02-15-2006, 19:53 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Working with Sony Ericsson How to Upgrade DreamBox to the DreamBox SE? 1. Purchase the "DreamBox to SE activation" at www.gsmserver.com. 2. Download the latest version of DBSS from www.dreambox.hk and install it. 3. Connect DreamBox to PC USB port. 4. Launch DBSS. 5. Select DreamBox >> Functionality Upgrade from the main menu. 6. Activation window pops up on the screen. 7. Enter the activation code into the field and press OK button. 8. Within one hour please perform DreamBox update procedure. How to repair "GDFS" zone? In order to get "GDFS" zone repaired, please perform the identical procedure as for the "Test Point unlock". Alternatively, the phone can be flashed with GDFS zone or Full Flash file backed up from another working handset of the same model.
Remove SP lock using "Test Point" connection method. No patches applied. Lock is removed directly from the phone firmware. The process doesn’t require Internet connection and not limited. In order to apply the "Test Point" access mode, the DreamBox Test Point cable is required. This mode is meant to be used to turn the phone into "Security Bypass" state. The procedure has to go through the Stage 1 and Stage 2 of the "Execute "Security Bypass" Operations":
"Test Point" unlock procedure
It may happen that the "Stage 2" fails to complete. In this case please repeat the process for the "Stage 2" only. How to change the language pack in the phone? There are several ways to change the language pack in the phone.
If the corresponding firmware version can not be found at www.boot-loader.com please perform the following steps.
Working with Siemens. 1. How to use Firmware Bug (manual)? 1.Connect phone to box2. How to modify my testpoint cable for EGold phones? Testpoint cable EGold modification3. Where I can find pinout for new Siemens-Banq phones? In the DreamBox's section (Docs folder) on www.boot-loader.comNote If you have any problem with DremBox, please send ALL log files from DBSS with your forum's name and problem description to us (Program Files->DreamBox ALL .log files) and we will solve yor problem as soon as possible. Cables The cable for Benq-Siemens phones is for working with A31, AF51, C81, EL71, S68. You can find pinout here. The cable for "New Siemens" phones (X55) is for working with C65, C66, C6C, C6V, C72V, CX6C, CX6V, CX7C, CX7V, C72, C75, CF75, CX65, CX70, CX75, CX7i, CF110, C55, C60, CF62, M65, M75, ME75, M6C, M55, MC60, S65, SK65, SK6R, SL65, SL6C, S6V, S6C, S66, S75, SL75, S55, SL55, A51, A52, A52V, A55, A57, A60, A65, A70, A75, AX75, A65C, A52M, A62C, SX1, A62, AX72, AL21, A71, A56i. The cable for "Old Siemens" phones is for working with 3618, 6618, A50, C45, M46, ME45, MT50, S45, S45i, S46, SL45, SL45i. Please, follow instructions in using DreamBox. 1. Download the last version of DBSS from www.dreambox.hk. 2. Install DBSS on your computer:
4. Install drivers (they are in DBSS folder). 5. Run DBSS. 6. Choose Dream Box->Update Firmware in main menu (You should have stable internet connection). 7. Connect a cables to your box
Than connect your phone to DreamBox by Phone Cable. If it is EGold phone: 1. Choose Mobile Phone. 2. Choose Access Mode (You can use Boot Core Bug, Normal (Cut track), Test Point, Stored Boot key or IMEI boot mode). If Boot Core Bug is possible for this phone, use it. If you will get a message "Check Boot Mode selection", use Normal (Cut track) boot mode (you need to cut your phone before). For using Boot Core Bug or Normal (Cut track) boot mode just run an operation of DBSS with you need. For using Test Point boot mode: 1. Connect the phone. It must be turned OFF. 2. Connect testpoint connector to "+" on your phone. 3. Run an operation of DBSS which you need. 4. Connect the testpoint probe to the phone as shown on the picture and wait. 5. Disconnect the testpoint probe, when you will see a message about this. After this you can run other operation of DBSS on this phone using Stored Boot key or IMEI boot mode. If it is SGold phone: 1. Choose Mobile Phone. 2. Choose Access Mode (You can use Auto, Firmware Bug, Format Bootcore, Test Point, Normal or IMEI boot mode). For using Auto boot mode: 1. Connect the phone. The phone must be: - with phone battery; - turned OFF; - without Sim Card; - with opened slider. 2. Choose Auto boot mode. 3. Choose a model of the phone. 4. Run an operation of DBSS which you need. For using Firmware Bug boot mode: 1. Connect the phone. The phone must be: - without Sim Card; - with opened slider; - turned ON (You can use Simulate SimCard for this). 2. Choose Firmware Bug boot mode. 3. Choose a model of the phone. 4. Run an operation of DBSS which you need. 5. Run Games -> SReader on the phone. For using Test Point boot mode: 1. Connect the phone. It must be turned OFF. 2. Connect a testpoint connector to "+" on your phone. 3. Run an operation of DBSS which you need. 4. Connect the testpoint probe to the phone as shown on the picture and wait. 5. Disconnect the testpoint probe, when you will see a message about this. After this you can run other operation of DBSS on this phone using Autoor IMEI boot mode. For using Format Bootcore boot mode: 1. Connect the phone. It must be turned OFF. 2. Choose Format Bootcore boot mode. 3. Choose a model of the phone. 4. Run an operation of DBSS which you need. For using Normal boot mode: 1. Connect the phone. It must be turned OFF. 2. Choose Normal boot mode. 3. Choose a model of the phone. 4. Run an operation of DBSS which you need. Normal boot mode can be use if:
Please, use also DBSS Help for information about using DBSS. We recommend to select in Options -> Siemens -> 1. Repair IMEI after flashing EEFULL or EELITE are (use OTP IMEI). 2. Repair setup table after flashing firmware area. If you will not do this, probably you can get some problems in work with DBSS. Problems with update firmware. If you get the next messages: -- Reading Info--------------------------------------------------------------- Error : Firmware is too old. Please, upgrade it. you must run Dream Box -> Update Firmware to use this version of DBSS. If you try to update your box and get the next messages: --- Updating Box Firmware------------------------------------------------------ Connecting to server ... Error: Server not found Error : Failed. please, check Internet settings. Problem is in your connection with Internet. If you try to update your box and get the next messages: --- Updating Box Firmware------------------------------------------------------ Connecting to server ...OK Trying to get firmware ... Warning : Update not found. There are no new updates on server or your device is already up to date Done. please, do the next: 1. Run Dream Box -> Read Box Info. 2. Send to DreamSupporter or to GSM Dream by PM this information from logs of DBSS. Last edited by GSM Dream; 03-06-2008 at 00:31. Reason: Update |
The Following 9 Users Say Thank You to DreamSupporter For This Useful Post: |
03-03-2006, 16:53 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | "How to use testpoints" tutorial added. "How to change language or repair a phone" chapter added. "DreamBox cable for new BenQ-Siemens" tutorial added. "DreamBox cable for new BenQ-Siemens" tutorial updated. |
07-25-2006, 18:39 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | ..::all siemens language desription step by step for dreambox user::.. a small gift for all users of the dreambox this the procedure step by step to know the language for all siemens supported by dreambox . all the details are in the Word file and all the stage has to follow are on the picture. * all the models added soon will be added by the dreambox TEAM *. br |
The Following 3 Users Say Thank You to allal123 For This Useful Post: |
07-25-2006, 21:22 | #4 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | First thx mate...... Sample : A50v 05 01 01_20BA A50v aa bb cc_xxxx A50 is phone model v means word: version aa is version of software bb is version of langpack cc is version of t9 languages xxxx is version of flash type Last edited by GSM Dream; 09-05-2006 at 12:03. Reason: Use Language Packs description from DBSS help. |
The Following User Says Thank You to BesTCooL For This Useful Post: |
12-22-2006, 14:53 | #5 (permalink) |
Member: 241271 Status: Offline Thanks Meter: 30 | DreamBox supports the next phones: E-Gold Based Phones: 6618, 3618, A31, A50, A51, A52, A52M, A52V, A53, A55, A56, A56i, A57, A60, A62, A62C, A65, A65C, A70, A71, A75, A76, AF51, AL21, AX72, AX75, AX76, C45, C55, C56, C60, C61, CF62, CF110, M46, M55, M56, MC60, ME45, MT50, S45, S45i, S46, S55, S56, SL45, SL45i, SL55, SL56, SX1. S-Gold Based Phones: C65, C6C, C6V, C66, C70, C72, C72V, C75, C81, CF75, CX65, CX6C, CX6V, CX70, CX75, CX7C, CX7I, CX7V, EL71, E71, M65, M6C, M6V, M75, M81, ME75, S65, S6C, S6V, S66, S68, S75, SK65, SK6R, SP65, SL65, SL6C, SL75, SL7F. ODM Panasonic Based Phones (Unlock by calculation of "unlock codes"): 8008, CL50, CL55, ST55, ST55(old), ST60. |
The Following 3 Users Say Thank You to DreamSupporter For This Useful Post: |
To Hack3r2k PLEASE READ THIS THIS.... | ..::Waqar::.. | FuriousGold | 4 | 05-02-2009 16:27 |
Please read this before posting in this section | Javajohn | J.A.F. By Jafsupport.com | 0 | 08-23-2007 20:57 |
How to get my free logs? Please, please, please read this F.A.Q. carefully!!!! | Raskal | Blazer | 1 | 02-09-2005 21:40 |
