W200 Still Dead Even After Test Point Success Reading Info--------------------------------------------------------------- User selected phone W200 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357************ OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Error : Invalid GDFS and/or configuration. Hint : Try to flash firmware. Error : Failed GDFS REPAIR ALREADY DONE SUCCEFULLY BY TEST POINT Unlock and Repair---------------------------------------------------------- User selected phone W200 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 52 Baseband Chip ID = 8040 Phone ID = 2380EB731550DD23 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. PHONE STILL DEAD CANT POWER ON ALSO FUL FLASHED WAITING THANKS |
try to full flash maybe flashing problem |
phone Still Dead Cant Power On Also Ful Flashed |
Hello! What version of DBSS you use? |
@gsm DREAM BOX SERIVCE SOFTWARE 3.6 |
1. Download fullflash file for W200 2. Choose model W200 in DBSS 3. Select Access Mode - Test Point 4. Go to Security tab & Execute " Security Bypass" Operation 5. Select Access Mode - Security Bypass 6. Go to Misc tab & Write Full Flash (look in p.#1) 7. After flashing go to Security tab & make "Unlock & Repair GDFS Sec. Blc." 8. Go to Flash tab & flash: Main+FS+Custpac. If that not help to You so it is HW problem - LCD, FlexCable, Flash IC, water damage etc. ... Anyway, you can send log files from DBSS to us, and we will try to find where problem is. |
