Strange K550 --- Security Bypass------------------------------------------------------------ User selected phone K550 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 354893-01-073763-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 51 AFter that no more respone . Newbie for DBSS . does i did something WRONG ? phone come with RED BLINKING GDFS FAILED startup |
my idea you must checking flash chip and power ic i have same this problem and reheat power ic the phone is ok . before this flash phone and checking again |
EROM CID = 51 i think you have to change to CID=52 Dear then try |
i have same problem k530 -- Security Bypass------------------------------------------------------------ User selected phone K530 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 359019-01-*********xx OTP CID = 51 Error : Failed. |
This phone is related to hardware... check in hardware. |
