Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 05-13-2008, 10:30   #1 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
possible change cid k320 50 to 52
Hi DreamBox Team....
can i change cid 50 to 52 k320?
with T/P or without T/P
thanks for replay...
B/R
babak nuri
Old 05-13-2008, 11:37   #2 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
Hello!
You can change CID from 50 to 52 for K320 with testpoint.
Old 05-13-2008, 14:14   #3 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hello sir
yes.my problem solved
but one Question :
why after repair damaged gdfs by DreamBox,setool can't read or write with usb(Hold "C").....
i need upgrade cid k320 to 52 and change imei with setool(new update)...
change cid is ok,but can't detect k320 with usb(dcu-60),bypass only supported by usb....
this error by setool after upgrade cid.......
ChipID:8040,EMP protocol:0301
NEW SECURITY MODEL DETECTED
erom_readvar: error reading unit 1/725
error while reading SIMLOCK SIGNATURE unit
phone was tampered with other software
SECURITY UNITS CAN'T BE READ !
DAMAGED FIRMWARE,GDFS OR EMPTY PHONE
Can't load ID loader !
Elapsed: 7 secs.
Old 05-13-2008, 14:38   #4 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,696
its Simple Man dream box when doing TP
they writing patched erom with own custom loader embedded, patching simlock signature check and ... erasing simlock signature without any reason, which prevents setool2 from making backup.
fix is extremly simple:
using com/ufs write next script in SIGNED MODE (check ONLY "USE SIGNED MODE" on settings)
for db2020:
gdfswrite:0001085144554D4D5944415441for db2012:
gdfswrite:0001072544554D4D5944415441
they custom loader also breaks alternative bypass support using dcu60 cable,
so you only can use SIGNED MODE with dcu60 after their "testpoint".
Old 05-13-2008, 14:38   #5 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
We are already wrote about this problem here.
Old 05-13-2008, 16:35   #6 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 363
Originally Posted by BABAK NURI View Post
... i need upgrade cid k320 to 52 and change imei with setool(new update)...
Change flash IC and do emptyfill ...
Old 05-13-2008, 23:45   #7 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
for db2020:
Hi....
thanks for replay
solve problem
***after change cid k320 50 to 52,i can change imei & free unlock with flash w200 firmware ***
thanks dream for good support
please add imei option with or without T\P....
Very hard change cid with TP by dream & flash phone with setool & change by setool
B/R
babak nuri
SIM-Lock remover DB2010/DB2012 CID 49/50/51/52 reactos Sony Ericsson 159 04-14-2010 21:53
SIM-Lock Remover DB2010/DB2012 CID 49/50/51/52/53 loyunk Sony Ericsson 1 04-27-2009 12:01
SIMLockPatchGen_v2.2 DB2010/DB2012 CID 49/50/51/52/53 mani6 Sony Ericsson 1 03-01-2009 18:20
SIM-Lock remover DB2010/DB2012 CID 49/50/51/52 cyme01913 Sony Ericsson 3 02-26-2009 23:29
Page generated in 0.18516 seconds with 9 queries
