 11:23:35] Stage 2 completed succesfully [01/04/2008 11:23:36] Done. [01/04/2008 11:23:36] [01/04/2008 11:25:19] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 11:25:19] User selected phone W200 using Security Bypass boot mode [01/04/2008 11:25:20] 1) Turn OFF the phone. [01/04/2008 11:25:20] 2) Connect the phone to DreamBox cable. [01/04/2008 11:25:20] Boot Responce = 5A [01/04/2008 11:25:20] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:25:23] Baseband Chip ID = 8040 [01/04/2008 11:25:23] Phone ID = 2380EB7315F000EA [01/04/2008 11:25:23] Reading GDFS... [01/04/2008 11:25:25] Testing security ... [01/04/2008 11:25:25] GDFS 0013 Hash OK [01/04/2008 11:25:25] GDFS 0006 Hash OK [01/04/2008 11:25:25] GDFS 000E Hash OK [01/04/2008 11:25:25] GDFS 001C Hash OK [01/04/2008 11:25:25] Unlocking ... [01/04/2008 11:25:26] Testing security ... [01/04/2008 11:25:26] GDFS 0013 Hash OK [01/04/2008 11:25:26] GDFS 0006 Hash OK [01/04/2008 11:25:26] GDFS 000E Hash OK [01/04/2008 11:25:26] GDFS 001C Hash OK [01/04/2008 11:25:26] Generating GDFS... [01/04/2008 11:25:26] Writing GDFS... [01/04/2008 11:25:35] Done. [01/04/2008 11:25:35] [01/04/2008 11:29:12] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:29:12] User selected phone W200 using Test Point boot mode [01/04/2008 11:29:12] Stage 1 started [01/04/2008 11:29:13] 1) Turn OFF the phone. [01/04/2008 11:29:13] 2) Connect the phone to DreamBox cable. [01/04/2008 11:29:13] Boot Responce = 5A [01/04/2008 11:29:13] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:29:15] NOR Flash ID = 897E [01/04/2008 11:29:15] OTP Status = LOCKED [01/04/2008 11:29:15] OTP IMEI = 357354-01-816192-7 [01/04/2008 11:29:15] OTP CID = 51 [01/04/2008 11:29:15] EROM Color = 4 : RED [01/04/2008 11:29:15] EROM CID = 52 [01/04/2008 11:29:34] Hint : Now the probe might be disconnected [01/04/2008 11:29:42] Processing ... - [01/04/2008 11:29:42] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:29:42] Error : Failed. [01/04/2008 11:29:42] [01/04/2008 11:29:44] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:29:44] User selected phone W200 using Test Point boot mode [01/04/2008 11:29:45] Stage 1 started [01/04/2008 11:29:45] 1) Turn OFF the phone. [01/04/2008 11:29:45] 2) Connect the phone to DreamBox cable. [01/04/2008 11:29:45] Boot Responce = 5A [01/04/2008 11:29:45] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:29:47] NOR Flash ID = 897E [01/04/2008 11:29:47] OTP Status = LOCKED [01/04/2008 11:29:47] OTP IMEI = 357354-01-816192-7 [01/04/2008 11:29:47] OTP CID = 51 [01/04/2008 11:29:47] EROM Color = 4 : RED [01/04/2008 11:29:47] EROM CID = 52 [01/04/2008 11:30:09] Hint : Now the probe might be disconnected [01/04/2008 11:30:16] Processing ... / [01/04/2008 11:30:16] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:30:16] Error : Failed. [01/04/2008 11:30:16] [01/04/2008 11:30:19] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:30:19] User selected phone W200 using Test Point boot mode [01/04/2008 11:30:19] Stage 1 started [01/04/2008 11:30:19] 1) Turn OFF the phone. [01/04/2008 11:30:19] 2) Connect the phone to DreamBox cable. [01/04/2008 11:30:20] Boot Responce = 5A [01/04/2008 11:30:20] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:30:22] NOR Flash ID = 897E [01/04/2008 11:30:22] OTP Status = LOCKED [01/04/2008 11:30:22] OTP IMEI = 357354-01-816192-7 [01/04/2008 11:30:22] OTP CID = 51 [01/04/2008 11:30:22] EROM Color = 4 : RED [01/04/2008 11:30:22] EROM CID = 52 [01/04/2008 11:30:51] Hint : Now the probe might be disconnected [01/04/2008 11:30:58] Processing ... | [01/04/2008 11:30:58] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:30:58] Error : Failed. [01/04/2008 11:30:58] [01/04/2008 11:31:00] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:31:00] User selected phone W200 using Test Point boot mode [01/04/2008 11:31:01] Stage 1 started [01/04/2008 11:31:01] 1) Turn OFF the phone. [01/04/2008 11:31:01] 2) Connect the phone to DreamBox cable. [01/04/2008 11:31:01] Boot Responce = 5A [01/04/2008 11:31:01] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:31:04] NOR Flash ID = 897E [01/04/2008 11:31:04] OTP Status = LOCKED [01/04/2008 11:31:04] OTP IMEI = 357354-01-816192-7 [01/04/2008 11:31:04] OTP CID = 51 [01/04/2008 11:31:04] EROM Color = 4 : RED [01/04/2008 11:31:04] EROM CID = 52 [01/04/2008 11:31:18] Hint : Now the probe might be disconnected [01/04/2008 11:31:29] Processing ... [01/04/2008 11:31:29] Stage 1 completed succesfully [01/04/2008 11:31:29] Stage 2 start [01/04/2008 11:31:57] Warning : Aborted by user. [01/04/2008 11:31:57] [01/04/2008 11:31:58] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:31:59] User selected phone W200 using Test Point boot mode [01/04/2008 11:32:00] Stage 2 start [01/04/2008 11:32:27] Timeout detected [01/04/2008 11:32:27] Error : Failed. [01/04/2008 11:32:27] [01/04/2008 11:32:30] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:32:30] User selected phone W200 using Test Point boot mode [01/04/2008 11:32:31] Stage 2 start [01/04/2008 11:33:13] Hint : Now the probe might be disconnected [01/04/2008 11:33:21] Processing... [01/04/2008 11:33:24] Entering Security Bypass mode ... [01/04/2008 11:33:24] 1) Turn OFF the phone. [01/04/2008 11:33:24] 2) Connect the phone to DreamBox cable. [01/04/2008 11:33:24] Boot Responce = 5A [01/04/2008 11:33:24] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:33:27] Baseband Chip ID = 8040 [01/04/2008 11:33:27] Phone ID = 2380EA73150044C7 [01/04/2008 11:33:27] Finalizing ... [01/04/2008 11:33:29] Stage 2 completed succesfully [01/04/2008 11:33:29] Done. [01/04/2008 11:33:29] [01/04/2008 11:33:33] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 11:33:33] User selected phone W200 using Security Bypass boot mode [01/04/2008 11:33:34] 1) Turn OFF the phone. [01/04/2008 11:33:34] 2) Connect the phone to DreamBox cable. [01/04/2008 11:33:34] Boot Responce = 5A [01/04/2008 11:33:34] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:33:36] Baseband Chip ID = 8040 [01/04/2008 11:33:36] Phone ID = 2380EA73150044C7 [01/04/2008 11:33:36] Reading GDFS... [01/04/2008 11:33:39] Testing security ... [01/04/2008 11:33:39] GDFS 0013 Hash OK [01/04/2008 11:33:39] GDFS 0006 Hash OK [01/04/2008 11:33:39] GDFS 000E Hash OK [01/04/2008 11:33:39] GDFS 001C Hash OK [01/04/2008 11:33:39] Unlocking ... [01/04/2008 11:33:39] Testing security ... [01/04/2008 11:33:39] GDFS 0013 Hash OK [01/04/2008 11:33:39] GDFS 0006 Hash OK [01/04/2008 11:33:39] GDFS 000E Hash OK [01/04/2008 11:33:39] GDFS 001C Hash OK [01/04/2008 11:33:39] Generating GDFS... [01/04/2008 11:33:40] Writing GDFS... [01/04/2008 11:33:50] Done. [01/04/2008 11:33:50] [01/04/2008 11:47:51] [01/04/2008 11:47:51] DBSS Start 3.1.2 [01/04/2008 11:48:03] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:48:05] User selected phone W200 using Test Point boot mode [01/04/2008 11:48:06] Stage 1 started [01/04/2008 11:48:06] 1) Turn OFF the phone. [01/04/2008 11:48:06] 2) Connect the phone to DreamBox cable. [01/04/2008 11:48:06] Boot Responce = 5A [01/04/2008 11:48:06] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:48:08] NOR Flash ID = 897E [01/04/2008 11:48:08] OTP Status = LOCKED [01/04/2008 11:48:08] OTP IMEI = 357354-01-906813-9 [01/04/2008 11:48:08] OTP CID = 51 [01/04/2008 11:48:08] EROM Color = 4 : RED [01/04/2008 11:48:08] EROM CID = 52 [01/04/2008 11:48:45] Hint : Now the probe might be disconnected [01/04/2008 11:48:53] Processing ... / [01/04/2008 11:48:53] Error : Testpoint failed. Check pin and try again. [01/04/2008 11:48:53] Error : Failed. [01/04/2008 11:48:53] [01/04/2008 11:49:00] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:49:00] User selected phone W200 using Test Point boot mode [01/04/2008 11:49:01] Stage 1 started [01/04/2008 11:49:01] 1) Turn OFF the phone. [01/04/2008 11:49:01] 2) Connect the phone to DreamBox cable. [01/04/2008 11:49:01] Boot Responce = 5A [01/04/2008 11:49:01] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:49:03] NOR Flash ID = 897E [01/04/2008 11:49:03] OTP Status = LOCKED [01/04/2008 11:49:03] OTP IMEI = 357354-01-906813-9 [01/04/2008 11:49:03] OTP CID = 51 [01/04/2008 11:49:03] EROM Color = 4 : RED [01/04/2008 11:49:03] EROM CID = 52 [01/04/2008 11:49:26] Hint : Now the probe might be disconnected [01/04/2008 11:49:26] Processing ... [01/04/2008 11:49:26] Error : Invalid GDFS structure and/or configuration. [01/04/2008 11:49:26] Hint : Try to flash firmware. [01/04/2008 11:49:27] Error : Failed. [01/04/2008 11:49:27] [01/04/2008 11:49:29] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:49:29] User selected phone W200 using Test Point boot mode [01/04/2008 11:49:30] Stage 1 started [01/04/2008 11:49:30] 1) Turn OFF the phone. [01/04/2008 11:49:30] 2) Connect the phone to DreamBox cable. [01/04/2008 11:49:30] Boot Responce = 5A [01/04/2008 11:49:30] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:49:32] NOR Flash ID = 897E [01/04/2008 11:49:33] OTP Status = LOCKED [01/04/2008 11:49:33] OTP IMEI = 357354-01-906813-9 [01/04/2008 11:49:33] OTP CID = 51 [01/04/2008 11:49:33] EROM Color = 4 : RED [01/04/2008 11:49:33] EROM CID = 52 [01/04/2008 11:49:39] Hint : Now the probe might be disconnected [01/04/2008 11:50:14] Processing ... [01/04/2008 11:50:14] Warning : Aborted by user. [01/04/2008 11:50:14] [01/04/2008 11:50:14] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:50:15] User selected phone W200 using Test Point boot mode [01/04/2008 11:50:15] Stage 1 started [01/04/2008 11:50:15] 1) Turn OFF the phone. [01/04/2008 11:50:15] 2) Connect the phone to DreamBox cable. [01/04/2008 11:50:15] Boot Responce = 5A [01/04/2008 11:50:15] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:50:18] NOR Flash ID = 897E [01/04/2008 11:50:18] OTP Status = LOCKED [01/04/2008 11:50:18] OTP IMEI = 357354-01-906813-9 [01/04/2008 11:50:18] OTP CID = 51 [01/04/2008 11:50:18] EROM Color = 4 : RED [01/04/2008 11:50:18] EROM CID = 52 [01/04/2008 11:50:49] Hint : Now the probe might be disconnected [01/04/2008 11:51:00] Processing ... [01/04/2008 11:51:00] Stage 1 completed succesfully [01/04/2008 11:51:01] Stage 2 start [01/04/2008 11:53:18] Warning : Aborted by user. [01/04/2008 11:53:18] [01/04/2008 11:53:19] --- Security Bypass------------------------------------------------------------ [01/04/2008 11:53:19] User selected phone W200 using Test Point boot mode [01/04/2008 11:53:20] Stage 2 start [01/04/2008 11:53:48] Hint : Now the probe might be disconnected [01/04/2008 11:53:56] Processing... [01/04/2008 11:54:00] Entering Security Bypass mode ... [01/04/2008 11:54:00] 1) Turn OFF the phone. [01/04/2008 11:54:00] 2) Connect the phone to DreamBox cable. [01/04/2008 11:54:00] Boot Responce = 5A [01/04/2008 11:54:00] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:54:03] Baseband Chip ID = 8040 [01/04/2008 11:54:03] Phone ID = 2380EA7315D063DD [01/04/2008 11:54:03] Finalizing ... [01/04/2008 11:54:05] Stage 2 completed succesfully [01/04/2008 11:54:05] Done. [01/04/2008 11:54:05] [01/04/2008 11:54:07] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 11:54:07] User selected phone W200 using Security Bypass boot mode [01/04/2008 11:54:08] 1) Turn OFF the phone. [01/04/2008 11:54:08] 2) Connect the phone to DreamBox cable. [01/04/2008 11:54:08] Boot Responce = 5A [01/04/2008 11:54:08] Processor ID = 8040030101010101 (DB2012 R3A) [01/04/2008 11:54:10] Baseband Chip ID = 8040 [01/04/2008 11:54:10] Phone ID = 2380EA7315D063DD [01/04/2008 11:54:11] Reading GDFS... [01/04/2008 11:54:13] Testing security ... [01/04/2008 11:54:13] GDFS 0013 Hash OK [01/04/2008 11:54:13] GDFS 0006 Hash OK [01/04/2008 11:54:13] GDFS 000E Hash OK [01/04/2008 11:54:13] GDFS 001C Hash OK [01/04/2008 11:54:13] Unlocking ... [01/04/2008 11:54:13] Testing security ... [01/04/2008 11:54:14] GDFS 0013 Hash OK [01/04/2008 11:54:14] GDFS 0006 Hash OK [01/04/2008 11:54:14] GDFS 000E Hash OK [01/04/2008 11:54:14] GDFS 001C Hash OK [01/04/2008 11:54:14] Generating GDFS... [01/04/2008 11:54:14] Writing GDFS... [01/04/2008 11:54:24] Done. [01/04/2008 11:54:24] [01/04/2008 12:58:03] Last edited by GSM Dream; 04-01-2008 at 11:11. |
04-01-2008, 10:46 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lost in this Field Age: 39
Member: 154513 Status: Offline Thanks Meter: 160 | 2 W850 gdfs repaired 1st one Code: [01/04/2008 12:59:56] --- Security Bypass------------------------------------------------------------ [01/04/2008 12:59:56] User selected phone W850 using Test Point boot mode [01/04/2008 12:59:57] Stage 1 started [01/04/2008 12:59:57] 1) Turn OFF the phone. [01/04/2008 12:59:57] 2) Connect the phone to DreamBox cable. [01/04/2008 12:59:57] Boot Responce = 5A [01/04/2008 12:59:57] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [01/04/2008 12:59:59] NOR Flash ID = 897E [01/04/2008 12:59:59] OTP Status = LOCKED [01/04/2008 12:59:59] OTP IMEI = 352826-01-052728-3 [01/04/2008 12:59:59] OTP CID = 49 [01/04/2008 12:59:59] EROM Color = 4 : RED [01/04/2008 12:59:59] EROM CID = 52 [01/04/2008 13:01:00] Hint : Now the probe might be disconnected [01/04/2008 13:01:11] Processing ... [01/04/2008 13:01:11] Stage 1 completed succesfully [01/04/2008 13:01:11] Stage 2 start [01/04/2008 13:02:18] Timeout detected [01/04/2008 13:02:18] Error : Failed. [01/04/2008 13:02:18] [01/04/2008 13:02:19] --- Security Bypass------------------------------------------------------------ [01/04/2008 13:02:19] User selected phone W850 using Test Point boot mode [01/04/2008 13:02:20] Stage 1 started [01/04/2008 13:02:20] 1) Turn OFF the phone. [01/04/2008 13:02:20] 2) Connect the phone to DreamBox cable. [01/04/2008 13:02:20] Boot Responce = 5A [01/04/2008 13:02:20] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [01/04/2008 13:02:22] NOR Flash ID = 897E [01/04/2008 13:02:22] OTP Status = LOCKED [01/04/2008 13:02:22] OTP IMEI = 352826-01-052728-3 [01/04/2008 13:02:22] OTP CID = 49 [01/04/2008 13:02:22] EROM Color = 4 : RED [01/04/2008 13:02:22] EROM CID = 52 [01/04/2008 13:02:32] Error : Failed. [01/04/2008 13:02:32] [01/04/2008 13:02:33] --- Security Bypass------------------------------------------------------------ [01/04/2008 13:02:33] User selected phone W850 using Test Point boot mode [01/04/2008 13:02:34] Stage 2 start [01/04/2008 13:04:05] Hint : Now the probe might be disconnected [01/04/2008 13:04:10] Processing... [01/04/2008 13:04:17] Entering Security Bypass mode ... [01/04/2008 13:04:17] 1) Turn OFF the phone. [01/04/2008 13:04:17] 2) Connect the phone to DreamBox cable. [01/04/2008 13:04:17] Boot Responce = 5A [01/04/2008 13:04:18] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [01/04/2008 13:04:19] Sending Application ... [01/04/2008 13:04:20] NOR Flash ID = 897E [01/04/2008 13:04:20] OTP Status = LOCKED [01/04/2008 13:04:20] OTP IMEI = 352826-01-052728-3 [01/04/2008 13:04:20] OTP CID = 49 [01/04/2008 13:04:20] EROM Color = 4 : RED [01/04/2008 13:04:20] EROM CID = 52 [01/04/2008 13:04:22] Baseband Chip ID = 9900 [01/04/2008 13:04:22] Phone ID = 21803A621580DF0C [01/04/2008 13:04:22] Finalizing ... [01/04/2008 13:04:23] Stage 2 completed succesfully [01/04/2008 13:04:23] Done. [01/04/2008 13:04:23] [01/04/2008 13:04:30] --- Unlock and Repair---------------------------------------------------------- [01/04/2008 13:04:30] User selected phone W850 using Security Bypass boot mode [01/04/2008 13:04:31] 1) Turn OFF the phone. [01/04/2008 13:04:31] 2) Connect the phone to DreamBox cable. [01/04/2008 13:04:31] Boot Responce = 5A [01/04/2008 13:04:31] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [01/04/2008 13:04:32] Sending Application ... [01/04/2008 13:04:33] NOR Flash ID = 897E [01/04/2008 13:04:33] OTP Status = LOCKED [01/04/2008 13:04:33] OTP IMEI = 352826-01-052728-3 [01/04/2008 13:04:33] OTP CID = 49 [01/04/2008 13:04:33] EROM Color = 4 : RED [01/04/2008 13:04:34] EROM CID = 52 [01/04/2008 13:04:35] Baseband Chip ID = 9900 [01/04/2008 13:04:35] Phone ID = 21803A621580DF0C [01/04/2008 13:04:35] Reading GDFS... [01/04/2008 13:04:37] Testing security ... [01/04/2008 13:04:37] GDFS 0013 Hash OK [01/04/2008 13:04:37] GDFS 0006 Hash OK [01/04/2008 13:04:37] GDFS 000E Hash OK [01/04/2008 13:04:37] GDFS 001C Hash OK [01/04/2008 13:04:37] Unlocking ... [01/04/2008 13:04:37] Testing security ... [01/04/2008 13:04:37] GDFS 0013 Hash OK [01/04/2008 13:04:37] GDFS 0006 Hash OK [01/04/2008 13:04:38] GDFS 000E Hash OK [01/04/2008 13:04:38] GDFS 001C Hash OK [01/04/2008 13:04:38] Generating GDFS... [01/04/2008 13:04:38] Writing GDFS... [01/04/2008 13:04:45] Done. [01/04/2008 13:04:45] [/QUOTE] Second One [QUOTE][31/03/2008 19:39:20] --- Security Bypass------------------------------------------------------------ [31/03/2008 19:39:21] User selected phone W850 using Test Point boot mode [31/03/2008 19:39:21] Stage 1 started [31/03/2008 19:39:21] 1) Turn OFF the phone. [31/03/2008 19:39:21] 2) Connect the phone to DreamBox cable. [31/03/2008 19:39:25] Boot Responce = 5A [31/03/2008 19:39:25] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [31/03/2008 19:39:27] NOR Flash ID = 897E [31/03/2008 19:39:27] OTP Status = LOCKED [31/03/2008 19:39:27] OTP IMEI = 352401-01-142421-9 [31/03/2008 19:39:27] OTP CID = 49 [31/03/2008 19:39:27] EROM Color = 4 : RED [31/03/2008 19:39:27] EROM CID = 49 [31/03/2008 19:42:11] Hint : Now the probe might be disconnected [31/03/2008 19:42:21] Processing ... [31/03/2008 19:42:21] Stage 1 completed succesfully [31/03/2008 19:42:22] Stage 2 start [31/03/2008 20:43:49] Hint : Now the probe might be disconnected [31/03/2008 20:43:54] Processing... [31/03/2008 20:44:01] Entering Security Bypass mode ... [31/03/2008 20:44:01] 1) Turn OFF the phone. [31/03/2008 20:44:01] 2) Connect the phone to DreamBox cable. [31/03/2008 20:44:01] Boot Responce = 5A [31/03/2008 20:44:01] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [31/03/2008 20:44:02] Sending Application ... [31/03/2008 20:44:04] NOR Flash ID = 897E [31/03/2008 20:44:04] OTP Status = LOCKED [31/03/2008 20:44:04] OTP IMEI = 352401-01-142421-9 [31/03/2008 20:44:04] OTP CID = 49 [31/03/2008 20:44:04] EROM Color = 4 : RED [31/03/2008 20:44:04] EROM CID = 52 [31/03/2008 20:44:05] Baseband Chip ID = 9900 [31/03/2008 20:44:06] Phone ID = 218091601550C522 [31/03/2008 20:44:06] Finalizing ... [31/03/2008 20:44:06] Stage 2 completed succesfully [31/03/2008 20:44:07] Done. [31/03/2008 20:44:07] [31/03/2008 20:44:13] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 20:44:14] User selected phone W850 using Security Bypass boot mode [31/03/2008 20:44:14] 1) Turn OFF the phone. [31/03/2008 20:44:14] 2) Connect the phone to DreamBox cable. [31/03/2008 20:44:18] Boot Responce = 5A [31/03/2008 20:44:18] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [31/03/2008 20:44:19] Sending Application ... [31/03/2008 20:44:20] NOR Flash ID = 897E [31/03/2008 20:44:20] OTP Status = LOCKED [31/03/2008 20:44:20] OTP IMEI = 352401-01-142421-9 [31/03/2008 20:44:20] OTP CID = 49 [31/03/2008 20:44:20] EROM Color = 4 : RED [31/03/2008 20:44:20] EROM CID = 52 [31/03/2008 20:44:22] Baseband Chip ID = 9900 [31/03/2008 20:44:22] Phone ID = 218091601550C522 [31/03/2008 20:44:22] Reading GDFS... [31/03/2008 20:44:23] Testing security ... [31/03/2008 20:44:23] GDFS 0013 Hash OK [31/03/2008 20:44:23] GDFS 0006 Hash OK [31/03/2008 20:44:23] GDFS 000E Hash OK [31/03/2008 20:44:23] GDFS 001C Hash OK [31/03/2008 20:44:23] Unlocking ... [31/03/2008 20:44:24] Testing security ... [31/03/2008 20:44:24] GDFS 0013 Hash OK [31/03/2008 20:44:24] GDFS 0006 Hash OK [31/03/2008 20:44:24] GDFS 000E Hash OK [31/03/2008 20:44:24] GDFS 001C Hash OK [31/03/2008 20:44:24] Generating GDFS... [31/03/2008 20:44:24] Writing GDFS... [31/03/2008 20:44:32] Done. [31/03/2008 20:44:32] Last edited by GSM Dream; 04-01-2008 at 11:10. |
04-01-2008, 10:49 | #4 (permalink) |
Member: 154513 Status: Offline Thanks Meter: 160 | Here K800 Gdfs repaired Check this out K800 Gdfs repaired Code: [31/03/2008 19:15:21] --- Security Bypass------------------------------------------------------------ [31/03/2008 19:15:22] User selected phone K800 using Test Point boot mode [31/03/2008 19:15:22] Stage 1 started [31/03/2008 19:15:22] 1) Turn OFF the phone. [31/03/2008 19:15:22] 2) Connect the phone to DreamBox cable. [31/03/2008 19:15:22] Boot Responce = 5A [31/03/2008 19:15:22] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [31/03/2008 19:15:24] NOR Flash ID = 897E [31/03/2008 19:15:24] OTP Status = LOCKED [31/03/2008 19:15:24] OTP IMEI = 351707-01-467902-6 [31/03/2008 19:15:24] OTP CID = 49 [31/03/2008 19:15:24] EROM Color = 4 : RED [31/03/2008 19:15:24] EROM CID = 52 [31/03/2008 19:15:41] Hint : Now the probe might be disconnected [31/03/2008 19:15:51] Processing ... [31/03/2008 19:15:51] Stage 1 completed succesfully [31/03/2008 19:15:52] Stage 2 start [31/03/2008 19:26:15] Hint : Now the probe might be disconnected [31/03/2008 19:26:20] Processing... [31/03/2008 19:26:27] Entering Security Bypass mode ... [31/03/2008 19:26:27] 1) Turn OFF the phone. [31/03/2008 19:26:27] 2) Connect the phone to DreamBox cable. [31/03/2008 19:26:27] Boot Responce = 5A [31/03/2008 19:26:27] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [31/03/2008 19:26:28] Sending Application ... [31/03/2008 19:26:30] NOR Flash ID = 897E [31/03/2008 19:26:30] OTP Status = LOCKED [31/03/2008 19:26:30] OTP IMEI = 351707-01-467902-6 [31/03/2008 19:26:30] OTP CID = 49 [31/03/2008 19:26:30] EROM Color = 4 : RED [31/03/2008 19:26:30] EROM CID = 52 [31/03/2008 19:26:31] Baseband Chip ID = 9900 [31/03/2008 19:26:31] Phone ID = 2180DB5D15E03B72 [31/03/2008 19:26:31] Finalizing ... [31/03/2008 19:26:33] Stage 2 completed succesfully [31/03/2008 19:26:33] Done. [31/03/2008 19:26:33] [31/03/2008 19:26:35] --- Unlock and Repair---------------------------------------------------------- [31/03/2008 19:26:35] User selected phone K800 using Security Bypass boot mode [31/03/2008 19:26:36] 1) Turn OFF the phone. [31/03/2008 19:26:36] 2) Connect the phone to DreamBox cable. [31/03/2008 19:26:36] Boot Responce = 5A [31/03/2008 19:26:36] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [31/03/2008 19:26:37] Sending Application ... [31/03/2008 19:26:39] NOR Flash ID = 897E [31/03/2008 19:26:39] OTP Status = LOCKED [31/03/2008 19:26:39] OTP IMEI = 351707-01-467902-6 [31/03/2008 19:26:39] OTP CID = 49 [31/03/2008 19:26:39] EROM Color = 4 : RED [31/03/2008 19:26:39] EROM CID = 52 [31/03/2008 19:26:40] Baseband Chip ID = 9900 [31/03/2008 19:26:41] Phone ID = 2180DB5D15E03B72 [31/03/2008 19:26:41] Reading GDFS... [31/03/2008 19:26:42] Testing security ... [31/03/2008 19:26:42] GDFS 0013 Hash OK [31/03/2008 19:26:42] GDFS 0006 Hash OK [31/03/2008 19:26:42] GDFS 000E Hash OK [31/03/2008 19:26:42] GDFS 001C Hash OK [31/03/2008 19:26:42] Unlocking ... [31/03/2008 19:26:43] Testing security ... [31/03/2008 19:26:43] GDFS 0013 Hash OK [31/03/2008 19:26:43] GDFS 0006 Hash OK [31/03/2008 19:26:43] GDFS 000E Hash OK [31/03/2008 19:26:43] GDFS 001C Hash OK [31/03/2008 19:26:43] Generating GDFS... [31/03/2008 19:26:43] Writing GDFS... [31/03/2008 19:26:53] Done. Last edited by GSM Dream; 04-01-2008 at 11:10. |
04-01-2008, 16:56 | #7 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: UK , london
Member: 292640 Status: Offline Thanks Meter: 18 | Thanks Bro Quote:
DreamBox Team is the best to provide that solution because all credits goes to their team not to us we will do work on their solution and share here because we appreciate their efforts. again All credit goes to Dream Box Team Keep it up your hard solutions & we do with your solutions more things & Solve our Problems | |
04-01-2008, 17:27 | #9 (permalink) | |
Member: 154513 Status: Offline Thanks Meter: 160 | Here is W580 Gdfs Repaired See here W850 gdfs repaired in first try Quote:
04-01-2008, 17:40 | #10 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,047 | Hi GSM Killer as you have unlocked 25 PCS And Get Too Much Money why don,t you send some to the great Team (Dream Box Team ) |
04-01-2008, 20:47 | #13 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Here and there Age: 40
Member: 52560 Status: Offline Thanks Meter: 226 | Quote:
BR Last edited by Bi0H4z4rD; 04-01-2008 at 20:55. | |
plz help my HWK was working ok last night and now it shows this to me | deep_6111 | UFS - Pro | 2 | 11-28-2009 12:18 |
got ub last night help to install it and run it | dapinderjit | Universalbox | 10 | 11-01-2009 09:00 |
v3r unlock done by smart-clip this morning | mquimpanes | Smart-Clip | 0 | 07-02-2009 02:55 |
n95 unlock by ?????????100% in 3 min and 43sec | armany99 | Nokia Base Band 5 ( BB-5 ) | 109 | 08-22-2007 22:09 |
