w810 db2010 cid 50 is not supported??? just want to ask is w810 db2010 cid 50 not supported yet? thanks User selected phone W810 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 49 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352336-01-650170-4 OTP CID = 49 EROM Color = 4 : RED EROM CID = 49 Error : DB201x CID < 50 is not supported Error : Failed. br |
that is the mesage i recieve when i make phone info & do test point with dreambox m8 br |
ok it is cid 49 but why i get that mesage? can you explain why? that is the log from dreambox br |
see the message clearly.... "Error : DB201x CID < 50 is not supported" below CID50 is not supported... |
ok thanks i will upgrade my cid br |
Regards. |
ok so what will i do? can you share your idea what does it mean? about the mesage i recieve? thanks br |
br >>> GsmFreeShop <<< |
this phone is dead when it came to me.i have flash it with setool but gdf error.so i was trying to repair it with drembox. br |
You can't repair it with dream box cause it's not supported yet try to flash it with mt se if you have it with w810i flash all in one br >>> GsmFreeShop <<< |
thanks bro problem solve i just flash it with setool again now phone is working fine.coz before when i flash this unit with setool i get error.now it is ok i just use usb cable to flash the phone br |
